Old 04-16-2015, 03:58 PM   #1
retrosmiths
Drives: Scion FR-S Whiteout
Faint, high-pitched whistling sound
Anyone else having this issue?
  • Usually happens when the engine is warm
  • Gets a bit louder/higher-pitched on higher RPMs
  • (NOT!) Cannot reproduce if the car is parked and I rev
  • Sounds something like a tea kettle noise
  • Stock exhaust pipes, stock intake system except for K&N drop-in filter
  • I triple-checked the filter to make sure it sits properly and that the box closes fully
  • I also plugged the pipe that leads from the intake to the cabin, and it didn't help
  • No matching symptoms with an intake/exhaust leak
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 04-16-2015, 04:01 PM   #2
You nailed everything I thought of at first.
Vacuum leak someplace?
Old 04-16-2015, 04:39 PM   #3
retrosmiths
If there is one, it would affect my MPG somewhat, and I'm still in the 23-26 range. Exhaust still sounds normal.
2013 Scion FR-S
Old 04-16-2015, 04:43 PM   #4
If it was bad enough that it effected your mileage you would throw a CEL.
Have had that sort of sound you described from collapsed vacuum lines or very small holes that didn't impact the actual system before in other cars. They are an absolute bitch to track down!
Old 04-16-2015, 05:27 PM   #5
retrosmiths
http://www.ft86club.com/forums/showt...light=vac+leak
This hose is still attached properly, as far as I can see.
2013 Scion FR-S
Old 04-16-2015, 05:39 PM   #6
White64Goat
I'm assuming that this occurs while driving?
Old 04-16-2015, 05:45 PM   #7
retrosmiths
Yes.
2013 Scion FR-S
Old 04-16-2015, 05:51 PM   #8
White64Goat
Chance that is a wind noise through the grill or from around a headlight or turn signal?
Old 04-16-2015, 05:52 PM   #9
retrosmiths
That matches the RPM?
2013 Scion FR-S
Old 04-16-2015, 05:56 PM   #10
White64Goat
So you're only hearing it at a specific RPM range in each gear and not once you reach a certain speed?
Old 04-16-2015, 05:59 PM   #11
retrosmiths
Nope, across all range regardless of speed, but the car has to be moving, which is so weird. It gets subtly louder with increasing RPM.
2013 Scion FR-S
Old 04-16-2015, 06:05 PM   #12
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
get up to speed and throw the car in neutral? Just to make sure its not a wind noise from airflow
determines if its from the engine, or car
Old 04-16-2015, 06:07 PM   #13
White64Goat
That would tend to eliminate the throw-out bearing (if it's a manual trans.) Since you only hear it while moving my next thought would be a dust shield rubbing on a brake rotor.
What Shutter said ...........
Old 04-16-2015, 06:17 PM   #14
retrosmiths
Alright, let me try this later on the way home. Good call.
2013 Scion FR-S
Faint Honking sound Raven604 Issues | Warranty | Recalls / TSB 117 07-14-2023 06:04 AM
Whistling sound..? tintumz22 Issues | Warranty | Recalls / TSB 34 11-21-2015 09:54 PM
not very loud, but high pitched sound at 70+mph fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 16 10-16-2013 11:30 PM
High pitched whine from sound tube and idle jumping Nourdmrolnmt1 Issues | Warranty | Recalls / TSB 0 04-18-2013 12:00 AM
TSB - FRS (re: High pitched chirping...) PNW FRS Issues | Warranty | Recalls / TSB 1 01-19-2013 02:05 AM
