Old 04-20-2015, 09:55 PM   #1
Flat_4_Life
Flat_4_Life's Avatar
Drives: 2015 SBD Turbo Halo FRS
Exclamation OFT STAGE 1 running rich?
hey guys,
ive had my FRS tuned with a OFT Stage 1 91oct (OTS) for about 2 months now. i haven't had any problems with the tune so far and i have always filled up with shell 91oct since the day i got the car. for the past two weeks i have found a rpm range where i can make the exhaust slightly pop (I LOVE IT!). but every day now it smells like my car is running rich and even with normal driving i can sometimes smell it. i know its not really much of a problem as it shouldn't harm anything im just wondering what's with the sudden change?
Flat_4_Life is offline   Reply With Quote
Old 04-20-2015, 11:13 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by Flat_4_Life View Post
hey guys,
Your best bet would be to use the OFT to take a log of normal driving and a 3rd gear WOT pull from low rpm to redline. At a minimum make sure AFR, Command AFR, LTFT and STFT are all logged. Upload the log to Datazap and post the link here. You will get some good feedback from the many knowledgable people here.
1974 TA22 Celica
2013 86 GT
Old 04-20-2015, 11:27 PM   #3
steve99
hey guys,
Did you make any mods to tune ie the exhaust pop/backfire mods ?
If you did it likely those mods causing issue as the pops ect are due to unburnt fuel igniting in exhaust, if it does not ignight then its going to just be unburnt fuel hence "rich" smell.
also do as per previous post if you have not modded tune
Old 04-21-2015, 07:27 PM   #4
Flat_4_Life
Thanks I'll give it a shot
Old 04-21-2015, 07:28 PM   #5
Flat_4_Life
I haven't changed any mods since I got the tune
Fiebruz BPB installed: Running rich? BRAWL Engine, Exhaust, Transmission 6 12-09-2014 09:55 PM
Anyone running FBM Stage 2 Heads? pleong Forced Induction 3 12-09-2014 10:14 AM
Cel gas running to rich anthonyravenfrs Scion FR-S / Toyota 86 GT86 General Forum 3 07-15-2014 02:55 AM
Running rich KslayFRZ Issues | Warranty | Recalls / TSB 15 10-26-2013 12:42 AM
running rich/stumbling Boostedpro Issues | Warranty | Recalls / TSB 1 01-28-2013 03:19 PM
