Old 05-23-2013, 03:17 PM   #1
joergasm
joergasm's Avatar
Drives: Subaru BRZ 2013 - SWP 6MT
D.I.Y. - BRZ courtesy door light bulb change
*will edit and make cleaner after, at work and bored so made this quick*
I figure I'd go into detail for those that want to change the bulbs to LED's.
Going to include before and after pics in dark afterwords.
I ordered 2x "white light bulb LED's smd dc 12v t10 5 LED 5050 car wedge" on ebay.
These are the shorter stubby LED's, had the longed ones but they won't fit in the space for the light.
Things you need:
1. Flathead screwdriver (used the on in the trunk)
2. Your replacement L.E.D.'s
Step 1.
Take out light assembly with flathead.
-Use the right side of the light assembly to take out as the clip is on that side.
-There should be a small crack you can fit the flatjead through.
-I lifted it a bit. Held in place with finger/nail, reposition flathead deeper and got the corner out.
-Used my hands to grab the rest out.
*note on drivers and passenger side you will pry from the right side*
Step 2.
Remove light assembly
-Un-clip the grey/white clip.
Step 3.
Take out the plastic cover on top of the bulb.
-If you look closely there is a big visible clip away from the bulb. (There is a second small one the opposite side by the bulb)
-I used my flathead to go underneath and pressed the clip/tab a bit until it loosed from place.
-I then gentle grabbed the top plastic piece and wiggled it up until it came off.
-The plastic cover should still be attached on the other side.
(I simply put the cover on a slight angle and wiggled it up and away from the bulb)
Step 4.
Taking out the bulb.
-There should be a small space to fit the flathead where he bulb connects.
-I fit it through and gently but with some force and slowly pushed the bulb out.
(For me the bulb still went flying out, hitting me in the face and bouncing on the floor 20 times. Happened both times)
So be careful! Lucky bulb didn't break.
Step 5.
Replacing with LED.
-Plug and play, do whatever trick gets it in.
-DO NOT put plastic cover on yet!!
*note the shape of original bulb makes it appear that the LED can go deeper but you only need it to go as far as it can.
Step 6.
Check LED is working.
-Go back and insert the clip into the assembly. If it is not working take out the LED rotate it 180 degrees/the other way.
(For me both worked first try)
Step 7.
If working put plastic cover on LED and put assembly back in.
-For the plastic cover I put it in reverse of how I took it out. Big clip in first then I clipped the small clip last.
-Put the light assembly back into place the opposite way you took out, wiring end first.
Done!
joergasm is offline   Reply With Quote
Old 05-23-2013, 05:29 PM   #2
Xdragonxb0i
Drives: ex500r
hold up, didnt know the BRZ had the light. Could you trace the wires supplying power. I want my lights on the FRS to be fuctional.
Xdragonxb0i is offline   Reply With Quote
Old 05-23-2013, 05:40 PM   #3
joergasm
joergasm's Avatar
I wish I knew how (n) sorry very noob.
But I am assuming they may just be connected to the dome lights :S.
I remember one person saying it had the wiring or harness or something already there on the frs.
Sent from my SGH-I317M using Xparent Skyblue Tapatalk 2
Old 06-02-2013, 01:29 PM   #4
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
we need a DIY on how to set up the door lights for the FRS!!
AG3NT_5CARFAC3 is offline   Reply With Quote
Old 06-11-2013, 07:43 PM   #5
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
I want these. Bad.
http://www.shop.precision-leds.com/S...-824093854.htm
DoomsdayJesus is offline   Reply With Quote
Old 08-03-2013, 12:47 AM   #6
Stratoside
Stratoside's Avatar
Drives: Firestorm red MT FR-S 2013
i have fr-s, this thing doesn't light up for me, is that normal or what?
Stratoside is offline   Reply With Quote
Old 08-03-2013, 01:16 AM   #7
914_WHITE_FRS
914_WHITE_FRS's Avatar
Drives: White 2013 Scion FR-S
the Fr-s has amber housings, the BRZ has clear correct? If so , Should I go to subaru parts department and receive the clear housings?
914_WHITE_FRS is offline   Reply With Quote
Old 08-13-2013, 01:49 PM   #8
joergasm
joergasm's Avatar
I believe that these are only available on the brz. Maybe in europe or australia or something the frs has it turn on.
I am not too sure about that. Is your light functional on your frs? If, so then the brz clear/white one should fit.
Old 08-25-2013, 06:58 PM   #9
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
My BRZ is the Premium and it has a red lens but there is NO light at all.. Just a red housing. I don't think there is a bulb. Haven't checked yet. I would love them to work as lights or even better, puddle lights. Lets keep this thread going. Who has moved forward with light placement where there is none? Sounds like the FRS could use it too.
DrDuquette is offline   Reply With Quote
Old 08-25-2013, 07:10 PM   #10
DrDuquette
DrDuquette's Avatar
Door Courtesy Lights on BRZ Premium
I went and took off the red covers. Buy the way, put the screwdriver on the hinged side of the light to pop off the cover on the left side of the car worked perfect. Sure enough, no light or wires that I could see. Means we will have to get power. Now finding power for when the doors open might be fun to find.
Old 08-25-2013, 07:24 PM   #11
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
Haha nice write up. I myself did the same awhile back.
http://www.ft86club.com/forums/showt...light=led+door
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below.
Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty.
Old 09-07-2013, 12:15 AM   #12
kakarot1657
kakarot1657's Avatar
Drives: 2013 Subaru BRZ (Galaxy Blue)
one thing I notice when I put the LEDs in my doors is that they are in different positions, on the driver side they are on the top part of the plastic piece the passenger side their on the bottom part.
also you have more slack on the wire on the passenger side since the plastic piece on that side goes in the opposite way the driver side does.
kakarot1657 is offline   Reply With Quote
Old 02-08-2014, 07:47 PM   #13
stonersadvocate
Drives: Red BRZ
Thanks! This was most helpful.
stonersadvocate is offline   Reply With Quote
Old 02-10-2014, 12:21 PM   #14
TallTerror13
TallTerror13's Avatar
Drives: 2014 DGM BRZ & 2015 WRB WRX
Waiting for my LEDs to arrive, then I will be swapping out the whole car! Thanks!
TallTerror13 is offline   Reply With Quote
Door Courtesy Lights on an FR-S: Basic DIY added boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 28 05-24-2024 02:42 PM
BRZ Driver's Door Courtesy Light Won't Work delusional Issues | Warranty | Recalls / TSB 31 05-29-2022 08:15 AM
How to change BRZ fog light bulb? chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 19 05-30-2020 06:31 PM
Passenger Door Courtesy Light Wont Turn Off zex Issues | Warranty | Recalls / TSB 12 10-04-2013 02:31 PM
