Southern California SoCal
Old 01-13-2015, 07:20 PM   #1
Choco
Embarrassed Doge
Choco's Avatar
Drives: Shibaru BRZ
Where Should I Take My BRZ for 30k Major Service? (SGV Area Preferably?)
My Beerzy, is nearly ready for it's first major service. Would it be a good idea to take to a dealer or a shop?
I tried to compare prices with two dealers by email asking how much it would cost for 30k service on a 2013 BRZ (Sierra Subaru and Puente Hills Subaru). Sierra quickly quoted me $450 while Puente Hills contacted me with multiple emails wanting my phone number instead of just being to the point and just give me a price. -__-
Anyone got theirs done in those dealers or if not, where did you get it done?
If you don't mind letting me know around how much it cost or if they did a good job, please do. Thanks!
Old 01-13-2015, 07:24 PM   #2
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Call evasive motorsports their 30k service is less than 450. I wouldn't trust a dealer with my car.
Build Thread
Instagram
Old 01-13-2015, 07:50 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Recommended Maintenance
30,000 miles
Inspect automatic transmission fluid
Replace brake fluid
Inspect disc brake pads and discs, front and rear axle boots and axle shaft joint portions
Inspect brake linings and drums
Perform inspect brake lines and check operation of parking and service brake system
Inspect clutch operation
Inspect steering and suspension
Perform rotate and inspect tires
Recommended Inspection fuel systems, lines and connections
Replace a/c filter
Inspect drive belt(s) [except camshaft]
Inspect engine coolant systems, hoses and connections
Replace engine oil
Replace engine oil filter
Replace air cleaner element
Basically:
Bleed/replace brake fluid, replace AC filter, do oil change, replace engine air filter, inspect everything else.
Yeah, any qualified shop you trust can do this, doesn't have to be a dealership. Just keep receipts on file if you do it yourself or use 3rd party.
-alex
dealerships, maintenance, service, shops, socal
AZP Aug/Sep Discounts on Major Service & TPMS Cloning! AZP Installs NY / NJ / CT / PA 0 08-17-2014 10:53 PM
dealership service in Phoenix area Evil86 Southwest 4 04-02-2013 02:41 AM
Where to service your BRZ in the GTA area? chenshuo CANADA 3 02-14-2013 10:41 AM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 11:06 PM
I need a 100% stock BRZ for major parts development in the San Diego area.1 week Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-21-2012 12:09 AM
