Old 03-22-2015, 11:57 PM   #1
ohnoitsthefuzz
Drives: 2013 Scion FRS 6 Speed Raven Black
Oil leak.
First off, sorry as I wasn't able to provide pictures of the issue.
Today while underneath the car taking care of a sway bar issue, I noticed a small oil leak on the bottom of the valve cover on the drivers side at the front of the engine. It seems to be coming from the sensor that's positioned there which I'm assuming is a cam positioning sensor. Has anyone else encountered this and is it in fact the cam positioning sensor? I was surprised it wasn't the cam seal plate on the passenger side leaking.
ohnoitsthefuzz is offline   Reply With Quote
Old 03-23-2015, 12:50 AM   #2
qwerty66
Drives: frs
I had the same issue with my driver side lower sensor, I've tried replacing the whole sensor with new O-ring under warranty and it still leaked (a little worse). So I sealed the mating surface with loctite silicone, and it has been fine every since (5,000km so far)
qwerty66 is offline   Reply With Quote
Old 03-23-2015, 02:31 AM   #3
ohnoitsthefuzz
Appreciate the feedback. Might have to try the loctite.
Gas Leak? Fuco Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 10-07-2022 10:40 AM
Oil leak after my first oil change.. WTF? jgonx213 Issues | Warranty | Recalls / TSB 16 04-17-2014 05:08 PM
oil leak problem HELP! davebrus Issues | Warranty | Recalls / TSB 18 12-07-2013 06:47 PM
A/T Pan leak goke186 Issues | Warranty | Recalls / TSB 0 04-15-2013 11:31 PM
Exhaust Leak? k33n3r Engine, Exhaust, Transmission 6 08-09-2012 01:59 PM
