Old 02-24-2014, 01:58 PM   #939
ptuning
ptuning's Avatar
Drives: White FR-S
Originally Posted by cobrabyte View Post
Ballpark ETA/pricing on 'flex fuel/racing surge tank setup?'
We're hoping to keep the return style/swirl pot system around $1.5k or so with the flex fuel option being extra. It will include A LOT of parts, many of them custom components, for the money. The fuel system will include a Fuel Lab FPR, Walbro 485 E85 fuel pump, PnP high current wiring relay, and PnP fuel connections with the price. All of the included fuel lines and in-tank wiring will be teflon lined and E85 compatible.
We're still undecided on how we want to implement the flex fuel connection to the ECU. There are several ways to do this, so we'll likely have several wiring options available.
- Toan
ptuning is offline   Reply With Quote
The Following User Says Thank You to ptuning For This Useful Post:
cobrabyte (02-24-2014)
Old 02-24-2014, 02:02 PM   #940
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
We're still decided on how we want to implement the flex fuel connection to the ECU. There are several ways to do this, so we'll likely have several wiring options available.
- Toan
Sign me up. I already have a FlexFuel setup so I'd just need the base system.
cobrabyte is offline   Reply With Quote
The Following User Says Thank You to cobrabyte For This Useful Post:
ptuning (02-24-2014)
Old 02-24-2014, 02:08 PM   #941
JerryMichaels7
Drives: Whiteout FRS
swirl pot = fuel sump? Like no lean condition on hard lefts??
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 02-24-2014, 02:19 PM   #942
ptuning
ptuning's Avatar
Drives: White FR-S
Yes, it's based off of the same design that allowed our Time Attack tC to run below the empty mark on track with r-comp tires, whereas the stock set-up had fuel starvation issues below half tank.
A surge tank and swirl pot are the same thing. However, a vertically mounted round swirl pot has side feeds for the FPR return and main tank fuel feed. This arrangement promotes a swirling action in the swirl pot/ surge tank that helps to deaerate the fuel coming back from the FPR. In addition it promotes the flow of the generally hotter FPR fuel back to the main tank and the cooler main tank fuel to feed the Walbro 485 pump housed inside of the surge tank. Hopefully this makes sense.
- Toan
The Following 2 Users Say Thank You to ptuning For This Useful Post:
JerryMichaels7 (02-24-2014), SmsAlSuwaidi (02-24-2014)
Old 02-24-2014, 03:11 PM   #943
JerryMichaels7
yep, lol a yes would of been good enough, but i like the detailed answer too. Gonna get all the supporting goods this year and hopefully next year i can pull the trigger...WTB HEADER W/FULL VBAND EXHAUST
Old 02-24-2014, 03:25 PM   #944
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Yes, it's based off of the same design that allowed our Time Attack tC to run below the empty mark on track with r-comp tires, whereas the stock set-up had fuel starvation issues below half tank...
Toan, have you experienced the same issue with the FRS below half a tank? Just wondering if it's an area of concern, primarily the lean condition, for those who daily drive or mainly a track application.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 02-24-2014, 03:29 PM   #945
JerryMichaels7
there are some old threads that mention it happening to the FRS
Old 02-24-2014, 03:35 PM   #946
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
I understand that but my question isn't really if it'll happen but in what conditions (track, dd, etc) is it most likely to occur.
Old 02-24-2014, 03:48 PM   #947
JerryMichaels7
Yeh sorry, the issue was hard lefts on tracks below i think 1/2 or 1/4
Old 02-25-2014, 02:55 AM   #948
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Have you ever seen an MV Agusta motorcycle disassembled? The mechanic gets to see beautiful works of art as he takes it apart. This photo reminded me of how PTuning is also proud of their work and takes their time to make parts look as good as they work.
rb6freak is offline   Reply With Quote
The Following 2 Users Say Thank You to rb6freak For This Useful Post:
bjun (02-25-2014), ptuning (02-26-2014)
Old 02-28-2014, 11:19 AM   #949
Events@Ptuning
Events@Ptuning's Avatar
Drives: 2013 Scion FRS
Bump More Info Coming Soon
Events@Ptuning is offline   Reply With Quote
The Following 3 Users Say Thank You to Events@Ptuning For This Useful Post:
Dinko (02-28-2014), MDSubarubrz (02-28-2014), mkivsoopra (02-28-2014)
Old 03-07-2014, 03:20 PM   #950
ptuning
ptuning's Avatar
Drives: White FR-S
Another dyno sheet. '13 FR-S owned by one of our sales staff.
Still zeroing in on the perfect tune for the midrange. We now have over 200WTQ from about 3,200 rpms to 8,000 rpms. Not too shabby.
93 pump gas at 11 psi.
PTUNING Spec-SS GT3076R Turbo System w/stock header
PTUNING DS-333 3-inch Dual Exhaust System.
PTUNING Fueling Package - Map Sensor and FIC 770cc injectors
The Following 7 Users Say Thank You to ptuning For This Useful Post:
bjun (03-07-2014), Eurasianman (03-07-2014), kanundrum (03-07-2014), kayhettin (03-07-2014), mkivsoopra (03-08-2014), rb6freak (03-07-2014), Sonolin (03-07-2014)
Old 03-07-2014, 04:34 PM   #951
sw20kosh
Drives: 2013 Black FR-S
Wow very nice! Still waiting on your 91 octane graph... =)
The Following User Says Thank You to sw20kosh For This Useful Post:
Old 03-07-2014, 09:38 PM   #952
ptuning
ptuning's Avatar
Drives: White FR-S
Now that we have a second shop car running just our base turbo set-up, this shouldn't be a problem. I'll check my dyno schedule for next week and see if I can squeeze in a 91 octane dyno tuning session.
- Toan
kanundrum (03-07-2014), rb6freak (03-07-2014)
over 9000, ptuning, turbo kit
FA20CLUB.com Turbo Kit Sneak Peek.... FA20Club.com Forced Induction 98 12-14-2013 01:34 PM
Sneak peek at new 57Xtreme? vividracing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-07-2013 02:24 PM
Sneak Peek! P&L Motorsports Stg.1 BRZ/FRS Turbo Kit. P&L Motorsports Forced Induction 179 01-31-2013 07:32 PM
AFE PROTOTYPE EXHAUST: SNEAK PEEK! autofashionfred Engine, Exhaust, Transmission 20 08-13-2012 01:22 PM
Tsukuba Circuit BRZ/FRS showdown Sneak Peek AVOturboworld BRZ First-Gen (2012+) -- General Topics 19 06-23-2012 11:13 AM
