Old 03-14-2015, 03:52 AM   #1
Hachiroku14
Drives: 2014 BRZ World Rally Blue
VALENTI Tailight fix
this is a reply from this thread...
http://www.ft86club.com/forums/showthread.php?t=41426
OK. I had just had the same 3 leds turn off like the OP posted. And since I am now past warranty I decided to investigate and it seems I found out what is causing this issue. Those without issues might want to take a look at this before your unit fails as well.
PROBLEM:
If you look at the back where all the wires are, you'll notice that those small black connectors are cramped/shoved inside the small hole, exactly where the leds seem to be having problems (hint!). So I believe one of those connectors is constantly hitting the part where the led is soldered on to the board (the affected led is the first led you see when looking directly in the hole) and over time, that solder will eventually come loose and cut the circuit running the other 2 leds.
SOLUTION:
1. FOR THE OTHER PAIR THAT STILL WORKS: I suggest you start getting those black connectors out of that hole ASAP!!! The wires have a bit of a slack to them so you can carefully get all 3 out of 4 connectors out. The one with the BLUE WIRE seems to be short so leave it inside. Now you can tape/clean up those connectors outside the hole and call it a day.
2. Unfortunately for the busted tailight, you may have to open it up. There maybe tutorials on the DIY thread or on youtube on how to open headlights. Same concept applies here. I would suggest the baking-in-the-oven method. As for the soldering part, youtube is also your friend.
UPDATE: If you have steady hands and is good with a soldering iron, the hole is big enough where you can just get away with heating up the connections and getting enough lead in there to attach it back to the board.
GOODLUCK!!!!!!
Hachiroku14 is offline   Reply With Quote
Valenti Japen LED Reverse Tailight USDM Wiring Furtive DIY (Do-It-Yourself) Guides 12 08-21-2015 10:31 AM
WTS: Valenti Red/White Tailight Calbee Exterior Parts (Aero, Lighting, Etc.) 5 04-05-2015 01:51 AM
Toms Tailight help! Ymerej Cosmetic Modification (Interior/Exterior/Lighting) 6 03-18-2014 09:48 PM
BRZ OEM Tailight set for sale. MINT! conekiller Exterior Parts (Aero, Lighting, Etc.) 10 12-01-2013 03:31 AM
Crystal Eye LED tailight mxsled Cosmetic Modification (Interior/Exterior/Lighting) 66 03-30-2013 09:15 PM
