Old 06-13-2015, 11:21 PM   #1
ChandlerSwyng
ChandlerSwyng's Avatar
Drives: 2013 Red Subaru Brz
Clutch done at 37k?
drove two hours today to flagstaff in Arizona from phoenix, as it rained towards the end of the drive I went over a few puddles and pretty heavy rain. When I got into town ten minutes later I could smell a very strange scent like rain mixed with clutch. Then as I started going through gears the clutch started to not grab and I had to engage it longer than normal. I pulled over popped the hood and there was some faint steam and smoke. Had it towed to nearest Subie dealer for now, but will not know what's wrong until Monday. Anyone have an idea? I can't imagine the clutch going out so early but I fear that is the problem. Thanks.
Old 06-14-2015, 04:42 AM   #2
humfrz
hmmm.......sorry to read your day got wrecked up ......
Well, I suppose that it's possible some water got on the clutch disk and caused to slip. Not likely though.
Are you "hard on" the clutch .... ??
Steam from under the hood after going through high water could be just that hot stuff got wet and is drying off.
Maybe IF the clutch disk got wet, it may have smoked itself a bit trying to dry off ....
I reckon the dealer will sort it out.
Please keep us posted.
humfrz
Old 06-14-2015, 05:10 AM   #3
YMAA
Maximum puntential
YMAA's Avatar
Drives: 2013 DGM BRZ 6MT LTD
Typically one of three things will cause the clutch to fail prematurely:
1) Aggressive, hard driving
2) Inexperience leading to excessive slipping of the clutch
3) Manufacturer's defect
Only you'll know best which of the three is most likely in your situation. I will say that while many believe that because this is a sports car it is intended to be driven like a sports car (and I'm one of them), when it comes to warranty claims Subaru is known to use that stereotype to deny warranty claims citing aggressive driving as the reason. Take from that what you will.
Hopefully it's the manufacturer's defect as the first two possibilities will be tough to convince the dealer or SOA to warranty. Best of luck and I hope your car is road-ready quickly and cheaply!
Perrin CAI + intake tube || Tomei UEL || OFT Stage 2 tune
YMAA is offline   Reply With Quote
Old 06-14-2015, 04:32 PM   #4
ChandlerSwyng
Thanks for the replies, I tend to drive this car pretty normally except every once in a while when I have a little fun. My mom drove the car all last year, but she has had a lot of experience with manual. Hopefully it's a defect
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 01:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 01:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 04:48 PM
