Southern California SoCal
Old 02-11-2015, 10:22 PM   #1
ironsurfer129
Drives: Whiteout FR-S
Which dealer to go for transmission warranty
Recently I experienced grinding when shifting from 6th to 5th at highway speed and I notice this can be cover under warranty.
Any of you had your tranny replaced and where did you go?
ironsurfer129 is offline   Reply With Quote
Old 02-11-2015, 10:31 PM   #2
tracerit
Drives: '13 SSM BRZ Limited 6MT
I have this same issue. I can 100% of the time circumvent the grinding by revmatching 1000k over what I would normally rev. Well it only exists in the morning when parked outside (or inside a parking structure overnight since I work graveyards). However, when I use the car after it's been in my garage, I have no issues. Is there more discussion on this?
EDIT: Just read this article on Southcoaste Subaru, they're the closest to me too :/ http://carbuying.jalopnik.com/subaru...ter-1685161385
tracerit is offline   Reply With Quote
Old 02-11-2015, 10:33 PM   #3
ironsurfer129
This actually happen after I drove the car all day long in the middle of the day. Cruising on 15 fwy and needed to downshift because of incline and grinded everytime i downshift from 6th to 5th. I even make sure I step on clutch hard to make sure it is all the way in
Old 02-12-2015, 03:04 AM   #4
Amir Ghadiri
Amir Ghadiri's Avatar
DO NOT go to Quality/Larry H Miller Toyota in Corona. Perhaps try Longo, I've heard good things about them!
Amir Ghadiri is offline   Reply With Quote
Old 02-12-2015, 03:22 AM   #5
SocalMonsta
SocalMonsta's Avatar
Drives: White FRS
I realize my area is way out of your way, but I have had very good service at hollywood toyota. I have not had any major issues, but theyve replaced everything Ive ever complained about.
Also, Santa Monica Toyota is incredibly bad.
SocalMonsta is offline   Reply With Quote
Old 02-12-2015, 03:28 AM   #6
YouShallKnow
Drives: Man
Send a message via ICQ to YouShallKnow Send a message via AIM to YouShallKnow Send a message via Yahoo to YouShallKnow
I've had good luck at DCH Torrance.
YouShallKnow is offline   Reply With Quote
Old 02-12-2015, 05:54 PM   #7
TougeSlug
Drives: 2015 CBS WRX 2014 D4S Mono(R.I.P.)
longo fixed mine. no problems ever since. DO NOT LET THEM WASH IT. YOU WILL GET PAINT SWIRLS
TougeSlug is offline   Reply With Quote
Old 02-12-2015, 08:26 PM   #8
ironsurfer129
You think I'll have problem if I have my shift bushing on?
Old 02-12-2015, 08:28 PM   #9
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
most likely not, but I really wouldn't chance it...Just not worth the massive headache it would cause if a note gets entered in the system or what not
Old 02-12-2015, 08:31 PM   #10
2much
I wanna go fast
Drives: 2013 FR-S 6MT
When someone asks me for a dealership recommendation, I say South Coast Toyota, I have had a very good experience every time I've been.
2much is offline   Reply With Quote
Old 02-12-2015, 09:40 PM   #11
hapa_kcm
hapa_kcm's Avatar
Drives: WRB BRZ Limited
I would go with Longo
hapa_kcm is offline   Reply With Quote
Old 02-12-2015, 10:22 PM   #12
TougeSlug
depends if the shift bushing caused the problem. if not, then you are fine. if so.. prepare to bend over
Old 02-12-2015, 10:48 PM   #13
toby714
Drives: whiteout
i had a bad experience with longo. they over torqued some bolts with accessing my tranny and didnt bolt back my grounding wire
toby714 is offline   Reply With Quote
Old 02-14-2015, 05:55 PM   #14
TougeSlug
did you take it back? give them a chance to fix it? My uncle, who has been a service manage with toyota for 25 years recommended i go to longo to get repairs. hes at a different dealer in socal and doesnt recommend his guys to work on my frs. he says they are too new for the twins and knows how picky (read anal retentive) i am about my car. so do what you will with that.
6MT Transmission Grind -> Warranty Replacement (Subaru) Fred E NY / NJ / CT / PA 7 11-07-2015 12:18 AM
Would dealer warranty this? 4th gear tennisfreak Issues | Warranty | Recalls / TSB 9 12-08-2014 04:13 PM
Transmission warranty. Reaper Engine, Exhaust, Transmission 28 10-10-2014 07:29 PM
Good dealer to go for service/warranty in GTA? shu5892001 CANADA 8 04-18-2013 07:04 AM
2nd Dealer Visit for Warranty Issues Umbie BRZ First-Gen (2012+) — General Topics 12 02-13-2013 06:42 PM
