Old 10-23-2015, 01:05 PM   #1
Frank the Tank
Cat broken apart
I have the Borla UEL header and berk muffler delete. the rest of the exhaust is stock. I have a terrible rattle from the front pipe and im 99% sure it is the cat converter. I guess the higher flowing and hotter exhaust from the header has destroyed it. But the car is dyno tuned to these exact mods. If i get a hi flow cat front pipe will i have to retune the car? If so im just gonna get another stock front pipe. Thanks
Frank the Tank is offline   Reply With Quote
Old 10-23-2015, 01:25 PM   #2
steve99
yep cats been known to disintergrate on cars tracked hard.
hi-flow cat front pipe change wont require re-tune, the aftermarket metalised cats probably tougher than the stock ceramic ones hopefully.
Old 10-23-2015, 03:05 PM   #3
wparsons
wparsons's Avatar
I would check to make sure nothing is rubbing first (especially a heat shield) before assuming it's the cat.
No re-tune needed for an aftermarket front pipe, and I would suggest getting one if you're replacing it already. The stock one is the 2nd biggest restriction (after the header) in the stock exhaust.
flickr
Old 10-23-2015, 03:18 PM   #4
Frank the Tank
Thanks guys. thats good to hear. Yea heat shields are completely off the car. wanted to rule that out first.
The Case of The Broken RS 1.0 JiroZero713 Scion FR-S / Toyota 86 GT86 General Forum 90 12-12-2014 01:15 AM
My car got BROKEN into. Hiros86 Northern California 25 02-25-2014 12:33 PM
Wtb:broken borla uel BoostedWrbBrz Engine, Exhaust, Bolt-Ons 4 12-31-2013 03:48 PM
Still not broken in Drftfan Scion FR-S / Toyota 86 GT86 General Forum 38 06-13-2013 08:51 PM
Broken into sharris721 BRZ First-Gen (2012+) — General Topics 42 04-28-2013 01:22 PM
