Old 07-10-2015, 03:28 PM   #1
XtremeS14
Drives: 2018 Subaru BRZ Limited
fs: Ohlins Road and Track Coilover
I'm selling my set of Ohlins coilovers for the FRS/BRZ. They have about 5000 miles on them and are in like new condition. Everything that came with them is included. I am also going to throw in another set of Ohlins front camber plates, brand new OEM Subaru front sway bar end links and brand new OEM Subaru front and rear hardware to install. Asking $2700 OBO. If I get my asking price, I will split shipping and paypal fee. Here is some info on them.
SOLD
Features:
- DFV (Dual Flow Valve)
- Corrosion salt spray tested to ISO 9227 - 2 year warranty
- Single bleed/Preloaded spring adjusters
- Fully re-buildable w/dust-covers
- Spring Rate: Front: 343 lbs/in. Rear: 343 Lbs/in.
Front (McPherson Strut):
- Single bleed adjuster
- Spring preload adjuster (20 mm lower than standard)
- Coil Springs
- Dustcovers
- Use with original top mounts
Rear (Conventional Shock Absorber):
- Separate spring preload adjuster (20 mm lower than standard)
- Coil Springs
- Dustcovers
XtremeS14 is offline
Old 07-11-2015, 02:44 PM   #2
kster1
kster1's Avatar
Originally Posted by XtremeS14 View Post
- Spring Rate: Front: 100 N/mm(572 lbs/in.) Rear: 80 N/mm(458 Lbs/in.)
Just curious, did you get them revalved for this custom spring rate?
kster1 is offline
Old 07-11-2015, 05:22 PM   #3
RJasonKlein
RJasonKlein's Avatar
As the previous poster indicated, these do not appear to be the Öhlins factory spring rates (although they appear to be Öhlins branded springs) - please confirm that these are non-standard springs and answer the above question regarding changes to valving.
RJasonKlein is offline
Old 07-11-2015, 05:42 PM   #4
XtremeS14
Spring rates
That was my fault. Those are spring rates for the Japanese model. The spring rates on these are 343lb/in or 6kg/mm. Sorry for the confusion.
Old 07-11-2015, 06:17 PM   #5
RJasonKlein
PM Sent.
Old 07-13-2015, 08:25 AM   #6
XtremeS14
sold
SOLD
Tein Flex Z Coilovers Evasive Motorsports Brakes, Suspension, Chassis 54 07-16-2017 02:21 AM
Ohlins Road & Track - settings (clicks) for street/track/ax dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-27-2016 10:36 PM
FS: Ohlins Road & Track Coilovers Wuuu Brakes, Suspension, Chassis 10 03-16-2015 10:37 PM
FS: Ohlins Road And Track DFV Coilover in Socal mtsui Brakes, Suspension, Chassis 5 03-28-2014 12:02 AM
Ohlins Road & Track Coilovers for sale h4nh Brakes, Suspension, Chassis 17 02-19-2014 12:35 AM
