Old 04-21-2014, 03:00 PM   #15
Los
Los's Avatar
Drives: '13 BRZ Limited DGM
@joergasm Thanks for the DIY so those door lights are actually functional haha. Also changed out my dome, vanity, trunk, and license plate lights to LED as well. Looks a lot better now.
@kakarot1657 Glad it's not just me on the positioning of those lights. Thought that was quite weird.
Los is offline   Reply With Quote
Old 05-15-2014, 05:06 AM   #16
jbsali
jbsali's Avatar
Drives: 2014 Subaru BRZ (Limited)
followed your DIY and didn't blow the $400 fuse! thanks @joergasm
jbsali is offline   Reply With Quote
Old 05-15-2014, 08:46 AM   #17
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Originally Posted by joergasm View Post
*will edit and make cleaner after, at work and bored so made this quick*
I figure I'd go into detail ......
Can you tell me the part no. of your clear lens? In Europe we have mandatory red lens over clear bulbs and without a Canadian or Japanese VIN Number it's difficult to find right parts number. Thanks!
Trap63 is offline   Reply With Quote
Old 06-15-2014, 07:24 PM   #18
joergasm
joergasm's Avatar
Drives: Subaru BRZ 2013 - SWP 6MT
Originally Posted by DrDuquette View Post
I went and took off the red covers. Buy the way, put the screwdriver on the hinged side of the light to pop off the cover on the left side of the car worked perfect. Sure enough, no light or wires that I could see. Means we will have to get power. Now finding power for when the doors open might be fun to find.
Aww man that is so weird :S Not sure what to say about that, Haven't been on here in a while!
I wish I knew, the other guy I multi-quoted also has the red one's. Not sure if he ended up swapping it out!
Haven't been on here in forever, didn't think this would help many people but glad it did/shed some light!
joergasm is offline   Reply With Quote
Old 06-21-2014, 01:07 PM   #19
inertia
inertia's Avatar
Have any of you encountered an issue with the courtesy light stop working after installing a LED bulb? Even though you put the original bulb back in, it still does not work. How do I reset this?
inertia is offline   Reply With Quote
Old 06-23-2014, 12:11 PM   #20
mikepaul21
mikepaul21's Avatar
Drives: 2013 Subaru BRZ
I did the same thing and I love it... It's the little things you do to your car that make it "yours". I was a little worried that it would be too bright because I got the brightest ones I could get through Diode Dynamics but I'm glad I went with these. I had to take the 3m tape off the back so it would fit in there though.
mikepaul21 is offline   Reply With Quote
Old 01-02-2015, 10:04 PM   #21
Hachi-Roku BRZ
Hachi-Roku BRZ's Avatar
Drives: 2015 Subaru BRZ limited MT
Thanks for the nice tutorial! Got my LEDs today and didn't know if there was an alternate method to just prying it open, but i can see that the clip is shaped in a way this wont be an issue.
Hachi-Roku BRZ is offline   Reply With Quote
Old 01-02-2015, 10:36 PM   #22
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question
Anyone know if the wiring harness is available from Subaru to add these lights into the housing on the FR-S?
Chad86 is offline   Reply With Quote
Old 05-26-2018, 07:00 PM   #23
COBlue
COBlue's Avatar
Drives: 2017 Subaru BRZ Limited PP
With the 2017 BRZ model changes, just thought I'd confirm for everyone this is all the same for 2017,just did mine.
COBlue is offline   Reply With Quote
Old 09-10-2018, 11:10 AM   #24
713_GT86
713_GT86's Avatar
Drives: 2015 Series Blue BRZ
Where can I pick up a set of these EU style covers?
I want to add/upgrade mine to these red lenses/covers as well as my dome light.
713_GT86 is offline   Reply With Quote
Old 09-13-2018, 03:06 AM   #25
_kongzilla_
Drives: Raven FRS
I used these for my frs
https://www.86speed.com/led-door-cou...86-subaru-brz/
Yes they are direct replacements for the BRZ, but i also order these pigtails.
https://www.aliexpress.com/item/10pc...3da24c4d8dNhEh
They sorta make in seem oem lol.
For the passenger side i ran one wire to the battery and the other to the pink wire in the domelight.
For the driver side i ran it to the dome and further down to passenger side.
from there i tapped the driver side into the passenger side wires.
I did this way because i also had side mirror lights.
_kongzilla_ is offline   Reply With Quote
Door Courtesy Lights on an FR-S: Basic DIY added boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 28 05-24-2024 02:42 PM
BRZ Driver's Door Courtesy Light Won't Work delusional Issues | Warranty | Recalls / TSB 31 05-29-2022 08:15 AM
How to change BRZ fog light bulb? chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 19 05-30-2020 06:31 PM
Passenger Door Courtesy Light Wont Turn Off zex Issues | Warranty | Recalls / TSB 12 10-04-2013 02:31 PM
