Drives: White Series.Blue
Proper BRZ sound
Hello friends,
Simple question: Is it possible to possess this sound without spending $4k on a turbo kit? https://www.youtube.com/watch?v=WbqC1B-thBY Any input would be greatly appreciated. Thanks in advance! |
Drives: 2019 BMW ///M4
[ame="https://www.youtube.com/watch?v=nhP1RpZrs38"]https://www.youtube.com/watch?v=nhP1RpZrs38[/ame]
This is a good alternative. UEL + Muffler Delete
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#3 | |
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
The "proper" sound you are referring to I believe is the lumpy nature of old school Subarus, and that is a result of using Unequal Length Headers. The person in the video you linked to doesn't seem to know what is installed, he claims in the intro he has a "Top Speed Auto over pipe" and a "Top Speed Auto cat-less over pipe". You can't have both, and judging from the sound I think he meant to say something along the lines of "Top Speed Auto UEL Header" in there. Do some research on Unequal Length Headers or UELs, they have their pros and cons over Equal Length Headers. (similar to what comes stock on our cars) I prefer UEL for the added torque and sound, but they're not ideal for turbo setups or squeezing out every last horsepower in general. Here's a video of my setup with just a Tomei UEL and Invidia Cat-back exhaust...still running the factory over pipe with catalytic converter so it's a bit quieter than the fully open, non-cat exhaust in your video link. All of the sound in this video is directly from my car. Be sure to let it play to the end for the drive-by clip/sound. [ame]http://youtu.be/cYT1g3LMFss[/ame]
Okay, perfect. You guys just confirmed my next purchase.
Thanks, again! |
#5 | |
Run Away!
Drives: 2015 Subaru BRZ Limited
Sorry to jack the thread, but did you get the UEL before the CBE? If so, was the rumble noticeable with just the stock exhaust? Also, beautiful sounding car.
Thanks! Quote:
#6 | |
)No, I put the Invidia CBE on first, drove it around for about a week...sounded nice but no rumble of course, then I had the header wrapped and installed, car dyno tuned. Judging by the small increase in sound from running just the Invidia CBE in place of the stock CBE, I would imagine it would be noticeable to run just the UEL header on the stock exhaust, but just not quite as loud as mine of course. Here are a couple of videos with that setup: [ame]http://youtu.be/cO6NJ_lcxZI[/ame] [ame]http://youtu.be/7ZM5d_7c5Xo[/ame]
I had my UEL before changing up the catback. As others have reported, it sounds weird. Hard to describe. Videos make it sound way better- in person, not so much. More tractor-like than anything
Run Away!
Thank you guys for the information. I want something more than the current quiet exhaust note but I'm trying to stay conservative. I had headers and a CBE on my old car and the noise level/drone was horrible.
When I get home I have an audio clip (no video, but decent quality stereo audio) from my car on a cold start and some revs with just a UEL. It is louder than stock and has some rumble, but not a lot.
#10 |
Run Away!
#11 | |
Drives: Fast
Probably the most conservative setup for this car. |
#12 |
Run Away!
Thanks for the heads up. I'm planning to stick to just UEL, drop in, and OFT. I'm trying to avoid the slippery slope of tuning/modding a car, I've spent way too much money before chasing for every last bit of HP/Torque and weight reduction. Just trying to keep things short and simple, but I have a feeling/fear that the modding bug has taken a hold.
#13 | |
Here it is chopped down to about 1 min: This was recorded with a Tascam DR-05 that was sitting on the ground about 6-7' from the car. At the time of this recording the car just had a RevWorks UEL, K&N filter, and OFT Stg. 2 91oct map. You will hear a full cold start, then a where it mellows out at idle, and then a cut to 3 short revs of increasing intensity. The cold start sounds a bit nasty, but after it is warmed up it is not bad. Definitely not as nice as an aftermarket exhaust system. My current system sounds much deeper and nicer overall, but is considerably louder. |
#14 | |
Run Away!
Thank you so very much for that sound clip. I really appreciate your help! It worries me a bit that the cold start is that loud but IIRC, a little tweaking with the tune file in OFT should somewhat reduce that loud cold start right? I need to do more research in which UEL to purchase, if I were to forge ahead with the decision. Once again, thank you! Last edited by Rabbit of Caerbonnog; 01-27-2015 at 10:17 PM. |
| Help on a proper setup | Zechs21 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 01-07-2014 01:20 AM |
| Proper Intake for 86/BRZ | Martin Donnon | Engine, Exhaust, Transmission | 11 | 10-17-2013 05:49 AM |
| Had my car taken away for a proper detailing. | Nourdmrolnmt1 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 8 | 04-16-2013 12:43 AM |
| Proper way to Rev Match | pinoyplaya | Engine, Exhaust, Transmission | 46 | 09-05-2012 02:09 PM |
| A proper test of the FR-S | Vanguard | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 03-19-2012 11:58 PM |
