Drives: Whiteout FR-S
Subaru or Toyota drain plug?
I have a very strong feeling that its Subarus drain plug, but for those who have changed their oil (if any), do you know if its Toyotas drain plug, or the more likely Subaru?
My main reason for asking, I plan on buying a magnetic drain plug, and would be very disappointed to buy one for Subaru, only to find out it for some reason has Toyotas oil pan. |
Subaru drain plug # 807016160, used on 2010 and up Outback/Legacy, 2012 Impreza, and BRZ. Uses gasket 803916010.
#3 | |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
http://www.quickoildrainvalve.com/Se...lts.asp?Cat=40 |
#4 | |
![]() http://www.shopgreddy.com/accessorie...ug-subaru.html |
Señor Member
Drives: 2013 SSM DZE BRZ
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
I'm pretty sure it's a Subaru drain plug. If you would like I'll order one on Monday and comepair it to the Toyota one see what the difference is. I know the dpg is completely different it uses a metal crush type that is slighty larger that a Toyota 12157-10010 normal Toyota engines use a 90430-12031 composite metal fiber type. So I'm guessing if it is at all close to a Toyota plug it's gonna be a differential drain or fill plug.
#7 | |
Corner Junkie
Ok, did my oil the other day. The Fumoto valves for the new Outback and Impreza work (16mm thread). One note, however. I got one of the valves with the nipple to make oil changes even cleaner. Unfortunately, the end of the nipple is just flush with the skid pan. If I were to run over something I risk tearing the valve out of the oil pan. So for my next oil change I'm going to put in one without the hose nipple.
#10 |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
How reliable are those Fumoto valves?
I'm mostly concerned about the valve being sheared off because the skid pan doesn't cover the drain bolt. The other concern with the quick drain valve is leaking. I'm trying to decide between this and a magnetic drain plug. |
#11 | |
Corner Junkie
If you get the valve without the nipple you don't have to worry about clearance issues. There would be about an inch of clearance between the bottom of the skid plate and the valve. So if you were to hit something hard enough to take out the valve, you've got other issues to worry about, like high-siding the entire car. |
#12 |
Drives: Silver AT Limited
Draco-Rex - do you have a picture of the fumoto valve with a nipple being flush to the skid pad? I ordered one last week and I wonder if I should return it to get the one without the nipple
#13 |
Shipping to Hawaii?...
Drives: '13 Asphalt FR-S
Why haven't I bought these ball valves since I've started driving??? Thanks guys!
~Matt
Efimia (asphalt FRS) |
#14 |
Photo Specialist
I'm strongly considering the fumoto, but is there a major improvement in using a magnetic drain bolt? I don't mind some mess if it means a cleaner engine.
| Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling | Hachiroku | BRZ Photos, Videos, Wallpapers, Gallery Forum | 113 | 11-21-2020 02:02 PM |
| Servicing: BRZ at Toyota / 86 at Subaru | celicajim | AUSTRALIA | 8 | 12-14-2011 05:37 PM |
| Honda to show off EV plug in concepts at Tokyo Auto Show | Dark | Other Vehicles & General Automotive Discussions | 4 | 11-10-2011 09:34 PM |
| Toyota FR-86 vs. Subaru BRZ | Levi | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 08-30-2011 07:04 PM |
| Subaru/Toyota Coupe spotted in Socal with Subaru Plates | owsiu | Scion FR-S / Toyota 86 GT86 General Forum | 150 | 05-25-2011 11:27 PM |
