GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
04-13-2024, 02:16 PM | #1 |
Drives: 2024 MT Toyota GR86
NO SPARE for 2024??
Hey all,
I noticed after I purchased my '24 86 there was no spare in the trunk. Is that by design or is there some aftermarket kit I am not aware of? Thanks in advance.
2024 Toyota GR86
2013 Scion FR-S |
04-13-2024, 03:07 PM | #2 |
AutoX-10/10ths every run
Looks like it isn't included:
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
The Following 2 Users Say Thank You to whataboutbob For This Useful Post: | Borrowed Time (04-21-2024), briang0901 (04-13-2024) |
04-13-2024, 03:16 PM | #3 |
Drives: '23 BRZ
I swapped over the spare from my '17 PP along with the styrofoam bits, all fits
The Following 3 Users Say Thank You to ZDan For This Useful Post: |
04-14-2024, 07:42 AM | #4 |
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
Do you know if the Styrofoam placeholder out of the '24 models fits well on the first gens? The OEM spare doesn't fit over my brakes, so no sense in lugging it around. It would be nice to have an OEM solution to filling that gap though.
04-14-2024, 08:11 AM | #5 |
Drives: '23 BRZ
I can't think of a reason the '22+ stuff shouldn't fit in 1st-gen tire well...
04-14-2024, 10:57 AM | #6 | |
Drives: BRZ limited
Is the tire well also fitting the 18”. Not sure how to organize it for the 18”. Also, the spare needs to be something that clears the Brembo. Sent from my iPhone using Tapatalk |
04-14-2024, 01:32 PM | #7 | |
Drives: BRZ 2023
https://www.*********/threads/how-to....3808/#replies |
04-14-2024, 01:42 PM | #8 |
Drives: BRZ 2023
Last generation twins came with spare in rear which had 16" wheel but there was also a different spare for performance package. Performance package spare had 17" wheel in order to fit over Brembos.
Not specific to PP or regular Spare Tire Bolt : 901720002 Spare Tire Washer: 97047FG000 Performance specific parts PP Spare Wheel: 28151FE030 PP Spare Tire: 28121VA050 PP Spare Foam Insert: 95086CA070 PP Spare Foam Spacer: 97046CA000 Regular spare Spare Wheel: 28151FJ031 Spare Tire: <Still looking> Spare Foam Insert: 95086CA040 Spare Foam Spacer: 52153PA181 |
The Following 2 Users Say Thank You to ruturaj001 For This Useful Post: | Busybee (04-14-2024), Ohio Enthusiast (04-14-2024) |
04-14-2024, 01:51 PM | #9 | |
Drives: BRZ limited
Thanks for posting here. Was checking the tread in the other GR86 forum. All great info. Getting a trueno so I assume I will need all parts. Was previous gen PP cars 18” and spare 17? If that’s the case I can do the same set up. But read that having the 17 spare on the rear there will be 0.2 difference. Will that affect? I wish that the 18” wheel and tires fit the styrofoam directly so no change will be needed . Sent from my iPhone using Tapatalk |
04-14-2024, 01:57 PM | #10 | |
Drives: BRZ 2023
You never install spare in rear. If rear has puncture then you have to put spare in front and install front in rear. |
The Following 2 Users Say Thank You to ruturaj001 For This Useful Post: | Busybee (04-14-2024), Stephen W. (04-24-2024) |
04-14-2024, 02:04 PM | #11 | |
Drives: BRZ limited
Thanks for all the great info. Looks like getting the below parts and a fitting jack (I think someone had the part # in the forum) will solve all the issue. Spare Tire Bolt : 901720002 Spare Tire Washer PP Spare Wheel: 28151FE030 PP Spare Tire: 28121VA050 PP Spare Foam Insert: 95086CA070 PP Spare Foam Spacer: 97046CA000 Sent from my iPhone using Tapatalk |
04-14-2024, 02:06 PM | #12 | |
Drives: BRZ 2023
The Following User Says Thank You to ruturaj001 For This Useful Post: | Busybee (04-14-2024) |
04-14-2024, 02:34 PM | #13 |
Drives: BRZ limited
Just curious!
Does the GR86 come with the 3 pieces Styrofoams on each side and behind the seat which fits the jack and other pieces Thanks Sent from my iPhone using Tapatalk |
04-14-2024, 03:56 PM | #14 |
Drives: 2023 Gray BRZ
Perhaps a little off-topic... I think a plug-kit + pump + jack/wrench is the best combo for these cars. Just remove the tire, plug it, inflate, then re-mount. Easy peasy. (And there appears to be a cosmic rule that one will not have a flat if properly prepared for it.)
The Following User Says Thank You to OldBiker For This Useful Post: | Busybee (04-14-2024) |
Similar Threads | ||||
2024 ts trim | Shub Deetle | BRZ Second-Gen (2022+) -- General Topics | 30 | 01-25-2024 07:38 PM |
S-FR.... or not (TAS 2024) | spike021 | Other Vehicles & General Automotive Discussions | 7 | 01-23-2024 05:30 AM |
PRICING ON 2024 BRZ | ruturaj001 | BRZ Second-Gen (2022+) -- General Topics | 12 | 11-16-2023 12:23 AM |
2024 BRZ tS Releaved | Rainy | BRZ Second-Gen (2022+) -- General Topics | 55 | 08-12-2023 04:20 AM |
Performance Package spare tire vs. regular spare | JeremyR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 67 | 09-22-2022 09:36 PM |
