Old 04-10-2015, 09:10 PM   #1
Flat_4_Life
Flat_4_Life's Avatar
Drives: 2015 SBD Turbo Halo FRS
Exclamation Exhaust silencer
So this is going to sound really dumb. As I said in another post I have removed my resonater and muffler and I love it! I want to get a UEL header soon so my car will be even louder and I'm ok with that. The problem that I'll have and want a solution for is I don't want to be a **** at 5 in the morning by waking my neighbours up so I want to find a way to silence the car only during the morning cold start. Don't give me dumb sarcastic answers like "get a muffler" or "can't have your cake and eat it to".
Flat_4_Life is offline   Reply With Quote
Old 04-10-2015, 09:15 PM   #2
swarb
what exhaust do you have? many have silencers for sale. pics?
A tune like oft can remove the negative timing that makes the cold start so loud. You can also lower the rpm too.
or just buy one from ebay.
Old 04-10-2015, 09:21 PM   #3
YMAA
Maximum puntential
YMAA's Avatar
Drives: 2013 DGM BRZ 6MT LTD
Then don't ask dumb questions about how you can have your cake and eat it too.
Perrin CAI + intake tube || Tomei UEL || OFT Stage 2 tune
YMAA is offline   Reply With Quote
Old 04-10-2015, 09:37 PM   #4
Flat_4_Life
How did I ask a dumb question?
Old 04-10-2015, 09:37 PM   #5
Flat_4_Life
It's a custom exhaust
Old 04-10-2015, 09:38 PM   #6
steve99
you can make some tuning changes to reduce cold start volume
It only does this for emmissions purposes and to heat up cats.
Three things happen Idle is increased to 1700rpm
Additional Fuel is added by offsetting MAF scale during warm-up
Ignition Timing is retarded by 15 degrees during warm-up
The retarded timing is what makes most of the additional noise.
You may get CEL code P050B if so just disable it its due to ecu monitoring post start ignition timing.
To fix alter the “Ignition Timing Post Start” table under “Ignition Timing- Advance” folder .
Change all cells from -15 to -4 degrees and most of the noisy “bark” should be gone.
.This image has been resized. Click this bar to view the full image. The original image is sized 1600x900.This image has been resized. Click this bar to view the full image. The original image is sized 1600x900.This image has been resized. Click this bar to view the full image. The original image is sized 1600x900.
You can also reduce the “Idle control” “Idle control Target A” through to “Idle control Target E” tables reduce the values for idle that are over 1200 rpm to 1200 rpm.
The MAF adjustments can also be scaled back but those tables not in OFT definitions yet
Also in USA roms set CEL code P050B to disable else you will get a cel code for "post start inginition timing"
Old 04-10-2015, 09:41 PM   #7
fast_dude
Drives: 2014 Scion FRS
Add one or two resonators.
2014 Scion FRS- Kw2 suspension, Openflash headers, Openflash tablet, Invidia N1 exhaust, Invidia Overpipe, Nameless catted front pipe, TRD intake, Enkei RPF1s with Hankook RS3 tires, carbon fibre front lip, TRD knockoff spolier, SPC lower control arms.
fast_dude is offline   Reply With Quote
Old 04-10-2015, 09:43 PM   #8
swarb
pics? or what tips/muff do you have? maybe a ebay silencer can fit. But realistically, if you remove cats/mufflers, its going to be loud. If there was a way to minimize sound levels without mufflers, the factory would have though of it, as it would save lots of weight and money.
Old 04-10-2015, 09:49 PM   #9
Flat_4_Life
I would try this but I think I would screw up lol
Old 04-10-2015, 09:52 PM   #10
Flat_4_Life
My tips are 4" and I'm not looking for anything pertinent I'm just looking to have something to slip into the exhaust in the morning to make it sound almost stock and take it out when I'm out of the drive way
Old 04-10-2015, 09:55 PM   #11
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
I would put the stock catback on, but have an electronic exhaust cutout welded in before the resonator in the midpipe. Close it for the cold start, and open it up when you leave the neighborhood. You'll have quiet and loud on command.
Freeman is offline   Reply With Quote
Old 04-10-2015, 09:55 PM   #12
swarb
ebay all day. You don't need to drill a hole, just find one with two holes and put the screw on the inside to wedge/hold it on until you reach the end of the street. I have seen silencers fly! off though. Be careful.
Old 04-10-2015, 10:07 PM   #13
Flat_4_Life
I was thinking something similar only concern is weight
Old 04-10-2015, 10:58 PM   #14
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
Roll out in neutral without gas as soon as you turn on the car. The RPM will drop from cold right away...
fantah is offline   Reply With Quote
WTB: silencer for Tomei 60S NLSP Want-To-Buy Requests 1 05-07-2015 11:55 PM
Tomei 80 Silencer JimmyMac Engine, Exhaust, Transmission 1 02-24-2015 01:47 AM
Invidia N1 Exhaust Silencer vs. No Silencer Comparison Teeeg28 Engine, Exhaust, Transmission 3 06-20-2014 02:04 PM
Invidia N1 Exhaust Silencer vs. No Silencer Comparison Teeeg28 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 06-19-2014 06:46 PM
exhaust silencer Im_SPEED Engine, Exhaust, Transmission 9 03-29-2014 10:12 PM
