Drives: '23 BRZ Limited
Finally looks like there is a proper bolt-in roll bar solution!
http://www.ft86speedfactory.com/auto...l#.VcPVtvlVhBc
Four points, harness bar, priced reasonably. WIN! |
Drives: Fr-s
Pretty sure that's been out awhile. Mounting plates look really small, I'd like to see where they land.
Drives: 2016 FR-S
Been around a while. Requires welding for front mounting.
Hmmm, I hadn't run across it before.
Could have swore the only thing I saw was whatever shop is making that $1500+ roll bar. |
Drives: 2013 Raven Scion FR-S
Was around back in '13 before my car was caged. Great option.
Emmanuel Baako: NASA-Southeast Race Control & NASA Florida Race Director
![]() RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T ![]() |
Drives: Sterling BRZ Ltd
Proper and bolt in are not words that should go together when talking about a safety device like a roll bar.
Drives: Fr-s
I'd argue that a bolted in design could be just as strong, but it would have to be designed properly. The problem I see with most roll bars is lack of any landing pad other than the 3x5 (if that) plate at the end of the hoop.
Does anyone have an install picture of the auto power bar? |
#8 | ||
Yep, properly designed bolt-in roll bars don't work AT ALL. This is the exact same bar I used to run in my Miata track rat. Based on the tach and being in 4th gear means he left the track at ~95mph. (Note to everyone, when you go off like that, LET GO OF THE DAMN WHEEL!) There are multiple, multiple incidents showing Boss Frog and Hard Dog roll bars saving the occupants in Miatas from injury. Quote:
#9 | ||
Drives: Nevermorange FRS
pic from link:
PRO86 | STL | LuckyDog
#10 |
BTW: GODDAMN. I hope you have considering using a head/neck restraint system going forward.. that looked ROUGH. Glad you're OK. Just went through something similar so I can relate.
Reference the 4 landing points of the cage in the picture, if just bolted down with that little surface area they can punch through the floor pan or body in a significant impact like yours, this I have seen. So a plate or "metal pad" that covers more surface area, often used on the underside of the body in which the cage bolts to spreads the load. I think a wider pad should be on both sides of the body the bars are bolted to. My welded in cage has thick pads (IT Spec) that cover a large surface area. In the past I used a bolted bar like this one but used larger plates above and below the body for a greater spread.
#11 |
No, that wasn't me. I've only wrecked on track on 2 wheels.
I was just using it as an example for those who like to spout off without experience on that which they are spouting off.Yes, like I mentioned, a properly designed bolt-in bar will have larger backing plates that place the "landing pads" in double shear. Although a weld-in cage should be mounted using plinth boxes, not just landing pads, a la: ![]() This is what happens with small "landing pads" without backing plates placing things in double shear (at my local track, car prepped by CarFx, essentially a bunch of jack holes who barely know how to turn a wrench) ![]() ![]() ![]() You can see them punched through the floorboard.
#12 | |
tickle fight referee
Drives: 2015 Subaru BRZ
Celery man
Electrical space wizard |
#13 |
Nope, somehow walked away.
I think it was something to do with using stock seats and belts allowing him to "fold" out of the way. That place builds terrible, terrible cars. However, Hallett is of the opinion (and make you sign the waiver) that if you're willing to put it on track, then go for it. I have wrecked on 2 wheels on the street (4 of us went down, 1 died) and once on 2 wheels at Hallett where a Shoei helmet saved my life after coming off the bike north of 70mph and landing head first (was knocked out long enough they red flagged the session).........I just don't understand how guys will skimp on safety. I guess it's the whole "It will happen to them, but never me." |
#14 |
Drives: 2013 Asphalt FRS
Spencer Fab make a excellent cage
I went with a Spencer Fab cage out of Seabrook New Hampshire,
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
| PTUNING GoPro and POV Camera Mount (tow-bolt mounted solution)...Now Available | Mrc@ptuning | Audio/Visual, Electronics, Infotainment, NAV | 23 | 04-18-2015 09:43 PM |
| Proper camber bolt installation | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 10-04-2014 10:09 AM |
| Bolt in Roll cages. | Ludacrits | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 01-26-2014 07:19 PM |
| Finally proper pictures of my car. | trueno86power | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 8 | 10-13-2012 09:01 PM |
| Proper Roll Cage | CyberFormula | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 04-12-2010 04:51 PM |
