02-19-2015, 12:39 AM | #29 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Any comparisons on the power delivery of this engine compared to the FA20?
02-19-2015, 08:13 AM | #30 |
Dirt Trackin'
Drives: '13 Raven FR-S MT
This brings me back to the days of messing with my red-topped '91 MR2... That Glen character that Manji mentioned is quite the source of knowledge with these motors and has (last I read) a pretty nice set-up in his Celica. I know he used to post a bit on the mr2.com forums, but it's been a long while since I've been on there.
I'd like to see an FRS with a blacktop. I'm pretty interested in the weight difference. IIRC when I had the redtop pulled from the MR2 it seemed pretty heavy for a 4cyl engine. Classic Toyota (Yamaha?) iron, I guess. Also, check this out: www.beams-redtop.com Edit: Lots of useful stickies here: http://www.mr2.com/forums/forums/127-BEAMS-Owners-Group
The Following User Says Thank You to FReSh For This Useful Post: | CxG (10-26-2015) |
02-19-2015, 09:17 AM | #31 |
Drives: 2013 FRS, with boost by ATS Racing
Yup, I'm with ATS (I'm one of the two that boosted Aaron's car...which is now mine). He's known for awhile you are doing a beams swap, so you must have told him back then.
02-19-2015, 09:44 AM | #32 |
Drives: GT-86
The 3s ge is an awesome engine. You can hammer it for years as I did mine in my previous car and it just keeps on ticking. Also makes similar power to the fa20 but is no where near as fuel efficient.
Maybe the next gen fa20 will be as reliable and make much more power. Just as how the blacktop is a much better engine than the red top. As it is I wouldn't do a swap now. |
02-21-2015, 11:10 AM | #33 | |||
This is a blacktop swap just in case that wasn't clear. I don't have the exact differences in weight, but couple things to balance out, you have two aluminum heads on the FA20 and only one on the 3sge, I just packaged up a full set of FA20 heads yesterday and they weighed 88lbs boxed. I feel like the 3sge head will be slightly lighter than that. I am throwing out numbers but would guess 50lbs or less on the 3sge fully loaded head. So saving of 30lbs to give to the over weight cast iron block. I don't have full weight of an FA20 block but have the bare block numbers somewhere in the office and have other 4cyl cast iron blocks to get a rough idea of weight and will report back next week. Now the 3sge will definitely have the weight higher distributed. Quote:
I think a lot of that has to do with proper tuning. I will wager we will get similar gas mileage with proper EMS and tuning. |
03-21-2015, 06:31 PM | #34 |
Just figured I would post up a quick picture of the finalized setup. Made 323whp at 8psi revving to 7600rpm before driving it 16hrs to TX2K. When I find some time upon returning, will turn the wick up a little and see what it makes at 8000+RPM.
The Following 17 Users Say Thank You to Dustin@Dynosty For This Useful Post: | civicdrivr (03-22-2015), CxG (10-26-2015), Dimman (03-23-2015), Draco_PR23 (03-21-2015), finch1750 (03-21-2015), geezer86 (03-22-2015), hamzam (03-24-2016), hmong337 (03-21-2015), Hyper4mance2k (01-15-2016), ill86 (08-04-2015), Manji (03-21-2015), mrk1 (03-27-2015), N_A (03-23-2015), themadscientist (05-11-2016), Tristor (12-04-2018), trueno86power (03-22-2015), yo joshman (08-05-2015) |
03-21-2015, 07:59 PM | #35 |
Emperor JDM
This is how Toyota should've built this car!
That's awesome powet for only 8psi. That's better than every stock internal FA20 bolt-on turbo setup I've seen. Cheers. Will be checking on your progress.
The Following User Says Thank You to hmong337 For This Useful Post: | acro (03-21-2015) |
03-21-2015, 10:14 PM | #36 |
Toyotas don't have boxers
Drives: GTV86, ISF, TE27
Nice work. It'll keep making power to 8000rpm (that's where mine makes peak power) but it'll fall away in a hurry after 8200.
This is what happened to mine a week ago.. [ame="https://www.youtube.com/watch?v=MNhcI4py8Lg"]3SGE Beams drops valve mid drift - YouTube[/ame] Too many drift runs in 4th gear, sitting on limiter I'm flattered you copied my plenum
03-22-2015, 12:45 AM | #37 |
Scrape Master
Drives: Goal: Oldest FRS State Side
Dont know if it's because I never grew up with the MR2 but i dont see the point at all in swapping this engine. Maybe this swap would be worth it in a car that has a poor engine like a ae86 but I just cant see the point in a twin. It's a old engine, heaver, and just the cost of the swap + a turbo just dosent make sense to me. For anyone who is going to comment on my post saying "twins cant hold power" im going to link you this post http://www.ft86club.com/forums/showp...87&postcount=9 All those threads you have read from engines blowing are from poor installation or a bad tune.
03-22-2015, 03:50 AM | #38 |
Can't tell if trolling or just stupid
The Following 3 Users Say Thank You to Manji For This Useful Post: |
03-22-2015, 08:55 AM | #39 |
Drives: frs
I dont like the boxer anyomore, i'd like to see those engines with a itb. Its possible to achieve 200+ hp @ 10k rpm?
03-22-2015, 09:39 AM | #40 | |
Thank you for your comments, but this is the swap forum, if you do not want to contribute to it with any thing other than confrontational comments you can please exit this thread. It is comments like these all over the board from people who just want to start a pissing match on the forums that create such a negative environment that no one wants to post any useful information any more and why intelligent vendors shy away from posting anything at all. IF you decide to combat again, I will report you to the moderator of this section. |
The Following 5 Users Say Thank You to Dustin@Dynosty For This Useful Post: | civicdrivr (03-22-2015), CxG (10-26-2015), Hyper4mance2k (01-15-2016), Manji (03-22-2015), Sportsguy83 (01-10-2017), Tristor (12-04-2018) |
03-22-2015, 10:51 AM | #41 | |
Scrape Master
03-22-2015, 10:55 AM | #42 | |
Emperor JDM
Similar Threads | ||||
High beams | DjDATZ | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 09-10-2014 07:49 PM |
3000k HID low beams | WolfsFang | Cosmetic Modification (Interior/Exterior/Lighting) | 26 | 08-21-2013 09:41 PM |
24 Watt LED DRL/Hi beams! | Ironsquid | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 05-20-2013 02:45 PM |
High Beams | DC-FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 01-12-2013 10:44 PM |
High beams?!?! | gmanculb | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 10-02-2012 04:51 PM |
