Old 01-31-2014, 08:37 PM   #155
Cessblood
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
Dat boosted life.....
You're set up is freaking awesome
Cessblood is offline   Reply With Quote
Old 02-02-2014, 10:25 AM   #156
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thanks!! It all came together nicely.
Old 02-02-2014, 09:10 PM   #157
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Nice meeting you David!
BTW guys this kits looks twice as good in person!
Ironsquid is offline   Reply With Quote
Old 02-02-2014, 10:55 PM   #158
Sportsguy83
Drives: Limited BRZ
And ^^ car too
Old 02-02-2014, 10:56 PM   #159
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
And ^^ car too
Wait there was a car?
Old 02-02-2014, 10:58 PM   #160
Sportsguy83
Drives: Limited BRZ
Dyno tuning has started for my KAB Customs ( @KAB-FRS ) turbo kit. @jamesm spent a good amount of time dialing it in. Still a work in progress, but looking good nonetheless!! 317 WHP/ 232 WTQ on 93 Pumpgas, Only 10.5 PSI. When the dip is tuned out (some fuel adjustments needed but ran out of time in the Dyno), I expect to be between 330-340 on pumpgas.
Dyno AFR reading is off by more than a point, disregard it.
Old 02-02-2014, 11:12 PM   #161
jamesm
330-340 easy with a bit more time and a load dyno. tuning fuel on a dynojet isn't so much fun it turns out.
also note the dyno wideband is off by a lot... that's not the actual afr
Old 02-02-2014, 11:13 PM   #162
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I was looking at that afr and telling my self no way they tuned it to that !
Sent from my IBrick
Old 02-02-2014, 11:15 PM   #163
jamesm
Sent from my IBrick
nope.. the dyno wideband was more than a full AFR point leaner than the installed AEM. actual target is low 11's.
Old 02-02-2014, 11:16 PM   #164
SmsAlSuwaidi
Boosted
nope.. the dyno wideband was a full AFR point leaner than the installed AEM... maybe even a bit more.
Did ecutek address the issue with the sd and e85 tune or not yet ?
Sent from my IBrick
Old 02-02-2014, 11:20 PM   #165
jamesm
Sent from my IBrick
we've got it figured out and will proceed with the flexfuel tune once we finish getting it dialed on 93. the limiter can be raised now.. just maybe not high enough for this turbo and e85 . hopefully there will be a better solution by then. if nothing else there are some workarounds we can do to get there.
Old 02-03-2014, 04:55 PM   #166
lexusb3
Drives: FRS
That boy David!!!! And KAB nice glad y'all got it worked out
lexusb3 is offline   Reply With Quote
Old 02-03-2014, 04:57 PM   #167
mrk1
Drives: Sterling BRZ Ltd
Now I want buy a gt30, thanks @Sportsguy83
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 02-03-2014, 05:01 PM   #168
Sportsguy83
Drives: Limited BRZ
Thanks man. Glad to see you out there Saturday
Hahaha! And wait till its put on corn...
gtx3076r, kab customs, kab where amazing happens
Shift-knob Developed! - Team Voodoo Koji_Online Cosmetic Modification (Interior/Exterior/Lighting) 91 09-28-2020 04:49 AM
Local custom exhaust Gen Southern California 7 11-18-2013 09:11 PM
Report: Supercharged Toyota 86 being developed by TRD!! Craikeybaby Engine, Exhaust, Transmission 205 03-04-2012 04:42 PM
Navy developed and tested a railgun SVTSHC Off-Topic Lounge [WARNING: NO POLITICS] 21 03-01-2012 08:43 PM
