Old 06-22-2012, 02:34 PM   #1
jjdrivesajazz
Drives:
automationLED: DIY LED interior + license plate conversion
For questions or tips, you could contact me by PM or email at automationLED@gmail.com
For the dome light on the car, it's very simple, you have 2 notches on the plastic cover where you would insert a flat head screw driver and lightly pry out the cover. It'll pop off and you will see the DE3175 bulb exposed. Be careful as the bulb might be a little warm to handle, so let it cool down for about 5 minutes. After it has cooled down, remove the bulb from the housing assembly and set it aside. Take the new LED bulb and insert it into the housing, if it does not light up the first time, remove it and turn it 180* and re-insert. The LED bulbs have a POS and NEG end, unlike the factory incandescent bulbs.
Package 1 dome light (similar brightness to OEM, bright white color)
Package 2 dome light (3x brighter than OEM)
All done
The trunk light is very simple, you just pop open the trunk and you'll see a small white cover. Remove that and place aside (or you can leave it off, for a brighter glow). Remove the wedge bulb and insert the new one.
For the license plate light, you'll access them from the inside of the trunk lid. You'll see the 2 light sockets on the inside, just twist and remove these lights, pull the wedge light and replace them with the new ones. Again, if they do not turn on the first time, remove them, flip it 180*, and re-insert.
For the reverse lights, you might want to do these last. Since you'll access the light sockets from underneath the bumper, it is very close to the muffler and you don't want to touch that when it's hot. After it has cooled down, reach from exhaust tip side of the lower valence, and feel for the light socket. Twist that one and remove the bulb, and insert the new LED.
*NOTE*
The CREE LED's might not seem that bright compared to the OEM light because of the way the light bulb is positioned. It points upwards towards the center of the car, and with LED's being a directional light, it will rely on reflecting on the inside housing to be bright. During the day time, it might not seem as bright, but at night time, it is a very nice bright white.
[/center]
jjdrivesajazz is offline   Reply With Quote
Old 06-22-2012, 02:35 PM   #2
jjdrivesajazz
Drives:
USER SUBMITTED PHOTOS
12SMD GODZILLA DOME LIGHT (OUR PACKAGE 2 KIT)
DOOR STEP LIGHTS (BRZ ONLY)
TRUNK LIGHT
LICENSE PLATE LIGHTS
HIGH POWER REVERSE LIGHTS
When you buy from Automation Lighting, you're not only getting the best product I can offer, you're also getting BEST CUSTOMER SERVICE and BEST PRICING out there, WE WILL NOT BE UNDERSOLD!!!
LOOK WHAT OUR CUSTOMERS HAVE TO SAY
Originally Posted by mechaghost View Post
I installed the Stage 2 LED lights on the BRZ. I like how bright the lights are, the photos don't do it justice but I definitely can see the ground with the white lights and the interior cabin just lights up! Great investment
Originally Posted by Caliban View Post
thumbs up for JJ @ Automation! These guys are legit!
Originally Posted by Fish View Post
Got my kit yesterday. Installed everything. Dome light, trunk light, and license plate lights. I have to say, it looks great. The dome light was bright as hell. I first got to use it on the drive Vegas. Pitch black and my buddy needed to find something. Turned it on and we were blinded. We just weren't prepared for how bright it was. I love it though. lol
Originally Posted by skoodge View Post
Just want to say thanks to Automation Lighting! The lights got here in 2 days. Very easy to install and a great product.
Check out more photos of the lights on my car journal thread "Skoodge's Whiteout FR-S"
Originally Posted by DyoGTS View Post
Just got my shipment yesterday and installed the lights last night (dome, door, trunk and license plate). Looks great, thanks!
I also got panels that I'll be using for the footwells, but I'm still deciding how I want that to work.
Originally Posted by colHolm View Post
Received mine today! They look great.
Originally Posted by Fenrir View Post
Just want to say publicly that customer service through Automation Lighting is excellent. Very quick response to my DOA bulb and a resolution already.
Originally Posted by Dkittrell View Post
Thank you for the very quick reply , very good customer service .Order is placed, cant wait to get these installed .
Those reverse lights look crazy. I like!
Originally Posted by prest1ge View Post
had i known the reverse lights look that good, i would've added them to my order as well. dangit......
Old 06-22-2012, 02:49 PM   #3
Khalis
Khalis's Avatar
Drives: 2013 Ultramarine 86
It would be great if you could also do a courtesy light diy on the door of the FR - S. Thanks for the write up!
Khalis is offline   Reply With Quote
Old 06-22-2012, 04:10 PM   #4
jjdrivesajazz
Drives:
As soon as I have some time to play with a FR-S and possibly a BRZ courtesy light, I might be able to do a DIY on how to retrofit it in.
Old 06-22-2012, 04:30 PM   #5
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
The brz is easy. Just use a screw driver on the side of the door light and pry it open. Disconnect the light housing from the wire. Then you need to open the light housing by pressing on a clip to separate the two halves. Then pull out thw bulb and replace. Reverse the directions to put back in. The bulbs are the same as the licenseplate lights and trunk light
mechaghost is offline   Reply With Quote
Old 06-22-2012, 04:37 PM   #6
Dkittrell
Drives: 2013 FR-S hot lava
Order is placed
Dkittrell is offline   Reply With Quote
Old 06-22-2012, 06:23 PM   #7
NRGBalanced
NRGBalanced's Avatar
Drives: '13 Subaru BRZ Limited WRB
Thanks a lot for the instructions! Going out today to put them on. Shipping and packaging was great.
NRGBalanced is offline   Reply With Quote
Old 06-23-2012, 01:50 PM   #8
jjdrivesajazz
Drives:
thank you! please post a couple pics if you have some time, i appreciate it!
Old 06-23-2012, 02:47 PM   #9
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
I'm in for a full order once you get the white turn signal package as well.
Khyron686 is offline   Reply With Quote
Old 06-23-2012, 03:22 PM   #10
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 06-24-2012, 02:15 AM   #11
NRGBalanced
DIY for BRZ in-door courtesy lights
Thought I'd throw up the pictures from installing LED door courtesy lights here after someone asked about it. The pieces seemed somewhat fragile. I did it this afternoon. (pictures link to larger version)
I had some pry tools lying around from work on small electronics and iPods. They look like this:
I used a couple of them to get in between the door and the lens. The lens will pop out from the right side (the lights are identical on each side) I managed to bust one of the pry tools while doing this, so don't pry too hard on the wrong side:
After it popped out, I pulled the light away from the door and pushed in on the gray tab in the center of the connector. Then you can disconnect the power and let the bulb cool.
Once you've removed the light assembly from the door, squeeze the plastic part where my thumb is in the picture and gently rotate up. The part below has a little notch that has to be disengaged. After it's released, do the same for the small tab on the other side (gently!). Then pull the whole bulb cover off:
Once that's off, stick a screwdriver behind the bulb to pop it out. Careful, it will go flying (location shown after LED was installed):
Replace the bulb with the LED, but make sure the LED wires touch the contacts. Now is a good time to plug it in again to make sure the polarity on the LED is correct.
Replace the plastic bulb cover. It will be snug now:
Then reverse the installation in the door (pop the right side in last):
That's it! Squeezing that plastic piece was a little nerve-wracking, but it's tough!
Old 06-24-2012, 02:19 AM   #12
NRGBalanced
And the results, using jjdrivesajazz's instructions for the rest.
All the lights are far brighter than stock, with the door lights especially providing more usable light:
Ignore the yellowish garage light:
Old 06-24-2012, 02:20 AM   #13
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
+1 on this!
86_ZN6 is offline   Reply With Quote
Old 06-25-2012, 06:47 PM   #14
jjdrivesajazz
Drives:
Read about our comparison when it comes to LED chip quality from other sellers
and see why our LED's are the BEST, read all about it
-> here <-
License plate ideas Laika Off-Topic Lounge [WARNING: NO POLITICS] 142 06-13-2015 09:17 PM
SG886 license plate ToxicSneakers Off-Topic Lounge [WARNING: NO POLITICS] 0 06-18-2012 06:35 PM
Another license plate idea.... michaelahess Cosmetic Modification (Interior/Exterior/Lighting) 4 06-07-2012 09:24 PM
Front License Plate Replacements Bonburner Cosmetic Modification (Interior/Exterior/Lighting) 14 05-14-2012 07:25 PM
Front License Plate Location Polish Person Scion FR-S / Toyota 86 GT86 General Forum 44 12-16-2011 12:04 PM
