Drives: 2014 BRZ Limited 6M
Clutch Spring Removal & Throwout Bearing
I was wondering if those that had removed their clutch helper spring experienced problems with their clutch. About a month after the removal of the spring, I started encountering loud squeaking noises as I depress my clutch, but it would only last for the first 10 minutes.
I brought it in to the dealer to see what was the issue and it turns out that my throw out bearing was wearing grooves into the pressure plate (clutch was completely fine). They informed me that it was not a defect, but rather driving habits. However, I am doubtful that it was solely my fault as the car has only 12,000 miles on it! I always rest my foot on the dead pedal to prevent any pressure on the clutch. If there was any unecessary wear, it would just be the occasional hiccups from daily driving. Would the removal of the clutch helper spring actually cause the throw out bearing to come into contact with the pressure plate even when there is no pressure exerted on the clutch pedal? From what I've gather, the answer is no; however, I've stumbled acrossed a thread on the Z06 forum about the rumor of GM dealerships checking for spring removal on Corvettes with tranny issues. My only assumption of why this could be a possible issue is if the spring pushes the clutch pedal up at rest, but to my knowledge, the helper spring only assists with the actual stiffness of the clutch. Let me know what you guys think. |
Drives: 13 GBS BRZ
I'm calling bullshit on it being driving habits. My car started making a noise at 27k miles. The clutch assembly was replaced under warranty.
Look at this thread. http://www.ft86club.com/forums/showthread.php?t=56882 |
Drives: old
My clutch squeaked, the pivot ball for the throwout lever needed to be greased.
| Tags |
| bearings, clutch, noise, spring, throwout |
| Clutch return spring removal | MikeyBRZ | Engine, Exhaust, Transmission | 186 | 09-16-2020 01:40 PM |
| How To: Clutch Spring Removal in 15 Minutes | eric6 | DIY (Do-It-Yourself) Guides | 165 | 02-15-2017 12:44 AM |
| Clutch Release Bearing Melted | Haulin | Engine, Exhaust, Transmission | 37 | 05-29-2016 07:35 PM |
| bearing clutch burnt out . clutch squeals | aagun | Issues | Warranty | Recalls / TSB | 18 | 07-21-2014 12:40 PM |
| FS: NJ O.E.M. Clutch, flywheel, throw out bearing | Michaeljp92 | Transmission and Driveline | 9 | 02-04-2014 12:42 AM |
