Old 02-02-2015, 08:12 PM   #1
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
For you engineers out there...
What level math did you finish at? I'm debating whether or not to go to multi variable calculus, since the physics I require start using double integrals with electricity and magnetic fields.
Old 02-02-2015, 08:24 PM   #2
jvincent
jvincent's Avatar
I'm an EE, and we did triple integrals in my last math course.
Old 02-02-2015, 08:40 PM   #3
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
This mostly depends on what field you are eventually going into. I'm an ME now mostly doing mechanical design work and only went as far as ODE (ordinary diff eq.) with a little bit of statistics for my MS. I find in the real world that most high level calcs are pretty much done by software/simulating, but a good base understanding of the math is always good.
Old 02-02-2015, 08:48 PM   #4
jvincent
jvincent's Avatar
@BigFatFlip reminded me that I forgot to mention how much of my math I use in my field.
Pretty much zero when it comes to calculus. Of course that will depend on what you end up doing. I've been in technical management for a while now, but even the guy that work for me have no use for any advanced math. It's all handled in the S/W we use.
Old 02-02-2015, 09:05 PM   #5
cjd
cjd's Avatar
Drives: 2017 BRZ
Well, not sure if software engineer counts I don't use math specifically, much.
My hobbies keep me on my toes, but even that doesn't require me to DO the math any more - I just have to understand it. Vector calculus mostly.
So, as someone said - it really depends what KIND of engineering you're after.
Old 02-02-2015, 09:11 PM   #6
stugray
Drives: 2013 GBS BRZ Limited
I have been an EE in aerospace for 20 years.
I have not used calculus once in those 20 years.
Has the understanding of calculus and it's applications been important? Hell Yes!.
These days almost all the "math" is done with matlab, simulink, IDL or other software. So mostly only the theoretical physics types still need to actually manipulate equations down to the derivative or integral levels.
I think that taking as high a math class as you can take is good.
The more practice you have with higher math the more things you can visualize.
I went as far as Quantum Mechanics (really more math than actual "physics") with a BSEE
Old 02-02-2015, 09:22 PM   #7
Hot Lava
The Antiriced
Hot Lava's Avatar
Drives: women wild
I've found trigonometry to be quite useful. The decision to pick a math class should be oriented toward what specialty you going for. So a wise idea would be to consult the Professor who teaches within the realm of your specialty first.
Hot Lava is offline   Reply With Quote
Old 02-02-2015, 09:32 PM   #8
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Laplace transforms.... something something sandwich rule.... something something Taylor expansion.
Engineering is all about avoiding math.
sin(x) = x for small x. Just saved a ton of time right there.
pushrod is offline   Reply With Quote
Old 02-02-2015, 09:38 PM   #9
jvincent
jvincent's Avatar
Ahh, Laplace transforms. I was the shiznit at those back in the day.
FWIW, it's my engineering class' 25 year reunion this fall.
Old 02-02-2015, 09:42 PM   #10
stugray
We stare at Fourier Transforms at work all the time on spectrum analyzers.
We dont have to calculate them but we have to understand the underlying math.
Old 02-02-2015, 10:23 PM   #11
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
I gave up being a engineer after Trig
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 02-02-2015, 10:48 PM   #12
Ultramaroon
not playing cards
Ultramaroon's Avatar
I hit the brick wall with ODEs. Div, grad, curl was just what it did to my brain. Do your best to be in the spirit of the coursework. It is critical to understand why it all works the way it does so you can spot something that doesn't look right.
We have all these modern, powerful analysis tools at our fingertips but get sucked into that pretty picture syndrome. No substitute for closed-form analysis of a simplified model to validate results from the computer.
Garbage in - garbage out
Old 02-02-2015, 10:53 PM   #13
jvincent
jvincent's Avatar
Important words right here.
In my class there were lots of guys who could do all the problem sets, because they had seen them before, but present them with something new, and they didn't understand it.
Having done a lot of hiring, I try to find the guys who understand how things work because in the end they will be better at solving problems.
Old 02-02-2015, 11:01 PM   #14
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
See, one of the fundimental reasons why i want to be an engineer (and why i kind of, big emphasis on that, like math) is because im a tinkerer and i love how things work. Im sure many of you have already posted in my old engineering threads but im going to be getting into either composites or vehicle design. I think composites is a better option, more things to do.
Eric's BRZ - A motorsports engineers perspective eric6 Member's Car Journals 223 07-14-2015 12:15 PM
Engineers Certificate needed for turbo kit? happytimetom Forced Induction 18 02-23-2014 06:47 PM
Rumor: Mazda Engineers pushing for more RWD models Allch Chcar Other Vehicles & General Automotive Discussions 32 10-15-2013 04:57 PM
Software and electrical engineers look here jonbonazza Engine, Exhaust, Transmission 6 09-16-2013 12:06 AM
Scion test engineers can't drive (Hyundais) holmesbrz Scion FR-S / Toyota 86 GT86 General Forum 23 02-28-2012 03:11 AM
