Old 03-25-2015, 05:24 AM   #1
steveholt
Drives: 2015 BRZ Limited 6MT
mcgard spline lugs on OEM wheels
Will McGard spline drive lugs fit on OEM wheels?
I want to upgrade from the oem lugs that it came with.
I wasn't able to find anything when I searched, amazon.com reviews says some people were able to use them on their oem sti wrx wheels ok, couldn't find anything on oem fit for brz/frs
steveholt is offline   Reply With Quote
Old 03-25-2015, 03:07 PM   #2
steveholt
Old 03-25-2015, 05:37 PM   #3
Panman
Panman's Avatar
Drives: 86 GTS
Yes, they fit. I have the McGard spline drives.
Panman is offline   Reply With Quote
Old 03-25-2015, 07:17 PM   #4
steveholt
Cool, thanks. Does the mcgard wheel lock also fit on the oem brz wheels too?
I think both the mcgard and oem lugs are 60 degree conical?
Did you have any trouble or minor fitting/threading issues when putting your mcgard spline lugs on your oem wheels? Or were they a perfect fit
Old 03-25-2015, 09:30 PM   #5
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
I put them on with my oem wheels for a few days before I got new wheels installed. I had no issues at all. I opted to go without the locks, but I don't see why they would be an issue. The diameter should be the same.
TheVoiceOfReason is offline   Reply With Quote
Old 03-26-2015, 12:14 AM   #6
ka-t_240
The Mcgard locking nut fits where the others do. I would skip the locking nut to be honest. I had them, and they sucked. They also do not have the 2 piece design as the regulars do(unless the design changed recently).
ka-t_240 is offline   Reply With Quote
Old 03-26-2015, 12:25 AM   #7
Panman
Panman's Avatar
Drives: 86 GTS
No fitting or thread issues, they fit perfectly, I change my wheels for different track events on a weekly basis. The only weak point is the spline drive key, and I ordered a spare one of those in case the original gets broken.
FS: McGard wheel lugs and locks set (black) FRS2000 Wheels and Tires 3 02-03-2015 05:47 PM
SoCal 1 x rpf1 tony Angelo , gold mcgard lugs spline drive with keys SliverBrz Wheels and Tires 8 07-10-2014 05:57 AM
FS: SoCal Enkei RPF1 16x7 +35, Azenis PT722 225/50/16, McGard Lugs/Key, Center Caps vteclol Wheels and Tires 2 12-05-2013 08:18 PM
Looking for Mcgard spline lugs in Canada. OICU812 CANADA 5 04-10-2013 10:14 PM
Stock Wheels and Gorrilla spline Lugs Nuts USMC -FRS Wheels and Tires 3 02-21-2013 02:32 PM
