Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 05-24-2015, 01:23 PM   #1
Vic_RSA
The voice of reason...
Vic_RSA's Avatar
Drives: 2012 Toyota 86 6MT Standard
Unhappy Seat Rails: My seat will no longer slide forward or backwards?
A few weeks back I was vacuuming my car (yes @sav ) and noticed that the driver seat would not move forward or backwards. I've spoken to a few people who say this was a Scooby issue at one stage.
Has anyone else locally or in the rest of the world had this issue?
As my car is under warranty I made an active decision not to attempt to troubleshoot... Due for service in about a month or so, will pass the buck on this one unless I hear of an easy fix?
Thanks in advance!
Vic_RSA is offline   Reply With Quote
Old 05-25-2015, 08:29 AM   #2
Alang
Alang's Avatar
Drives: 2013 Toyota 86 2.0 Std.
Pull up the lever under the form of the seat and then slide it.
They are designed to stay in one place because it could be dangerous if they slide around.
You're welcome!
Adding power makes you faster on the straights, subtracting weight makes you faster everywhere - Colin Chapman
Alang is offline   Reply With Quote
Old 05-25-2015, 08:37 AM   #3
Vic_RSA
Vic_RSA's Avatar
Mine used to be like that... My security system against tall people...
Old 05-25-2015, 12:36 PM   #4
Laser69
Laser69's Avatar
Drives: White Ltd Edition
My passenger seat did the same a couple of weeks ago. It was like it did not engage the rail lock correctly. I rocked it back an forth (With Force)and it engaged the lock and has worked perfectly since then.
Laser69 is offline   Reply With Quote
Passenger side seat not staying forward. merlin2111 Issues | Warranty | Recalls / TSB 4 08-06-2013 12:44 AM
Seat Rails/Sliders TouchMyHonda Cosmetic Modification (Interior/Exterior/Lighting) 1 07-29-2013 05:47 AM
Another seat rail option! Nagisa Auto Seat Rails vividracing Cosmetic Modification (Interior/Exterior/Lighting) 11 02-28-2013 05:15 PM
Seat rails diss7 Cosmetic Modification (Interior/Exterior/Lighting) 1 02-22-2013 06:03 AM
Seat rails... poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 10 12-17-2011 09:47 AM
