Old 01-20-2015, 07:03 AM   #1
Guillaume
Guillaume's Avatar
Drives: Exige S 240
OEM illuminated trunk release button
Hi folks,
I am going to share my experience with this small mod that seems pretty popular in Japan: http://ameblo.jp/zn6-86-fa20/entry-1...c=thumb_module
Difficulty: if you own a Phillips screwdriver, you can do it.
Time: 10 min.
You'll need:
  1. A LED-equipped trunk button: Toyota part SU003-05478
  2. Two of these pre-fitted wires: Toyota part 82998-12750
    They turned out to be crazy expensive (€20+ a piece) through my Toyota dealer so I ordered replacement parts from Japan instead: http://global.rakuten.com/en/store/a...43-1-cavs03bk/
  3. To avoid cutting and soldering, I tapped into the harness with two of these: http://global.rakuten.com/en/store/a...0/item/pt-741/
  4. If you don't want to tap directly into the car's harness, you can use this "extension wiring loom": Subaru part H0077AJ001 (I didn't use it)
The pictures in the Japanese blogs are pretty self explanatory but here are the main steps:
1. Remove the stock button. To do so, you'll need to remove the side panel as shown below and you'll be able to unclip the module with the dash dimmer and trunk button. You do not need to remove the lower panel (don't do step 2 from the image).
2. Swap the cover and the electronics from the new button into the frame of the stock button. Be careful, the translucent cover of the new button is pretty fragile, take your time.
It should look like this:
3. Add the power supply to the trunk button connector. That's where the 2 small wires come in.
You can just slide them right in (that's what she said ?), if you open the cover it will look like this:
4. Connect the + wire to the purple wire from the dimmer harness, the ground wire to the black and white wire. That's where I used the connectors shown in item 3 in the parts list.
5. Put everything back together, enjoy the extra 10 hp and all the women throwing themselves at you.
Crappy iPhone pic of my car (AFAIK, first LHD twin with it):
Better picture from Japan:
Guillaume
Old 01-20-2015, 02:24 PM   #2
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I didn't know this was an available part. I've been wanting an illuminated button.
Old 01-20-2015, 03:18 PM   #3
trsiidno
Drives: .
4 pictures arent showing!
trsiidno is offline   Reply With Quote
Old 01-20-2015, 03:27 PM   #4
adamg
Drives: brz
this is pretty awesome
adamg is offline   Reply With Quote
Old 01-20-2015, 04:49 PM   #5
Guillaume
Guillaume's Avatar
Drives: Exige S 240
I reuploaded a few pics, everything should show up now.
Old 01-20-2015, 04:58 PM   #6
STV3
Señor Member
STV3's Avatar
its the little things that count
STV3 is offline   Reply With Quote
Old 01-20-2015, 05:45 PM   #7
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
Thank you!
Still, I feel fortunate. Most of the switches in our cars are illuminated. Every time I want to drive my wife's Rav4 at night, I have to turn on the overhead to locate the alternate seating position switch. Additionally, I don't remember the door locks or window switches being lit either, but correct me if I'm wrong. It's a US market 2013 Rav4 Limited...
NWFRS is offline   Reply With Quote
Old 01-20-2015, 11:12 PM   #8
fritzburg
fritzburg's Avatar
Drives: 2015 Scion FR-S
My 2015 has an illuminated trunk button... I just assumed every year had them
fritzburg is offline   Reply With Quote
Old 01-21-2015, 01:52 AM   #9
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
LOL@myself for not noticing my 2015 has an illuminated trunk button.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 01-21-2015, 02:16 AM   #10
FrostedFlakes
Drives: 2013 Raven FRS
Awesome. You should see if the moderators can move this to the DIY section ~!!!
FrostedFlakes is offline   Reply With Quote
Old 01-21-2015, 02:52 AM   #11
Guillaume
Guillaume's Avatar
Drives: Exige S 240
I didn't know. If someone could get the part number, that would avoid the button internal swapping step.
Old 01-21-2015, 05:22 AM   #12
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
Guillaume
I was on board until this part, my mudflaps already get me unmanageable amounts of ladyparts. Oh well.
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
Old 01-21-2015, 05:54 AM   #13
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Tell me about it, I can't get any rest ever since I put on those hinge and bolt covers.
Old 01-21-2015, 06:04 AM   #14
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
I didn't know they make those for our cars!!
I'm ordering these first thing tomorrow! How much were they??
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Trunk opener button fitcious Scion FR-S / Toyota 86 GT86 General Forum 13 05-13-2014 02:24 AM
Trunk remote or button won't pop open? 914_WHITE_FRS Issues | Warranty | Recalls / TSB 6 07-05-2013 11:08 AM
Trunk button not working Jahdai42 Issues | Warranty | Recalls / TSB 4 02-19-2013 09:03 AM
Trim removal - boot release button panel StuAU Cosmetic Modification (Interior/Exterior/Lighting) 2 02-04-2013 01:48 AM
Question for owners - Boot release button proficience AUSTRALIA 7 07-27-2012 12:12 PM
