#15 |
Vtec Jesus
Update?
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
#16 |
Drives: 5/2013 scion frs
#17 |
i'm sorry, what?
Drives: Canada
can you share how he fixed the problem? re-tap the hole? helicoil?
#18 |
#19 |
Drives: '13 BRZ Ltd
I just installed these last weekend. If you are trying to get the rears back in, loosen the front subframe bolts - this will give some slack. If you just take the rears out and drop it enough to get the upper bushings in, the bolts will only hand-thread in a few turns then stop. If this happens, do not get a wrench to apply more torque! Loosen the front bolts and play with the height of the rear or shift it around a bit as you hand tighten the bolt. You should be able to hand tighten it most of the way.
#20 | |
Good thing I have another car. The Whiteline instructions should tell you that it might be a good idea to loosen the front mounts to get a better angle on the rear bolts.
#21 |
Drives: '13 Argento MT FR-S
Well I'm one of the guys who messed up my passenger rear subframe mount, that was mentioned in a previous thread. My tap is on its way to @Brinks . I said I would make it a community tap for anyone needing it, so if you need one in the near future... contact Anthony @Brinks).
#22 |
Drives: 2013 Firestorm FRS
wow, red loctite? You wont be taking those off again haha.
Glad its all fixed though, and a good thread as a heads up to people installing bushings. |
#23 | |
Overlord
Drives: SWP 13 BRZ, 94 Miata
"FR-S or BRZ, it doesn't really matter, they're the same to me. It's a matter of choice, like mass effect, but then the thought of boxer engines make my mass erect!" -The Roman
#24 | |
I sometimes wonder if/when I sell my car, if the next person will be like "wtf did this guy do" |
#25 |
Just got everything dialed in. The threads were not messed up too bad. loosened up the front mounts to align the rear and hand tighten the bolts till they came flush with the sub frame. Its kinda obvious in retrospect that you need to loosen the fronts before threading the rears.
To anybody that is thinking about this install, make sure you look up through the sub-frame mounts to see if everything is aligned first before you even start to thread the bolt. If the bolts stops by hand, take it out and preposition the subframe. Thanks again @Kwaziekeller If anybody needs a long 14x1.5 Tap hit me up,,. Probably not a good idea to use red lock tight either, you have to use a torch to loosen that stuff up. Last edited by Brinks; 07-31-2014 at 05:02 AM. |
#26 |
No problem, glad u got everything fixed and the car back on the road. I figured that I only bought the tap for that purpose so why not share it around since I probably won't need it ever again.
#27 |
Anybody have to have the rear alignment done after installing? I'm getting some vibration through the gas pedal.
Edit - ended up being an exhaust leak Last edited by Brinks; 08-01-2014 at 06:35 PM. |
#28 |
Had this happen to me... wish I had found this thread earlier... friend lent me a tap and die set with the 14x1.5 set, and now have the rear of my subframe on...
Still gonna order a 14x1.5 helicoil set just in case something happens down the road... |
| Whiteline rear subframe bushing install... | fl_speed001 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 07-11-2020 01:29 AM |
| Whiteline KDT922 (Subframe Bushing Inserts) Grease - Safe to use on Rubber? | eckoflyte | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 07-14-2018 12:24 PM |
| whiteline rear subframe inserts | charged86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 05-18-2013 10:20 PM |
| Subframe/Drivetrain Thoughts.... | TrackDog | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 11-10-2011 11:53 PM |
