Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
02-22-2023, 11:44 PM | #1 |
Drives: 2013 AT Firestorm FRS
Electric Power Steering Gone
Hey all! I have a '13 with around 75k miles that's never been in an accident. A few days ago, the steering became very light and almost felt as if the steering input had a deadzone. Checked the tire pressure and everything is OK. This happened in the middle of a nice drive.
I'm thinking my electric power steering EPS has overheated and may have failed. I've found some older threads on this, but just wondering if anyone has dealt with this issue. I spoke with someone at my local Toyota dealership because this EPS failure was part of a Toyota Australia recall and covered, but is not a recognized recall in the United States. Dealership basically said not our issue. Has anyone had any experience with this? I'm looking at a ~$1,000 in parts alone if the work is done by myself and a buddy. Would rather put that to a few track days coming up I always thought if the electric steering motor went, the steering would become very stiff, as if the ignition wasn't on. But the steering almost feels as if the wheels aren't on the road. Lost complete feel of the road, so it may have overheated and became faulty. |
02-23-2023, 12:41 AM | #2 |
has a funny hat
Drives: 2014 BRZ Limited
Any codes?
I would also expect it to fail heavy if it completely failed, but if the control circuit is having issues or there’s a bad sensor it could be in fail safe mode which sets the assist level equal to the assist at something around 45mph. I picked up a couple EPS units and columns (for other projects) from a salvage yard for under $100ea. Might be a little more costly in your region, but you should be able to get a better parts price than $1000 if you need. |
The Following 3 Users Say Thank You to pope For This Useful Post: |
02-23-2023, 04:22 PM | #3 | |
No lights on dash but will plug the car in this weekend. Was thinking of picking a used unit for under $200 in my area, worst case scenario I can just return it if the part is faulty. |
02-24-2023, 10:50 AM | #4 |
Drives: 2013 Scion FR-S Raven 6MT
The steering assist went out on my '13 a couple of weeks ago. It was intermittent, usually working while after start and then quitting after a few miles.
Took it in for repair, expecting at least a $500 repair. It turned out to be a corroded connection which they cleaned and reconnected for less than $100. The tech said this is a very common problem in these cars. Hopefully this is your problem too. Sent from my motorola one 5G ace using Tapatalk
Stay squatchy, my friends
The Following 4 Users Say Thank You to jeffchap For This Useful Post: |
02-25-2023, 09:48 AM | #5 | |
Drives: 2013 frs base
The Following 3 Users Say Thank You to blsfrs For This Useful Post: |
03-06-2023, 02:08 PM | #6 |
Update: I purchased a replacement EPS column unit for 100 bucks used off eBay. I'm also going to replace the Damper Electric Power Steering Motor Shaft (cog) which is a $15 part.
I'm opting to leave the EPS computer module as is for now. Will report back if this fixes my issues |
03-15-2023, 08:14 AM | #7 |
Drives: Gt86
Good morning ,
here I come to you because I have a problem with my direction of gt86 2012. 1 year ago I bought a hub with a tuliper steering wheel, but unfortunately I did not fit the steering wheel properly. following this I have the abs and esp warning lights which came on after a few kilometers and went out after stopping the engine. I changed my sensor in the bracing but not the airbag sipriale. but I always have a problem with the car when I drive fast I have the impression that the car deports from left to right. |
03-15-2023, 08:17 AM | #8 |
Drives: Gt86
the lights are no longer on but I still have a weird behavior.
as if the direction had a game or that it does not harden. these asser disturbing . I made a gear adjustment (geometry + parallelism) |
03-15-2023, 01:40 PM | #9 |
Drives: Subaru BRZ
Steered the thread well and truly off the track..
04-04-2023, 02:10 AM | #10 |
Drives: Frankenstein of parts
It went to limp mode. It lost can communication with ABS most likely.
The Following User Says Thank You to Nmstec For This Useful Post: | blsfrs (08-16-2023) |
08-15-2023, 02:43 PM | #11 | |
Proud of BOXER
Drives: Subaru Boxer
BUMP for updates on this.
The Following User Says Thank You to Clipdat For This Useful Post: | blsfrs (08-16-2023) |
08-16-2023, 12:45 PM | #12 | |
Drives: '13 BRZ TLM Spec
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
04-18-2024, 02:24 AM | #13 | |
Drives: 2013 Genesis Sedan
04-21-2024, 08:54 AM | #14 |
What codes are present?
Tags |
eps, steering, steering motor |
Similar Threads | ||||
Electric Power Steering with no CAN | ML | Software Tuning | 9 | 03-12-2023 12:51 PM |
Electric power steering and steering column part info | raspec | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 10-12-2021 05:27 PM |
Electric Power Steering | oziel | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 01-24-2021 01:06 AM |
Electric Power Steering | ArtS | Electronics | Audio | NAV | Infotainment | 0 | 10-31-2016 08:19 AM |
Electric power steering | madfast | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 10-13-2011 10:11 AM |
