Old 10-18-2013, 08:20 PM   #15
zoomzoomers
zoomzoomers's Avatar
Originally Posted by frs10 View Post
so i got a torque wrench that is 10-75lbs, set the torque to 12 and tried to install the grimmspeed strut bar and snapped on of the bolts off... now i have no idea what to do...
What??? How did you do that? Are you sure you set the TW to the proper setting before tightening the bolts?
Old 10-18-2013, 08:52 PM   #16
frs10
Drives: tezla
yeah, the top of the bolt is snapped off on the passenger side, the lower one, closer to the bumper...
i have the other 3 installed... how do i replace that single bolt?
frs10 is offline   Reply With Quote
Old 10-18-2013, 09:04 PM   #17
CSG Mike
CSG Mike's Avatar
at low torque settings, the "click" is very, very soft/subtle.
12 lb/ft is VERY little force. It's less than "hand tight". Turn your torque wrench VERY gently. You will barely feel it, if at all.
Old 10-18-2013, 09:07 PM   #18
frs10
Drives: tezla
so what do you guys suggest now? how do i replace this broken bolt? is it ok to drive with only the other 3 bolts attached?
Old 10-18-2013, 09:09 PM   #19
wlwarfield
VTECLOL
wlwarfield's Avatar
Drives: 2011 STi & 2013 F150 SVT Raptor
I have owned a Craftsman 1/2" drive torque wrench for 3 or so years. It's always been accurate and never failed on me.
follow me on Instagram @wlwarfield
OFFICIAL Texas BRZ, FRS, GT86 Facebook Page
OFFICIAL NM86CLUB Facebook Page
2011 Subaru Impreza WRX STi sedan
2013 Ford F-150 SVT Raptor
wlwarfield is offline   Reply With Quote
Old 10-18-2013, 10:27 PM   #20
CSG Mike
CSG Mike's Avatar
I'm not 100% sure which bolts you're talking about. Can you upload a pic please?
Old 10-18-2013, 10:33 PM   #21
frs10
Drives: tezla
Old 10-18-2013, 10:47 PM   #22
CSG Mike
CSG Mike's Avatar
I"m not sure if that bolt is welded in or not, but you'll be okay for now. I'll take a look the next time I have the CSG BRZ in my possession...
Old 10-18-2013, 11:06 PM   #23
cnk
Drives: '13 DGM BRZ Limited
Posted this in your other thread, but here is another post that addresses your issue: http://www.ft86club.com/forums/showt...hlight=snapped
As for torque wrench settings, I don't normally trust the settings that are at the extreme bottom and top settings. For those nuts that only require 12-17 ft-lbs of torque I use a in-lbs torque wrench so that I can set it in the middle of it's working torque range. That gives you a more solid click. I think I have at least 4 torque wrenches so that I can cover all ranges I'll ever need without having to go to their high/low settings.
Old 10-19-2013, 08:17 AM   #24
frs10
Drives: tezla
i posted in there but OP never came back to the thread to tell us what happened...
Old 10-26-2013, 05:04 PM   #25
jflogerzi
jflogerzi's Avatar
Just got a mailer from harbor freight. 10$ for there torque wrench. I need to pick up another pair of jack stands. You just can't beat there prices.
Old 06-07-2017, 03:48 PM   #26
TheWhiteWizard13
TheWhiteWizard13's Avatar
Drives: 2013 Subaru BRZ with Invidia N1
Originally Posted by Gary in NJ View Post
IMO, you need three torque wrenches:
1/4-drive in inch/pounds
3/8-drive in a 10 to 100 (give or take) foot/pound range
1/2-drive in a 20 to 200 (give or take) foot/pound range
There is also 3/4-drive in a 50 to 300 range, but unless you are working on diesel trucks, you wont have much use for it.
If you can only afford one, the 3/8 is the one to start with. I have always had good experience with Craftsmen and Snapon tools. Booth have a lifetime warranty. DO NO BUY TOOLS FROM Harbor Freight. They will piss you off and you'll end up buying one of the above brands anyway. Buy Once, Cry Once.
Digital vs non-digital, I prefer the non-digital. What ever model you get, only store it set to zero, otherwise it will loose its calibration over time.
so if we should start with the 3/8 torque wrench then what is the purpose of the other 2?
TheWhiteWizard13 is offline   Reply With Quote
Old 06-07-2017, 04:04 PM   #27
The idea is to select the torque wrench based on the application. Use the one in which the target torque is closest to the middle of the range of the wrench.
Strain measurement devices tend to be most accurate in the middle of their range so the same holds true for things like pressure gauges, bathroom scales, etc. It's just a basic rule of thumb.
Old 06-07-2017, 06:34 PM   #28
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
like others said i have both torque wrench 3/8 & 1/2... no problem so far.
less than 30 ft/lb i dont bother use torque wrench that much.
Socket set and torque wrench Ty89m Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 07-29-2013 01:46 AM
Brownline digital torque wrench qoncept Mechanical Maintenance and Tools 0 06-28-2013 12:20 PM
Torque Wrench options FRiSson Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 03-14-2013 03:29 PM
Torque wrench... Vendors welcome Freeman Off-Topic Lounge [WARNING: NO POLITICS] 8 01-23-2013 06:30 AM
Which type of torque wrench do you prefer? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 07-11-2012 05:17 AM
