Drives: 2013 FRS 6MT
2002-2006 STI Brembo Conversion
Counldn't find exactly the information i needed after searching, hopefully someone can shed some light for me. I have a BBK my friend wants to hand me, but it belongs on a STI 02-06. Would it be possible to transfer this to my FRS, without having to customized anything, like a plug and play.
Or could i just use the calipers and get new brake lines and brake fluid? Thanks! It comes with CALIPERS HUBS ROTORS KNUCKLES |
#2 | |
Drives: 2014 BRZ Limited
Try this Edit: Don't think the Hubs or Knuckles will work though. |
Drives: '14 Midnight Purple FR-S
Fronts will be a direct bolt-on, just need to swap the bleeder from bottom to top because our calipers are mounted frontwards instead of rearwards like the STI. Looks like your rotors are from an 04 STI so they will fit no problem as well.
I wouldn't bother with the rears to be honest. My setup for reference:
#4 | |
Drives: Harrop TVS86 STi BRZ tS
Drives: 2024 GR86
Swapping bleeders is probably the most difficult. I had to get 1 helicoiled by a machine shop. You must use heat! I used a small A\O brazing torch and slowly brought it up to temperature. I rushed the first one and that was the only one i messed up. Use a nice fitting Allen key is important to prevent stripping the plug.
You will need the adapter for the rear calipers. I bought the KNS Version II. You will need to trim the rear heat shield. You will need new fasteners. Depending on the exact year of this set, you may need new rotors if they are not 5x100. Good luck. All information is on the posts linked above. |
| Brembo conversion problem | mrha | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 01-29-2016 01:44 AM |
| 2006 Honda CBR F4i | timisu87 | Cars for Sale/Trade | 0 | 05-18-2015 12:30 AM |
