Old 06-24-2015, 04:51 AM   #1
Kodename47
Kodename47's Avatar
Drives: UK GT86
ROM Table Discovery & Definitions
Seeing as there isn't a specific thread for this I thought I'd start one rather than tagging it in the middle of the Tactrix threads.
I decided to try WinOLS with some success, however I was wondering if those with IDA could look through and determine if these tables are of any use and what they do.
It seems that WinOLS is fairly good at determining the actual tables and has a go at formulating the expressions, as well as allowing you to view them in a table or 3D format you would be familiar with.
Below are the 10 largest tables that are not yet defined, on my definition at least, for ZA1JA02G. I haven't looked at the A01G but so far the 2 are the same.
@Td-d
@ztan
I'll post the same over on Romraider to see if they can be of any assistance.
Addresses:
Code:
<table name="Alpha 1" storageaddress="1070B8">
      	<table type="X Axis" storageaddress="106FF0" />
      	<table type="Y Axis" storageaddress="10703C" />
     	</table>
<table name="Alpha 2" storageaddress="102518">
      	<table type="X Axis" storageaddress="102458" />
      	<table type="Y Axis" storageaddress="1024B4" />
     	</table>
<table name="Alpha 3" storageaddress="100948">
      	<table type="X Axis" storageaddress="1008A8" />
      	<table type="Y Axis" storageaddress="1008D4" />
     	</table>
<table name="Alpha 4" storageaddress="100644">
      	<table type="X Axis" storageaddress="1005B8" />
      	<table type="Y Axis" storageaddress="100600" />
     	</table>
<table name="Alpha 5" storageaddress="11AC4C">
      	<table type="X Axis" storageaddress="11ABC8" />
      	<table type="Y Axis" storageaddress="11AC08" />
     	</table>
<table name="Alpha 6" storageaddress="10B488">
      	<table type="X Axis" storageaddress="108E48" />
      	<table type="Y Axis" storageaddress="109018" />
     	</table>
<table name="Alpha 7" storageaddress="10B274">
     	</table>
<table name="Alpha 8" storageaddress="10AFE8">
     	</table>
<table name="Alpha 9" storageaddress="10AD2C">
     	</table>
<table name="Alpha 10" storageaddress="10AA70">
     	</table>
Table Data:
Code:
<table type="3D" name="Alpha 1" category="Alpha" storagetype="uint8" endian="big" sizex="19" sizey="31" userlevel="3">
      <scaling units="Unknown" expression="x*0.392157" to_byte="x/0.392157" format="0.00" fineincrement=".01" coarseincrement=".1" />
      <table type="Y Axis" name="Throttle Position" storagetype="float" endian="little" logparam="E52">
        <scaling units="Degrees" expression="x" to_byte="x" format="#" fineincrement=".001" coarseincrement="0.01" />
      </table>
      <table type="X Axis" name="Engine Speed" storagetype="float" endian="little" logparam="P8">
        <scaling units="RPM" expression="x" to_byte="x" format="#" fineincrement="50" coarseincrement="100" />
      </table>
          </table>
<table type="3D" name="Alpha 2" category="Alpha" storagetype="uint16" endian="big" sizex="23" sizey="25" userlevel="3">
      <scaling units="Unknown" expression="x*0.009321" to_byte="x/0.009321" format="0.0" fineincrement=".01" coarseincrement=".1" />
      <table type="Y Axis" name="Unknown" storagetype="float" endian="little" >
        <scaling units="Unknown" expression="x" to_byte="x" format="0.0" fineincrement=".001" coarseincrement="0.01" />
      </table>
      <table type="X Axis" name="Engine Speed" storagetype="float" endian="little" >
        <scaling units="RPM" expression="x" to_byte="x" format="0" fineincrement="50" coarseincrement="100" />
      </table>
          </table>
<table type="3D" name="Alpha 3" category="Alpha" storagetype="uint16" endian="big" sizex="11" sizey="29" userlevel="3">
      <scaling units="Unknown" expression="x*0.0125" to_byte="x/0.0125" format="0" fineincrement=".01" coarseincrement=".1" />
      <table type="X Axis" name="Unknown" storagetype="float" endian="little" logparam="E52">
        <scaling units="Unknown" expression="x" to_byte="x" format="0" fineincrement=".001" coarseincrement="0.01" />
      </table>
      <table type="Y Axis" name="Engine Speed" storagetype="float" endian="little" logparam="P8">
      </table>
          </table>
<table type="3D" name="Alpha 4" category="Alpha" storagetype="uint16" endian="big" sizex="18" sizey="17" userlevel="3">
      <scaling units="Unknown" expression="x*0.012089" to_byte="x/0.012089" format="0" fineincrement=".01" coarseincrement=".1" />
      </table>
      <table type="Y Axis" name="Unknown" storagetype="float" endian="little" logparam="P8">
        <scaling units="Unknown" expression="x" to_byte="x" format="0" fineincrement="50" coarseincrement="100" />
      </table>
          </table>
<table type="3D" name="Alpha 5" category="Alpha" storagetype="uint16" endian="big" sizex="16" sizey="17" userlevel="3">
      <scaling units="Unknown" expression="x*0.001907" to_byte="x/0.001907" format="0.0" fineincrement=".01" coarseincrement=".1" />
      <table type="Y Axis" name="Unknown" storagetype="float" endian="little" logparam="E52">
      </table>
      </table>
          </table>
<table type="3D" name="Alpha 6" category="Alpha" storagetype="uint16" endian="big" sizex="14" sizey="19" userlevel="3">
      <scaling units="Unknown" expression="x*0.003053" to_byte="x/0.003053" format="0.0" fineincrement=".01" coarseincrement=".1" />
      <table type="X Axis" name="Load" storagetype="float" endian="little" logparam="E52">
        <scaling units="g/rev" expression="x" to_byte="x" format="0.00" fineincrement=".001" coarseincrement="0.01" />
      </table>
      </table>
          </table>
<table type="3D" name="Alpha 7" category="Alpha" storagetype="uint16" endian="big" sizex="14" sizey="19" userlevel="3">
      </table>
      </table>
          </table>
<table type="3D" name="Alpha 8" category="Alpha" storagetype="uint16" endian="big" sizex="14" sizey="19" userlevel="3">
      <scaling units="Unknown" expression="x*0.12207" to_byte="x/0.12207" format="0.0" fineincrement=".01" coarseincrement=".1" />
      </table>
      </table>
          </table>
<table type="3D" name="Alpha 9" category="Alpha" storagetype="uint16" endian="big" sizex="14" sizey="19" userlevel="3">
      </table>
      </table>
          </table>
<table type="3D" name="Alpha 10" category="Alpha" storagetype="uint16" endian="big" sizex="14" sizey="19" userlevel="3">
      </table>
      </table>
          </table>
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-24-2015, 07:07 AM   #2
ztan
Drives: Toyota 86
I'll have a look in IDA.
Last tried to use WinOLS in 2006...
ztan is offline   Reply With Quote
Old 06-24-2015, 09:35 AM   #3
ztan
Drives: Toyota 86
Unpicking "Alpha 1":
From addresses given:
Code:
ROM:00106FF0 flt_106FF0:     .float 800.0, 1200.0, 1600.0, 2000.0, 2400.0, 2800.0, 3200.0, 3600.0, 4000.0, 4400.0
ROM:00106FF0                                         ; DATA XREF: ROM:000B2EF8o
ROM:00106FF0                 .float 4800.0, 5200.0, 5600.0, 6000.0, 6400.0, 6800.0, 7000.0, 7200.0, 7400.0
ROM:0010703C flt_10703C:     .float 8.0, 10.0, 12.0, 14.0, 16.0, 18.0, 20.0, 22.0, 24.0, 26.0
ROM:0010703C                                         ; DATA XREF: ROM:000B2EFCo
ROM:0010703C                 .float 28.0, 30.0, 32.0, 34.0, 36.0, 38.0, 40.0, 42.0, 44.0, 46.0
ROM:0010703C                 .float 48.0, 50.0, 52.0, 54.0, 57.0, 60.0, 65.0, 70.0, 75.0, 80.0
ROM:0010703C                 .float 85.0
ROM:001070B8 byte_1070B8:    .datab.b h'13, h'FF     ; DATA XREF: ROM:000B2F00o
ROM:001070B8                 .data.b h'B9
ROM:001070B8                 .datab.b h'12, h'FF
ROM:001070B8                 .data.b h'7F, h'DF
.....592 values
Following the xref from the x-axis (RPM) to B2EF8:
Code:
ROM:000B2EF4 stru_B2EF4:     Table_type <h'13, 0, h'1F> ; DATA XREF: sub_4FFD2+1Co
ROM:000B2EF4                                         ; ROM:off_500C4o
ROM:000B2EF8                 .data.l flt_106FF0  ;x-axis
ROM:000B2EFC                 .data.l flt_10703C  ; y-axis
ROM:000B2F00                 .data.l byte_1070B8  ;data
ROM:000B2F04                 .data.w h'400  ;data length (byte)
ROM:000B2F06                 .data.w 0
ROM:000B2F08                 .float 0.39215687 ;data scalar
ROM:000B2F0C                 .float 0.0  ;data offset
Following the xref from the table definition to 4FFD2:
Code:
ROM:0004FFD2 sub_4FFD2:                              ; CODE XREF: sub_4FEBE+Ep
ROM:0004FFD2                 movmu.l r14, @-r15      ; Move Multi-register Upper part
ROM:0004FFD4                 fmov.s  fr14, @-r15     ; Floating-point move single precision
ROM:0004FFD6                 fmov.s  fr15, @-r15     ; Floating-point move single precision
ROM:0004FFD8                 stc.l   gbr, @-r15      ; Store Control Register Long
ROM:0004FFDA                 movi20  #dword_FFF89B8C, r0 ; 20-bit immediate data transfer
ROM:0004FFDE                 ldc     r0, gbr         ; Load to Control Register
ROM:0004FFE0                 mov.l   #RAM_RPM, r2    ; Move Immediate Long Data
ROM:0004FFE2                 fmov.s  @R2, fr14       ; Floating-point move single precision
ROM:0004FFE4                 mov.l   #RAM_Throttle, r2 ; Move Immediate Long Data
ROM:0004FFE6                 fmov.s  @R2, fr15       ; Floating-point move single precision
ROM:0004FFE8                 mov.l   #sub_53FA0, r2  ; Move Immediate Long Data
ROM:0004FFEA                 jsr/n   @R2 ; sub_53FA0 ; Jump to Subroutine with No delay slot
ROM:0004FFEC                 extu.b  r0, r14         ; Extend as Unsigned (Byte)
ROM:0004FFEE                 mov.l   #stru_B2EF4, r4 ; Move Immediate Long Data
ROM:0004FFF0                 movi20  #Pull3D, r2     ; 20-bit immediate data transfer
ROM:0004FFF4                 fmov    fr14, fr4       ; Floating-point move
ROM:0004FFF6                 jsr     @R2 ; Pull3D    ; Jump to Subroutine
ROM:0004FFF8                 fmov    fr15, fr5       ; Floating-point move
ROM:0004FFFA                 movi20  #dword_FFF89B8C, r6 ; 20-bit immediate data transfer
ROM:0004FFFE                 fmov.s  fr0, @r6        ; Floating-point move single precision
We find the x-axis is RPM, y-axis is Throttle, value pulled from the table is stored in FFF89B8C (I don't know what this is yet).
Old 06-24-2015, 01:30 PM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
*Thanks, I've updated the code. I figured it would be something like that as the table looks like this:
Seems to have higher numbers in the lower torque areas.
As more are found I'll update the 1st post.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-24-2015, 09:25 PM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Some more
Addresses:
Code:
<table name="Alpha 11" storageaddress="103310">
      	<table type="X Axis" storageaddress="1032D0" />
      	<table type="Y Axis" storageaddress="1032F4" />
     	</table>
<table name="Alpha 12" storageaddress="103498">
      	<table type="X Axis" storageaddress="103470" />
      	<table type="Y Axis" storageaddress="103484" />
     	</table>
    <table name="Alpha 13" storageaddress="104634">
      <table type="Y Axis" storageaddress="1045E8" />
    </table>
    <table name="Alpha 14" storageaddress="104B70">
      <table type="Y Axis" storageaddress="104AA8" />
    </table>
    <table name="Alpha 15" storageaddress="104D28">
      <table type="Y Axis" storageaddress="104CC0" />
    </table>
<table name="Alpha 16" storageaddress="1138A4">
      	<table type="X Axis" storageaddress="113854" />
      	<table type="Y Axis" storageaddress="113880" />
     	</table>
<table name="Alpha 17" storageaddress="1139BC">
      	<table type="X Axis" storageaddress="11396C" />
      	<table type="Y Axis" storageaddress="113998" />
     	</table>
<table name="Alpha 18" storageaddress="113E74">
      	<table type="X Axis" storageaddress="113E24" />
      	<table type="Y Axis" storageaddress="113E54" />
     	</table>
<table name="Alpha 19" storageaddress="13D52C">
      	<table type="X Axis" storageaddress="13D4B8" />
      	<table type="Y Axis" storageaddress="13D4F8" />
     	</table>
<table name="Alpha 20" storageaddress="11BCBC">
      	<table type="X Axis" storageaddress="11BC3C" />
      	<table type="Y Axis" storageaddress="11BC78" />
     	</table>
Data:
Code:
<table type="3D" name="Alpha 11" category="Alpha" storagetype="uint16" endian="big" sizex="9" sizey="7" userlevel="3">
      <scaling units="Unknown" expression="x*0.002929" to_byte="x/0.002929" format="0.0" fineincrement=".01" coarseincrement=".1" />
        <scaling units="Unknown" expression="x" to_byte="x" format="0.00" fineincrement=".001" coarseincrement="0.01" />
      </table>
      </table>
          </table>
<table type="3D" name="Alpha 12" category="Alpha" storagetype="uint16" endian="big" sizex="5" sizey="5" userlevel="3">
      <scaling units="Unknown" expression="x" to_byte="x" format="0.0" fineincrement=".01" coarseincrement=".1" />
      <table type="X Axis" name="Unknown" storagetype="float" endian="little">
      </table>
      </table>
          </table>
<table type="2D" name="Alpha 13" category="Alpha" storagetype="uint16" endian="big" sizey="19" userlevel="3">
      </table>
          </table>
<table type="2D" name="Alpha 14" category="Alpha" storagetype="float" endian="big" sizey="50" userlevel="3">
      <scaling units="Unknown" expression="x" to_byte="x" format="0.00" fineincrement=".01" coarseincrement=".1" />
        <scaling units="Unknown" expression="x" to_byte="x" format="0.0" fineincrement="50" coarseincrement="100" />
      </table>
          </table>
<table type="2D" name="Alpha 15" category="Alpha" storagetype="float" endian="big" sizey="26" userlevel="3">
        <scaling units="Unknown" expression="x" to_byte="x" format="0.00" fineincrement="50" coarseincrement="100" />
      </table>
          </table>
<table type="3D" name="Alpha 16" category="Alpha" storagetype="uint16" endian="big" sizex="11" sizey="9" userlevel="3">
      </table>
      <table type="Y Axis" name="Engine Speed" storagetype="float" endian="little" >
      </table>
          </table>
<table type="3D" name="Alpha 17" category="Alpha" storagetype="uint16" endian="big" sizex="11" sizey="9" userlevel="3">
      </table>
      </table>
          </table>
<table type="3D" name="Alpha 18" category="Alpha" storagetype="uint16" endian="big" sizex="12" sizey="8" userlevel="3">
      <table type="X Axis" name="Load" storagetype="float" endian="little">
      </table>
      </table>
          </table>
<table type="3D" name="Alpha 19" category="Alpha" storagetype="float" endian="big" sizex="16" sizey="13" userlevel="3">
      </table>
      </table>
          </table>
<table type="3D" name="Alpha 20" category="Alpha" storagetype="uint16" endian="big" sizex="15" sizey="7" userlevel="3">
        <scaling units="Degrees?" expression="x" to_byte="x" format="0" fineincrement=".001" coarseincrement="0.01" />
      </table>
        <scaling units="Degrees?" expression="x" to_byte="x" format="0" fineincrement="50" coarseincrement="100" />
      </table>
          </table>
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-27-2015, 05:46 AM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
Rather than just picking random tables I have been overlooking the entire ROM, I found these 4 2D tables all in the same portion of the hex dump. They seem to correspond to RPM so I wonder if these are cylinder comp tables of some sort. When viewed as a chart they vary quite a bit.
Code:
    <table name="Alpha 21" storageaddress="11E61C">
      <table type="Y Axis" storageaddress="11E5E0" />
    </table>
    <table name="Alpha 22" storageaddress="11E694">
      <table type="Y Axis" storageaddress="11E658" />
    </table>
    <table name="Alpha 23" storageaddress="11E70C">
      <table type="Y Axis" storageaddress="11E6D0" />
    </table>
    <table name="Alpha 24" storageaddress="11E784">
      <table type="Y Axis" storageaddress="11E748" />
    </table>
Code:
<table type="2D" name="Alpha 21" category="Alpha" storagetype="float" endian="big" sizey="15" userlevel="3">
      </table>
          </table>
<table type="2D" name="Alpha 22" category="Alpha" storagetype="float" endian="big" sizey="15" userlevel="3">
      </table>
          </table>
<table type="2D" name="Alpha 23" category="Alpha" storagetype="float" endian="big" sizey="15" userlevel="3">
      </table>
          </table>
<table type="2D" name="Alpha 24" category="Alpha" storagetype="float" endian="big" sizey="15" userlevel="3">
      </table>
          </table>
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-29-2015, 11:45 PM   #7
aagun
Drives: 86
i dont know what it is but i wanna learn all about it
aagun is offline   Reply With Quote
Old 07-02-2015, 10:06 PM   #8
aagun
Drives: 86
i need help here
i tried find FFF106FF0
it is same but not analyze
Code:
OM:00106FF0 dword_106FF0:   .data.l h'44480000, h'44960000, h'44C80000, h'44FA0000
ROM:00106FF0                 .data.l h'45160000, h'452F0000, h'45480000, h'45610000
ROM:00106FF0                 .data.l h'457A0000, h'45898000, h'45960000, h'45A28000
ROM:00106FF0                 .data.l h'45AF0000, h'45BB8000, h'45C80000, h'45D48000
ROM:00106FF0                 .data.l h'45DAC000, h'45E10000, h'45E74000
Code:
.....592 values
Old 07-03-2015, 07:09 PM   #9
ztan
Drives: Toyota 86
Originally Posted by aagun View Post
i need help here
Go to >Options>Setup data types (Alt-D)
An option box will come up with data type rotations that you want included in the data carousel - check "float". Pressing "d" in IDA will change the data type.
To change the line of numbers into an array, press "*" and enter the length of the array.
Old 07-06-2015, 11:50 PM   #10
burdickjp
Drives: 2013 ultramarine Scion FR-S
So this data is available on the CANBUS:
http://www.ft86club.com/forums/showthread.php?t=91170
I want it on my Tactrix. How do we go about getting it?
burdickjp is offline   Reply With Quote
Old 07-07-2015, 01:20 AM   #11
steve99
you would need to either sniff the can buss to get the data or get someone to trawl the ecu code to see if its stored in ecu ram addresses.
I suspect what the oft guys did was aquired a device that performes those read functions then sniffed the can buss data requests and coppied requests into oft.
Old 07-07-2015, 01:40 AM   #12
burdickjp
We could do similarly by copying the OFT requests. I don't like that, though. I don't think that's a very ethical way of accomplishing it.
Old 07-09-2015, 08:48 AM   #13
ztan
Drives: Toyota 86
Vishnu, EcuTek have all got their parameters by either disassembling the ROM or sniffing the CAN bus. Ethical would be buying the info from Toyota or Subaru, but they aren't selling.
I had a look at this briefly a couple of years ago, sniffing Techstream requests on CAN:
http://www.romraider.com/forum/viewt...8475&start=296
Old 07-09-2015, 10:19 AM   #14
burdickjp
That thread actually had this a few posts from where you linked in:
Lots of potential being seen:
ECU 0x07E8
CAN-ID 0x01
01 Calculated load
04 05 MAF
0B 0C Engine speed
0D Vehicle speed
32 Oil Temp
CAN-ID 0x03
07 Ignition advance
CAN-ID 0x37
09 0A FLKC
0B 0C FBKC
CAN-ID 0x41
06 07 Accel position
VSC module 0x07B8
CAN-ID 0x05
0B 0C Real engine torque
CAN-ID 0x47
01 Lateral G
02 Front/Rear G
03 Yaw rate
04 05 Steering wheel angle
Is it possible to get standalone engine + VSC logging with the OP2.0?
OFT vs. non-OFT definitions cliff p. Software Tuning 26 03-12-2018 04:24 PM
RomRaider XML definitions. wparsons Software Tuning 9 03-25-2014 12:24 PM
Oil? Strange discovery under glove compartment Seungify Issues | Warranty | Recalls / TSB 11 10-21-2013 07:58 PM
Discovery SCION FRS in Recent 86 Video Review. Zaku Scion FR-S / Toyota 86 GT86 General Forum 35 11-28-2011 03:41 PM
Front Suspension 'discovery'? Dimman BRZ First-Gen (2012+) — General Topics 13 07-23-2011 09:22 PM
