Old 05-05-2013, 02:46 PM   #1
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
Raspy header and weird noise
This is my current setup,
Fa20club 4-1 EL header
Agency power over/front pipe
Magnaflow catback
i'm catless
It's raspy after 3k RPM how could I make it less raspy? Should i change my over/front pipe to get a catted one?
Also,
I get this weird noise in the front that sounds like a tractor , flutter noise.
Nothing is leaking, i got it triple checked at my garage guy.
Could i maybe need a bigger gasket for the header?
Also would the raspy go away once I go turbo?
Scalzo is offline   Reply With Quote
Old 05-05-2013, 03:16 PM   #2
mxsled
mxsled's Avatar
Drives: Audi A3 2012
Magnaflow catback
i'm catless
Also,
If your headers are catless you should go with a catted frontpipe
Imo,for having a good exhaust sounds(not to raspy)you need at least one cat
do you have any videos of how it's sounds?
Moto east Ecutek /JDL UEL Header/Nameless Performance axleback exhaust-Motiv overpipe/Full Perrin CAI/BC Racing Coilover/Traklite angle 18x9/Federal 595 RS-R (245-35-18)/Blackhousing,hid 4300k headlights/Crystal eyes taillight/Anarchy Motive Heavy ShiftKnob/Cusco Sport pedals/Jpm Coachworks alcantara dash panel,cluster,shift boot,
mxsled is offline   Reply With Quote
Old 05-05-2013, 03:18 PM   #3
Opposed
Drives: 2013 Asphalt FR-S
A catted front pipe will help. I don't think 100%, but it will make quite a difference. I do believe that a turbo will muffle some of that in the future as well.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 05-05-2013, 04:29 PM   #4
chutrain
chutrain's Avatar
Drives: WRB BRZ
A resonator will help a good amount. I just put one on mine that had the same issue after 3k rpm.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 05-06-2013, 12:49 AM   #5
Scalzo
Scalzo's Avatar
Shouldn't it come with the catback and the front pipe?
I was thinking of putting back my stock front pipe/over pipe, and when i get the turbo i'll put the front pipe/ over pipe back in.
Hmmm, i might just put the stock front pipe/over pipe back..
Funny thing is about an hour after posting, i got a ticket for my exhaust lol
I'll be posting a video tomorrow
it's only raspy when i hit the gas or drive in high rpms 3.5-4
Old 05-07-2013, 11:59 PM   #6
Scalzo
Scalzo's Avatar
I ordered the cat for the header,
the only problem now, it makes a tracktor noise when i accelerate like a fluttering noise, sounds like something in the front.
Old 05-08-2013, 12:21 AM   #7
86pro
Drives: frs
flutter noise at low rpm is just how the engine sounds. I know the sound. The raspy can be easily fixed with just a resonator or put back the two with magnaflow ones. You in ontario?
86pro is offline   Reply With Quote
Old 05-08-2013, 12:23 AM   #8
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
It could be the engine, or an exhaust leak.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 05-08-2013, 12:44 AM   #9
Scalzo
Scalzo's Avatar
I brought the car to two garages and they said no exhaust leak but it sounds like a flutter super annoying. Magnaflow ones are in , it's because i'm catless no cats.
Flutter noise at low RPM, never heard it before until i put the catless headers + overpipe + front pipe catless
I'm in montreal
Old 05-08-2013, 01:34 AM   #10
Hawaiian
That guy
Hawaiian's Avatar
I'm in montreal
Check the frame where the overpipe crosses. The first 2 times I had the header installed it was fine, but the third time it wasn't hung properly and rubbed the frame. At higher rpm the sound of the engine would mask it, but it was audible at lower rpm, and when I would turn at speed.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 05-08-2013, 01:38 AM   #11
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Without cats it'll still be raspy with a turbo.... I was full catless invidia q300 on my wrx and I loved how it sounded but it was loud
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 05-08-2013, 01:45 AM   #12
Scalzo
Scalzo's Avatar
It was pulled further away from the frame already, it makes like a nasty ffffff ffffff tracktor noise, its weird. only at low RPMs, i'm thinking it could be because im catless in videos you dont hear it but in person you do.
Hmm, starting to get some cats then lol
Old 05-08-2013, 09:00 AM   #13
mad_sb
if you have an exhaust leak you should be able to see it by inspecting all the gasket locations with a flashlight, all around the ports / joints. You will see black soot. You have to really look for it, not just half ass it. I suspect the shops you had look at it may have just glanced at it or put it on the lift and ran it at idle.
Leak or hitting are most likely as others have said.
Old 05-08-2013, 09:05 AM   #14
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Catted/resonated front pipe will help a lot, and the cat in the header will also help. The resonator in the Magnaflow midpipe is rather short. A longer one like in the Perrin/OEM resonated catback will likely get rid of most if not all the rasp.
Heard a very weird noise today FlyingFool Engine, Exhaust, Transmission 1 03-24-2013 01:08 PM
Here's a weird one...noise hours after turning off sa1126 Issues | Warranty | Recalls / TSB 12 10-12-2012 03:15 PM
weird plastic squeaking noise (back seats) whyreeto AUSTRALIA 5 09-17-2012 01:34 AM
Weird noise Touge_ninja Scion FR-S / Toyota 86 GT86 General Forum 3 08-28-2012 01:46 AM
