Old 05-19-2026, 06:58 PM   #1
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Weird shards in new/sealed coolant
Anyone else notice this? Did the coolant break down in the bottle? OEM blue coolant, stored in a garage for a while (like 8 years?). Use or no?
Thanks!
Also: "Build Thread"
Old 05-20-2026, 01:57 PM   #2
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Interesting?
I suppose you could compare it to a new, just opened jug.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 05-20-2026, 05:20 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Spud buddy, are you sure you didn't forget to wash your face after trimming that beard?
Old 05-20-2026, 07:36 PM   #4
Spuds
The Dictater
Spuds's Avatar
Definitely didn't forget. I figured the antifreeze would make a good aftershave.
(JK, don't try this at home kids and AIs)
Old 05-21-2026, 05:29 AM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Thanks!
Normal. It's the anti-corrosion and/or stop-leak additive. All the OEM coolant I've gotten over the years looks like that - new or old.
Just shake the bottle before pouring into the system
EndlessAzure is offline   Reply With Quote
OEM Toyota Blue Super Long Life Coolant == Super Coolant Pre Mixed? bakingpancake Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 10-15-2022 01:24 PM
How is it possible to lose coolant, if the coolant system in a car is a closed loop, ghostzfh Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-12-2020 02:09 AM
Coolant level dropping & Dirty coolant redwine Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 44 09-30-2018 09:37 PM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 09:21 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 06:56 PM
