Drives: 2013 Asphalt 6spd
Fuel pump running when the car is off?
I sit in my car to listen to the radio or read a book while I eat lunch, and on occasion I will hear humming from the dash, and other times I will hear humming from the trunk. I got out today slid under the back of the car and am pretty sure it is the fuel pump running, but the car is turned completely off. I don't even have the key in the ignition. It will run for over a minute, I don't know exactly how long it goes, because I usually get annoyed and I turn the key on to acc+, then back off to make it stop. All I can think is that it is keeping the fuel system pressurized. Anybody have any idea?
#2 |
Drives: 2014 BRZ SWP LTD
Normal. Search or read the manual.
#3 |
Apostle
Drives: Fast Microwave
It says on for a while, I've noticed just sitting in the car finishing a phone conversation with the car off. *shrugs* nothing wrong.
Sent from my Nexus 5 using Tapatalk |
#4 |
It may be the purge pump you hear running (fuel evaporation leakage check).
Quite normal. humfrz |
#5 |
searched before I posted, doesn't show anything related unless it's farther down the list then I looked. I read manual first day I bought the car, I never saw anything about the fuel pump running when the car is not in operation.
I never said it wasn't normal, Just not sure why it was doing it. humfrz: It may be the purge pump you hear running (fuel evaporation leakage check). I did not know there was a pump for that, but then again I am used to a carbon canister working off of vacuum lines and solenoids, and only working with the car running. I have no clue how this one is setup. Thanks. |
#6 | ||
Drives: Firestorm FR-S (MT)
#7 |
Drives: 2014 FR-S
My car and my wife's Prius were both "talking" to each other in the garage the other night.... |
#8 |
Drives: 16 CBS WRX Limited
I'm not sure if anyone's mentioned it yet, but it's the fuel evaporation leakage check.
#9 |
Drives: 2013 MT Asphalt FR-S
Also for those of us who have the starting issue, turning on Accessory gets the pump primed and allows for first time starts. When I just turned the key all the way without waiting at ACC position for a few heartbeats, my car would not reliably start.
#10 |
#11 |
shagaliscious: Approximately five hours after the engine is turned off, you may hear sound coming from under the vehicle for several minutes. This is the sound of a fuel
evaporation leakage check and, it does not indicate a malfunction. I appreciate it, I'll have to read it again when I get home to see I can find it. |
#12 |
#13 | |
Drives: 2005 Toyota Camry
Just go read the PDF version of the manual on Subaru.com... I'm sure there is the same thing on scion.com -alex |
| Vortech 12.5 psi running on pump gas? | Adeets | Forced Induction | 27 | 10-16-2017 05:36 PM |
| Fuel pump | sw20kosh | Engine, Exhaust, Transmission | 1 | 12-10-2013 11:21 PM |
| Electric fuel pump running with car off??? | bpracer | Issues | Warranty | Recalls / TSB | 13 | 08-08-2013 10:42 AM |
| Car fuel pump on... | Genomaxter | Engine, Exhaust, Transmission | 5 | 11-29-2012 11:06 AM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 05:53 PM |
