USMC
Drives: 2013 FR-S 6-MT Raven
Clutches that hold over 400Hp/Tq
I currently have the ACT SB7-XTG6 installed. What other clutches are out there that hold a lot of power but aren't twin discs? Has anyone seen or created a list? Thanks in advance.
Sent from my SAMSUNG-SM-N920A using Tapatalk |
Hot Lava 6MT
Drives: Hot Lava FR-S
My Clutchmasters FX400 has been great. I'm currently around 450HP/400TQ
Drives: Rb25 neo brz
I currently have the ACT XT installed at 500 WHP the clutch is a pain to use, and is starting to fall short and has been sense day one. i would recommend the Exedy twin disc
#4 | |
USMC
Hot Lava 6MT
Drives: 2013 Whiteout FR-S
I'm using an exedy twin disc.. it's also a pain to use if you're DDing the car..
You should also think about upgrading the transmission gears
TEAM NEMESIS | NEM 86 | IG: @NEM_86 PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics The NEM86 Build Thread |
Drives: Raven FR-S 6M
OS Giken doesn't like to publish their torque specs but are used in many high hp/tq applications.
“The World is Flat”
[||•]=(86)=[•||] |
Did you bump back up in power after that initial bump down and reliability session at Church's?
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#9 | |
Drives: 2014 Argento FRS
Fairly new to aftermarket clutches, why is it a pain to drive a twin disc as a DD? Having to slipped a lot more to get going? Sent from my iPhone using Tapatalk |
#10 |
The engagement is pretty sensitive.. the window from when the clutch is pressed in, to the engagement point is literally maybe 2" of lift.. and it's stiff as hell
#11 |
Ned flanders
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
I was running the ACT street at 320whp. and it began to slip. I since swapped in a 4 puck, Link below:
( http://www.frsport.com/HD-Clutch-Kit...DSIRoCEvvw_wcB ) And it has been fine ever since. It does make some funny noises and engagement is "harsh" as most people would complain about. But most people that drive our cars are sissy's and complain about everything.
797Performance.com
#12 |
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
I'm running a OS Giken Twin Plate, its rated at 700TQ from what they told me. Its a pretty stiff for DD but once you get used to it, it's not to bad. Super small window of engagement, feels great shifting.
#13 | |
USMC
#14 | |
USMC
| Volkswagen has gone mad.... 400hp Golf | Joakim3 | Other Vehicles & General Automotive Discussions | 59 | 03-11-2016 01:48 PM |
| 400hp on pump gas | woode | Forced Induction | 100 | 10-16-2014 01:11 AM |
| 400hp build and other turbo questions. | Ludacrits | Forced Induction | 22 | 10-26-2013 10:01 AM |
| 400HP Firestorm Red FBM Kit | FullBlown | Forced Induction | 166 | 10-16-2013 06:54 PM |
| E85 400hp mark | Fabron757 | Forced Induction | 26 | 06-20-2013 02:41 PM |
