Old 06-03-2014, 04:24 PM   #15
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
New job offer?
Not yet, but trying to cover all bases beforehand.
Old 06-03-2014, 04:42 PM   #16
samisons
Drives: 2013 Raven Fr-s, 2013 Versa Sedan
Fellow GA 86's.
I believe if you remove Cats, your Emmisions system will show "not ready" in the OBD2 monitor...
Then, if you use the EVAP soleniod line for boost control, that is a second system that will show "Not ready"....
So how do you get around this in GA? (Having two systems not ready for OBD2 yearly test)
@Reaper @dwx @ATL BRZ
My friend managed to pass emissions without his cats in his s2000. not sure how lol.
samisons is offline   Reply With Quote
Old 06-03-2014, 04:44 PM   #17
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I used to reset the ecu in early obd2 cars so it would force the tailpipe test. Then id dump isopropyl alcohol in the tank and pass everytime
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 06-03-2014, 05:05 PM   #18
J_kennington
Drives: 2013 asphalt scion FRS
You realize 98% of cars will pass without cats right? All it takes is for the tester to not look under the car, and to use one if the "tricks" to fool the ecu into thinking it's there. (Much like how we use an extended o2 well on aftermarket headers.)
Also, as far as what counties DO require emissions. It's mainly any within proximity to downtown Atlanta. Mine(douglasville) requires it, but Carroll(literally 20 miles down the street) does not.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 06-04-2014, 12:33 AM   #19
samisons
Sorry sir, I did not know that. Especially since my county does not require emissions, thus I've never had to test any of my cars.
Old 06-04-2014, 12:35 PM   #20
2pt5RS
Berz
Thanks. I was reading the law and it seems emmisions is only 13 counties within ATL metro area, but the OBD2 test is everywhere? Might be mistaken, I don't live there just reading up in the GA page for emmisions.
Is one system allowed not be ready like in other states? Or all systems are required to be ready?
AFAIK, it has to show all ready. but @J_kennington may know more about it than I do. :p
Cobb County does require emissions.. What county is your car registered in?
2pt5RS is offline   Reply With Quote
Old 06-04-2014, 02:18 PM   #21
J_kennington
If you live and registered in Marietta...you have to have emissions. Granted, we have 3 years from DOB to have to get it on our twins(in otherwords, a 2012 needs it's first emissions in 2015, a 2013 will need first emissions in 2016)
The ONLY reason I know 2 can be "not ready" is because my buddy has ran a station for 3 years now. The "not ready" fail is mainly in effect for the people who know they have a CEL, pull into the parking, clear the code, and try to get it tested.
2005 Yamaha yz250f
Old 06-04-2014, 02:19 PM   #22
ZionsWrath
Thanks
ZionsWrath's Avatar
If you know the right people and have some $ anything is possible.
I know someone who has a car all suspensions is fucked (every bump is hard metal to metal sound), ran out of oil once, all kinds of codes, etc etc lolol
Anyway they knew someone, left the car with them and they got a pass. I think it cost them 200$?
Not sure how that thing is still working to be honest but more power to them. The oil pressure warning beeps every 2 minutes when driving it, I'd go crazy personally.
Old 06-04-2014, 03:43 PM   #23
J_kennington
I'm guessing it was also an obd1 vehicle?
2005 Yamaha yz250f
Old 06-04-2014, 05:20 PM   #24
samisons
Pike county
Old 06-04-2014, 05:43 PM   #25
ZionsWrath
Thanks
ZionsWrath's Avatar
It's a 1999
Old 06-05-2014, 07:11 PM   #26
xwd
Just saw this thread.
I failed a test in my FXT because the OBD2 readiness for the O2 sensor was not complete. I'm not sure where the rule is about you are okay with 2 sensors being not ready but I'm not sure that's true.
I'm not sure what Ecutek can do as far as the readiness state goes. In the past just turning off the DTC wasn't enough to pass emissions because you'd still fail the readiness check.
CPC you could always just reconnect the stock CPC and run WG boost until emissions was done. O2 sensor would be a little more difficult unless you had a catted front pipe and even then I'm not sure it would pass. GA has no visual inspection so as long as the plug-in check passes you are good to go.
Old 05-27-2015, 04:08 PM   #27
Synack
Boosted
Synack's Avatar
Drives: Sideways
IM REVIVING THIS because I'm due VERY soon for my turbo catless 2013 FR-S.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 05-28-2015, 01:49 PM   #28
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Pay off someone or move to Florida.
WheelDude.com | Stivo Racing Exhaust System - in stock and ready to ship! WheelDude.com Engine, Exhaust, Bolt-Ons 13 10-20-2013 06:59 AM
FA20CLUB CAI V2 SYSTEM NOW READY FA20Club.com Engine, Exhaust, Transmission 51 10-03-2013 08:26 AM
INJEN and aFe Intake System, In stock and ready to ship!! 10k Redline Engine, Exhaust, Bolt-Ons 5 10-03-2012 05:05 PM
