Old 03-21-2015, 01:47 PM   #1
JJJMan75
JJJMan75's Avatar
Drives: 2013 White BRZ Limited
Transmission - (4th) gear grind
(@ 8k miles) I recently noticed that my trans grinds while shifting into 4th gear. When I'm accelerating very gently at low RPMs, it simply makes the clicking noise you hear when shifting out of reverse. However, it definitely grinds whenever I shift quickly or at higher RPMs... Got a friend to drive it, does the same thing to him. Any ideas regarding what this is or what caused it?
JJJMan75 is offline   Reply With Quote
Old 03-21-2015, 01:56 PM   #2
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Common Problem with a million threads started already. Search using google and you will find some of the longer threads.
To sum up = Bad synchros, bring to dealer, fix under warranty
My car goes in Monday for the same problem
GotBRZ1691 is offline   Reply With Quote
Old 03-21-2015, 02:42 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Shit. Yours too? Man, I'm sorry about that.
Old 03-21-2015, 03:36 PM   #4
GotBRZ1691
GotBRZ1691's Avatar
Its been a problem for awhile now. Since about 12,000 miles it was noticeable. Now at 28,000 and its really bad.
6th Gear Grind & Replaced Transmission Bonburner Issues | Warranty | Recalls / TSB 45 07-31-2016 12:08 AM
Grind Into 5th Gear Since885 Engine, Exhaust, Transmission 8 01-18-2015 06:47 PM
transmission grind in 5th gear Rocket.BRZ Issues | Warranty | Recalls / TSB 7 06-30-2014 11:38 PM
transmission grind jbailey8748 Engine, Exhaust, Transmission 26 05-18-2014 10:32 PM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 08:37 PM
