Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-02-2016, 06:24 PM | #1 |
SupaSter
Drives: 13' BRZ
Coolant loss - Void Warranty/ Edit: coolant flush question
Hey all,
A few months ago I realized my coolant was low so I topped her off. Again recently I realized it was low. Since it is an enclosed system, something must be wrong correct? Anyway, I would like to take it to the dealership to have them check on it. I would like to know if my modifications will possibly "void" warranty if there is a problem. I have an UEL header, over-pipe, Catback, and aftermarket intake tube. All of which (besides catback) was installed after noticing the loss of coolant. I'm not too knowledgable toward engine internals yet, so please be somewhat understanding. Thanks EDIT: Ok so I was a noob a while back threw in some coolant that was sitting in my cabinets at home from my parents. After doing lots more research since then and realizing that you should never do that, I check the overflow tank. It was goopy at the bottom which means the mix wasnt the same chemicals. That being said, I now realize I need to empty and flush the system, then refill with Subaru coolant. Does anyone know of a good flush kit? Thanks
01-02-2016, 06:30 PM | #2 |
Canada Eh!
Drives: '13 FRS
You're fine. None of that should void your warranty.
The Following User Says Thank You to Joe-G For This Useful Post: | BRZach (01-02-2016) |
01-02-2016, 06:57 PM | #3 |
Drives: JAWS
It's not going to "void" your warranty, and I don't think they're going to blame your coolant loss on exhaust modifications. BUT, they can make a note in their system that you have aftermarket exhaust modifications and if you were to go in with some kind of engine issue, they may try to use that as an excuse to deny warranty coverage of that issue, even if you've returned to stock at that point.
The Following 2 Users Say Thank You to JB86'd For This Useful Post: | BRZach (01-02-2016), FRSBRZGT86FAN (01-02-2016) |
01-02-2016, 07:06 PM | #4 |
As above mods dont completely void warranty, but if they can tie the problem back to a mod or aftermarket part then they can "void" warantee on that issue or part.
Its possible they may argue that the aftermarket header has caused engine bay temps to rise (no heat shields on aftermarket headers) , this may cause more evaporation from the coolant overflow tank , for example. Or the extra heat caused deterioration of rubber/plastic pipes in engine bay if they were cracked/leaking/deteriorated faster than normal. If its just loosing a small amount (say a cup full) over a few months in hot weather then it might just be evaporation from overflow tank. If it loosing more than that in a week or so then its likely another issue like a leak or at worst cracked block/head leaking radiator ect. If your at all concerned swap the stock header back in before you take it for warantee claim |
The Following User Says Thank You to steve99 For This Useful Post: | BRZach (01-02-2016) |
01-02-2016, 07:07 PM | #5 |
Drives: frs
First off, which coolant you used?
01-02-2016, 07:15 PM | #6 | |
http://www.ft86club.com/forums/showthread.php?t=26482 My car "loses" coolant as well, took almost 8-9 months and right after a hot summer to notice it was on low when the engine was warm. I think it's a common issue, with it evaporating through the hoses and expansion tank cap and such. Other people have found that swapping to mishimoto hoses stops the issue. I personally just topped it off with a 1 gallon jug of Toyota long life coolant and it didn't even use a 1/4 of it after the aforementioned 8-9 months of hot summer whether, which lead me to believe in my case it was just an evaporation issue.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | BRZach (01-02-2016) |
01-02-2016, 07:25 PM | #7 |
SupaSter
Drives: 13' BRZ
01-02-2016, 07:41 PM | #8 |
Drives: 2005 Toyota Camry
Stop using the word void.
Nothing is voided. You did not burn your car down nor did Subaru go out of busines. -alex |
01-02-2016, 07:47 PM | #9 |
SupaSter
Drives: 13' BRZ
As I put void in quotations, meaning deny.
01-02-2016, 07:55 PM | #10 |
Warranty claim denied, depends on your case.
The usage of the word void suggests that you no longer have a warranty and many people misunderstand how warranties work, like an aftermarket mod can cancel your entire warranty. -alex |
01-02-2016, 07:59 PM | #11 |
SupaSter
Drives: 13' BRZ
Agreed, thanks for that.
01-02-2016, 08:29 PM | #12 | |
http://www.ft86club.com/forums/showthread.php?t=9883 [ame="http://www.amazon.com/Genuine-Toyota-Fluid-00272-GTBC1-Coolant/dp/B00AKYP114/"]Amazon.com: Genuine Toyota Fluid 00272-GTBC1 Blue Super Long Life Coolant - 1 Gallon: Automotive[/ame] Personally I stay away from flush fluids and kits I just use a whole bunch of distilled water
01-02-2016, 08:31 PM | #13 |
Drives: frs
Used different coolant, mean warranty is voided
01-02-2016, 08:36 PM | #14 |
I just use distilled water lol. I guess it matters more if you're in a freezing climate.
The Following User Says Thank You to ryoma For This Useful Post: | BRZach (01-02-2016) |
Similar Threads | ||||
Will this void warranty? | Ymerej | Issues | Warranty | Recalls / TSB | 16 | 02-13-2014 02:01 AM |
Oil cooler void warranty? | Sniper2606 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 02-09-2014 09:44 PM |
Will e15 void the warranty? | dawnst3ar | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 12-05-2012 02:59 PM |
What Will Void My Warranty ? | ScionFR-S | Issues | Warranty | Recalls / TSB | 6 | 11-10-2012 12:36 AM |
Will This Mod Void My Warranty? | Apex Chase | Engine, Exhaust, Transmission | 7 | 07-17-2012 12:38 PM |
