Old 12-10-2015, 08:14 AM   #1
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
What to do about Clutch Knee
My last car had a mushy clutch but the FRS has a pretty stiff clutch in it and I sit in some pretty nasty traffic sometimes. Back of my knee is killing me. Is their some driving habbits I need to change, to ease up on the knee. Other day it actually buckled on me
Guess i can trade off with my wife every few days, taker her atuo Kia let her drive the stick and give my knee a rest
RichardsFRS is offline   Reply With Quote
Old 12-10-2015, 08:17 AM   #2
Lorico
Drives: 2015 FRS
The military gave me some rough ankles and I too sometime debate about my clutch pedal.
The only way to change is to drive less but we all have to get to work some how. Would you ever think getting an auto? Or better yet. Just buy a cheap automatic beater to get to and from work. The FRS can be the weekend warrior
Lorico is offline   Reply With Quote
Old 12-10-2015, 08:23 AM   #3
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Work out? This is about the lightest clutch you'll ever drive.....
Old 12-10-2015, 08:27 AM   #4
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
The FR-S clutch is stiff? It's as light as my Corolla.
If your FR-S is used, it may be worth finding out if yours had the clutch spring removed and/or if there is a heavier aftermarket clutch installed.
Old 12-10-2015, 08:48 AM   #5
RichardsFRS
We just got the frs. It is used. I can just trade off with my wifes kia every few days. She has no traffic but she may not give me the car back. She loves that car
Old 12-10-2015, 09:04 AM   #6
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
If the clutch is stiff, there might be something wrong with it, or an enterprising previous owner modded it.
pushrod is offline   Reply With Quote
Old 12-10-2015, 11:05 AM   #7
These^^^
Odds are that the spring has been removed since about 99% of the people on here find it way too light and vague when stock. Probably not a big deal to put it back.
Old 12-10-2015, 11:05 AM   #8
jvincent
jvincent's Avatar
One other thing that might be a contributing factor is that the clutch pedal height from the factory is very high, which can make it uncomfortable to use.
There is a 10-min DIY fix for this.
Old 12-10-2015, 11:14 AM   #9
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I used to drive stick like you.... Then I took an arrow to the knee
Old 12-10-2015, 11:16 AM   #10
KR-S
Sporadic Member
KR-S's Avatar
And here come the trolls in full force...
Old 12-10-2015, 12:50 PM   #11
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Squats are you best friend. Don't have a gym membership? Do lunges and air squats. If the back of your knee is killing you, sit closer so you're not extending your leg as far.
MS, CSCS, TSAC-F, CPT
Old 12-10-2015, 01:03 PM   #12
Ashikabi
Ashikabi's Avatar
I too have problems with the tension in my knee but not with the car. Try a different seeing arrangement. Perhaps you are too close or too far. Try to keep your heel on the floor, should take nearly all tension off your knee
Old 12-10-2015, 01:04 PM   #13
KR-S
Sporadic Member
KR-S's Avatar
OP is an old timer, just so you know.
Old 12-10-2015, 01:06 PM   #14
Celica00
Celica00's Avatar
Drives: 86
Was just going to mention this ^^^
Again, try changing seat adjustment. Similar to how parts of our suspension can fail from lowering the car by changing the angle of force. Maybe your leg is trying to be hella stance when it should be OEM
Celica00 is offline   Reply With Quote
:popcorn:
Knee Pad Set For FR-S and BRZ zetaproducts.net Interior Parts (Incl. Lighting) 4 12-18-2012 10:07 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 11:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 01:06 PM
