Old 10-10-2015, 09:43 PM   #1
stevesnj
stevesnj's Avatar
LED H11 Headlights in 3 Temps for $42
Maybe I missed it in my search but didn't find anyone with these. They may be new to the market? Dunno but wow these are fantastic. I got these H11's from amazon here [ame="http://www.amazon.com/gp/product/B00Y1UXZFW?psc=1&redirect=true&ref_=oh_aui_detailp age_o00_s00"]Amazon.com: Partsam 2pcs H8/H11/H16 2-Cree-XML2 8000K White 2000LM LED Headlight: Automotive[/ame]
I bought similar LED's with internal driver and rated for water intrusion and that's what these have also. So after searching I found these and they come with 3 colors not 2 as it says in the ad. 6500k, 8000k, and 3300k yellow/amber
The colors are created by exchangeable glass covers (yes real glass). the naked LED is 6500k and the 8000k is produced by the blue cover and yellow/amber with that cover. The tip of the housing unscrews and you can then change to your desired color. I wish I could use the Yellow because it is stunning to see! But I chose the 6500k to match the front LED switchback signal bulbs plus the yellow is not legal in NJ.
Anyway I did a comparison and took some pics. Now the Lumens of a Halogen H11 is 1800+lm these LEDS are 2000lm and its just fine not too bright for oncoming drivers since my truck has the same lumen and temp bulb I knew it would be fine. Time will tell on their reliability but for $42 it was worth a shot to try.
Any questions just ask!
Pic 1 Unboxing
Pic 2,3,4 - exchangeable glass covers
Pic 5,6 - clearance from base of bulb to wheel well
Pic 7 - colors of 3300k and 8000k
Pic 8 - 3300k
Pic 9 - 8000k
Pic 10 - 6500k
My 2016 Build thread
Old 10-10-2015, 09:51 PM   #2
stevesnj
stevesnj's Avatar
more pics...
Vid - 1 3300k
Pic 1 - 3300k I think this looks amazing, in person it's beautiful!
Pic 2 - 6500k Beam Pattern (distance about 50 ft - 15 meters)
Vid 2 - 6500k
[ame="http://vimeo.com/142026362"]http://vimeo.com/142026362[/ame]
[ame="http://vimeo.com/142027040"]http://vimeo.com/142027040[/ame]
Old 10-10-2015, 10:09 PM   #3
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Have any pics of the output/beam pattern?
Old 10-10-2015, 10:10 PM   #4
stevesnj
stevesnj's Avatar
Yep, coming
Old 10-10-2015, 10:23 PM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by stevesnj View Post
Yep, coming
Surprisingly from the photos the cutoff doesn't look that bad and I don't see any glare like the majority of LED bulbs
Old 10-10-2015, 10:26 PM   #6
stevesnj
stevesnj's Avatar
Yeh it looks nicer in person, could be some distortion from the camera lens
Old 10-10-2015, 10:29 PM   #7
FRSBRZGT86FAN
I'll honestly stick with my HIDs in my WinJets, LED performance still isn't good enough via the aftermarket to compare to the HID kit. Also HID kits are almost a full 1000 lumens brighter
Old 10-10-2015, 10:31 PM   #8
stevesnj
stevesnj's Avatar
I'll honestly stick with my HIDs in my WinJet LED performance still isn't good enough via the aftermarket to compare to the HID kit. Also HID kits are almost a full 1000 lumens brighter
Yeh I didn't want to go brighter than stock lumens but had no choice. 2000lm is close enough. though I probably wouldn't have an issue legally with brighter, so I'm just playing it safe.
Old 10-11-2015, 12:04 AM   #9
Andrew025
Andrew025's Avatar
Looks pretty good.
Been thinking of getting some of these for my fogs basically for the color.
Not sure if I would put them in my headlights though.
Old 10-11-2015, 01:04 AM   #10
swarb
Looks good. Your head lights look pointed a little too high. And take pictures/videos in front of a garage door to get better indication of color and beam pattern.
3 colors were provided.
Yellow= 3k (not 4300k as you mentioned)
No cover= 4300k
Cover=6k
I think that is correct.
Old 10-11-2015, 01:11 AM   #11
stevesnj
stevesnj's Avatar
No cover= 4300k
Cover=6k
Nope, says on the box, 4300k 8000k 6500k(no cover) Just realized it said 6500k
Old 10-11-2015, 01:22 AM   #12
swarb
Just because it says it in the box does not mean it is right. It is probably made in China and they rarely get sun under that thick layer of pollution so their white balance is off.
Just look at it the pic. The light is very yellow. 3k is yellow. 4300k is warm white.
6500k might be semi-accurate though.
Old 10-11-2015, 01:27 AM   #13
stevesnj
stevesnj's Avatar
Probably supposed to be 3300k, put in a 4 instead of a 3, but it looks great whatever it is. But what LEDs are not made in China. lol
Old 10-11-2015, 03:32 PM   #14
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
Look good to me! Are they significantly better for visability / I assume these are plug-n-play?
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
N/A typical oil temps JB86'd Engine, Exhaust, Transmission 13 12-16-2014 01:42 AM
Oil temps with JR SC and JR oil cooler dp1 Tracking / Autocross / HPDE / Drifting 87 11-14-2014 01:35 AM
Oil Temps Fish Eagle AFRICA 13 07-22-2014 06:53 PM
Intake air temps mrk1 Engine, Exhaust, Transmission 2 07-10-2013 08:56 PM
