go_a_way1
Old 05-27-2014, 02:36 PM   #1317
becauseracecar1
becauseracecar1's Avatar
Drives:
Nitrogen vs regular air in the tires for track day? Thanks!!
2014 Ultramarine Scion FR-S
facebook.com/86motorsports
becauseracecar1 is offline   Reply With Quote
Old 05-27-2014, 02:43 PM   #1318
ayau
Drives: Some rust bucket
Unless you can get nitrogen for free, I'd just use regular air and bleed as necessary. We're not professional racecar drivers here, lol.
The Following 2 Users Say Thank You to ayau For This Useful Post:
becauseracecar1 (05-28-2014), kavanagh (05-27-2014)
Old 05-27-2014, 02:48 PM   #1319
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
do you have the ability to completely suction/cycle out the regular air and then refill with only nitrogen.. and then have support for a nitrogen refill?
kinda pointless for the everyday joe
Old 05-27-2014, 02:54 PM   #1320
CSG David
CSG David's Avatar
You should just buy a good tire pressure gauge and a good bicycle pump.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
becauseracecar1 (05-27-2014), SirBrass (05-27-2014)
Old 05-27-2014, 03:12 PM   #1321
ZDan
ZDan's Avatar
Drives: '23 BRZ
Assuming motion ratios of 0.95 front, and 0.75 rear, look at this ratio:
Front effective spring = 550
Rear effective spring = 500 * 0.75 = 375
Front effective spring % = 59.45
Rear effective spring % = 40.54
Keep in mind that motion ratio in the rear is probably lower than 0.75, so my numbers are off.
Actually, it's worse than that.
Wheel rate is spring rate multiplied by the SQUARE of the motion ratio, so his wheel rates are:
550 lb/in * .95^2 = 496 lb/in front wheel rate
500 lb/in * .75^2 = 281 lb/in rear wheel rate
I'd swap the springs front to rear to get:
500*.95^2 = 451 lb/in front wheel rate
550*.75^2 = 309 lb/in rear wheel rate
And probably reconnect the rear sway, but then more likely to lift the inside rear...
How on earth did this car end up with 57/43 weight distribution?
Old 05-27-2014, 03:13 PM   #1322
CSG Mike
CSG Mike's Avatar
Multiple posts got combined into one post there.. >>,
Old 05-27-2014, 04:47 PM   #1323
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Every track rat should have one of each. Bike pumps can come in very handy!
dradernh is offline   Reply With Quote
Old 05-27-2014, 04:50 PM   #1324
CSG David
CSG David's Avatar
Everybody laughs at me for bringing a bike pump. I'm also the guy everybody asks to borrow the bike pump to pump up their tires after the track day.
See. I solved the obesity problem already.
Old 05-27-2014, 04:51 PM   #1325
jvincent
jvincent's Avatar
I brought a bike pump with me. Makes perfect sense to me.
Old 05-27-2014, 04:52 PM   #1326
gramicci101
Off Topic
A [ame="http://www.amazon.com/250-PSI-12-volt-Air-Compressor/dp/B000KHH3U8"]12V air compressor[/ame] wouldn't work?
*note: not recommending that specific air compressor, merely providing a representative example.
Old 05-27-2014, 05:05 PM   #1327
CSG Mike
CSG Mike's Avatar
You do realize you have a Honda air compressor in the trunk of your CR...
Old 05-27-2014, 05:09 PM   #1328
gramicci101
Off Topic
This is like the family that only communicates via text. Don't you guys work together?
The Following 4 Users Say Thank You to gramicci101 For This Useful Post:
ATL BRZ (05-27-2014), buddy32 (05-27-2014), CSG Mike (05-27-2014), kavanagh (05-27-2014)
Old 05-27-2014, 05:16 PM   #1329
CSG David
CSG David's Avatar
We work from everywhere. I AM BATMAN! Batman...baatman...ba...
Old 05-27-2014, 05:16 PM   #1330
CSG David
CSG David's Avatar
I'm not going to blow that one up from using it so much. It's also going to blow the fuse on non-CR cars too.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) -- General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) -- General Topics 20 01-10-2012 09:54 AM
