Old 08-28-2015, 04:21 AM   #1
megamarines
megamarines's Avatar
Drives: 2015 FR-S RS 1.0
Send a message via AIM to megamarines
Constant "Grinding" Sound in Transmission?
Ok, so this just started a few hours ago, but my FRS suddenly started making a low whirring noise that almost sounds like a bike chain on the ground. It happens AROUND 4-4.5K RPMS and it almost sounds as if its occurring on the underside versus in the engine and is rather worrying. It's a decent volume, but it's mostly concerning since it happens in the lower gears. Clutch engagement and gear movement is fine, but it's the sound of it definitely feels like moving parts versus rattling exhaust or anything.
Any help or ideas? I think it might be a glazed clutch, but I haven't driven weird or hard on it at all.
I also got some video/bad sound clips of it. The sound is definitely right around 4-4.5k RPM's and can hover there even with my foot leveled on the gas. It sounds akin to a chain being dragged on the ground and is definitely coming from the front end of the car; not the rear or behind the drivers seat. Definitely a "grinding" whirring noise.
I apologize for my girlfriend's Cloverfield-esque footage haha
megamarines is offline   Reply With Quote
Old 08-28-2015, 10:45 PM   #2
J-Money
J-Money's Avatar
Drives: GT-86
Can't play video on my phone. But sounds like what I have. It starts around 4k and goes all the way up to 7k in every gear. I think I fucked up the clutch in all honesty because I used to ride it and accidently grind gears. I'm at 40k miles. Getting it checked tomorrow. I'm prepared to spend some cash on new clutch etc. My first manual car. But I drive it fine now. It must of gradually gotten worse over time. B
J-Money is offline   Reply With Quote
Old 08-30-2015, 01:45 AM   #3
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Eww. That sounds like a wire scratching the clutch (use headphones, you'll hear it then).
Does it have a mechanical sound like grinding following at higher rpm?
Hey, if you take it apart, check clutch bearing. You ever drive it hard? Even once? Not all cars react the same even if they the same car. Maybe the surface on the fingers(name?) aren't wearing out evenly. If it does that same sound on all gears, imo check drive shaft front. I googled and I guess its called 'torque shaft?'
Packofcrows is offline   Reply With Quote
Old 09-10-2015, 09:46 AM   #4
endless_pain
Pissin off regressives
endless_pain's Avatar
Drives: They have engines.
This is mine after a track event last month:
[ame="https://www.youtube.com/watch?v=Wr5aeX1sUXg"]20150830 160659 - YouTube[/ame]
Don't have shift problems either. Happens in low to mid speeds and all gears but was not happening in 5th when this video was taken. Hope is the throw out bearing.
endless_pain is offline   Reply With Quote
Old 11-20-2015, 05:44 PM   #5
RD1428
RD1428's Avatar
Drives: 2013 Scion FRS
So what was the issue? Having a similar problem like the OP
RD1428 is offline   Reply With Quote
Old 11-20-2015, 10:43 PM   #6
stevesnj
stevesnj's Avatar
Something may be loose, cat shield or similar. gently bang on some things in the exhaust area with the rubber handle of a hammer. Firm taps may rattle something.
My 2016 Build thread
Old 11-20-2015, 11:26 PM   #7
Packofcrows
TRD exhaust I hear?
Old 11-25-2015, 08:37 AM   #8
endless_pain
Originally Posted by Packofcrows View Post
TRD exhaust I hear?
Nop. PTuning header, OP, catted DP, OEM mid-pipe and Nameless track pipe with their biggest muffler option.
Old 02-28-2016, 11:34 PM   #9
Cartman
Cartman's Avatar
Drives: GT86
What ended up being your issue, mine is doing the exact same sound after my last track day.
Cartman is offline   Reply With Quote
Old 03-06-2016, 02:22 AM   #10
nimble
nimble's Avatar
Drives: 2013 WO FR-S
@megamarines Did you ever find the issue? Mine's doing this as well.
nimble is offline   Reply With Quote
Old 06-27-2024, 11:47 AM   #11
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Did you guys figure out what was causing the noise? I have a similar noise and I’m trying to figure out if it’s the transmission or the engine. There is noise on mine above idle and even if my foot is pressing down on the clutch
HRTROB is offline   Reply With Quote
"Flappy Paddle" Treatment From SSP // Automatic Transmission Upgrades@DSG Performance Jason@DSG Transmission and Driveline 201 06-09-2016 07:31 PM
Gearbox Loose and "Slushy" Sound When Under 2200 RPMs astrubinger Issues | Warranty | Recalls / TSB 9 07-08-2015 11:48 PM
Metallic "clink" sound coming from the rear... Jaylyons1 Issues | Warranty | Recalls / TSB 20 07-26-2014 09:11 PM
"... the subtle evil that is the automatic transmission" - article robwbright Other Vehicles & General Automotive Discussions 4 06-03-2014 03:24 PM
REQ: Looking for sound clip of Nameless 2.5" "No Muffler" Dual Exhaust Axleback jbsali Engine, Exhaust, Transmission 1 01-28-2014 08:22 AM
