Drives: 2015 WRB BRZ
Shifter rattles after CF driveshaft install?
I've recently got my DSS CF Driveshaft installed for my 2015 BRZ.
It drives fine at any given speed. However, whenever I go over 4k RPM the shift starts to rattle. There is no vibrations of any sort in this car. I've searched around any found that Shifter rattle is a common issue but my question is: did my driveshaft install cause it or is it a coincidence? Thanks! |
Drives: FRS
Do you have an aftermarket shift lever? Kartboy, etc...?
Drives: Smells like tires when I drive
If it's RPM relative instead of being speed relative it's not the driveshaft. I'd put the car up in the air again and check for anything loose.
Turning is for Nerds
Drives: 35 characters is not enough
Even if you don't have an aftermarket shift lever, go under the car and check clearence from your driveshaft to your shift linkage.
#5 | |
Drives: PEARL WHITE GT86 TRD
I had a similar rattle, and I found out that it is the pin holding the gear lever to the shift arm that causes this rattle. Have a look here: http://www.ft86club.com/forums/showt...=58951&page=19 and http://www.ft86club.com/forums/showt...t=13664&page=5 Good luck |
Drives: 2012 Toyota 86
i had a similar rattle that would happen at 4-6k on partial throttle and it ended up being my exhaust hitting my chassis, and the vibration working its way through where the front pipe bolts to the transmission for support.
| DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft | F1point4 | DIY (Do-It-Yourself) Guides | 67 | 04-17-2021 06:21 PM |
| kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 02:41 AM |
| New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft | Evasive Motorsports | Engine, Exhaust, Transmission | 1 | 09-24-2013 03:27 PM |
| Shifter bushing install | Bullnettles | Engine, Exhaust, Transmission | 4 | 06-20-2013 05:36 PM |
