Drives: 13' Scion FRS Track car
track driven car - Engine noise - click on driver side - vid
hello guys,
today I am taking the car out of storage and I hear a noise I dont' think is normal: check the video : [ame="https://www.youtube.com/watch?v=cbo32cveuTU"]scion frs engine start - then clicking after a 45 seconds - YouTube[/ame] at 50 seconds, you will see a new clicking is coming up much louder than the usual idle. the engine is warm. Every time I restart the engine I get the normal idle noise, then a few seconds later, that louder clicking comes on... I assume it is not normal ? looking at this I also see the tension pulley really is far from steady, is that norma behavior ? thanks for your help Phil.
2013 Scion Frs Track Car - Sold.
I am not a mechanic, I just tinker a bunch and most of it is on other vehicles. That said:
I don't think the tensioner should be bouncing like that; at 600 RPM you are talking about five detonations per second per cylinder which is quite close to what the video looks like. Given that I would suspect that you might have a weak cylinder. A load test might be in order, though I don't know how exactly to do that on one of our cars. A compression test might also be useful, but given where the spark plugs are that would probably be really hard. The strange thing about suspecting a weak cylinder in this case is that we should be seeing a CEL about a cylinder miss firing so iono. In terms of the noise, I suspect it could be the high pressure fuel pump. This could be the engine switching from port injection to direct injection after its initial self checkout. Best thing to do would be to use a mechanic's stethoscope and figure out more precisely where the noise is coming from. The question then becomes, why is the pump making that noise and I don't have any idea unless it is related to the bouncing tensioner.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
| Clicking noise in wheel area, driver side | Rabbit of Caerbonnog | Issues | Warranty | Recalls / TSB | 19 | 02-18-2015 02:59 PM |
| Strange pulsating noise driver side footwell | TennisHsu | Issues | Warranty | Recalls / TSB | 11 | 09-08-2014 12:59 PM |
| Rear driver side clank and click | spyingwind | Issues | Warranty | Recalls / TSB | 11 | 04-05-2014 12:26 AM |
| Creaking/Clinking Noise from Driver Side | Touge86 | Issues | Warranty | Recalls / TSB | 17 | 08-17-2013 09:20 PM |
