Old 10-31-2014, 03:42 AM   #71
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Here's the one I used.
http://parts.subaru.com/p/Subaru_200...0620AA111.html
I walked into the auto parts store on a fact-finding mission but when I saw how close it looked and how inexpensive it was I just took it.
There's a slight issue with the guide for the banjo fitting. I will have to cut off one of the bosses so the fitting can be aligned at 45° like the OEM cylinder. The hose is a little too tight now considering how much the engine rocks in the mounts. Minor shit.
This is gonna be tempting for me now lol...
How hard was the install? I've never changed out a slave cylinder before. Do you foresee any implications this could create in the future?
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 10-31-2014, 05:35 PM   #72
Zero issues for component wear or otherwise.
Driving it in this morning with stop & go I can see where some might not like the slightly heavier pedal but it's no worse than my brother's 911. Just feels more raw and sporty. Looking forward to @Andrew025's feedback.
As far as the installation? I'm removing it again this weekend to cut off the banjo fitting guide. I'll take photos and do a writeup but fear not, if you can adjust your clutch pedal throw, this will be easy for you. Just don't be a slob and don't crumple your fender.
Old 10-31-2014, 09:10 PM   #73
Phantobe
Phantobe's Avatar
Sweet, my clutch pedal is already adjusted to be parallel with my brake pedal.
Look forward to the writeup! Sounds like you're happy with the setup so far. I'm surprised this thread isn't getting more attention, we can't be the only ones O.o
Old 10-31-2014, 10:07 PM   #74
To say I'm happy is an understatement. Driving home today I was able to pull like a boss just rocking back on my heel. This is the SHIT!
My guess is a lot of folks are lurking with some scepticism. No, I am quite certain we are in good company.
Old 10-31-2014, 10:47 PM   #75
504
504's Avatar
Drives: 2014 86 GTS
in what way does it feel different? can you actually feel engagement point properly now?
Im quite surprised a 1mm diameter drop would make the difference you're suggesting, Nice!
Im a believer btw haha
504 is offline   Reply With Quote
Old 10-31-2014, 10:48 PM   #76
solus
Drives: 2014 Scion FRS (Ultramarine)
i have an aftermarket clutch and the engagement still sucks... is it just he pedal position?
solus is offline   Reply With Quote
Old 10-31-2014, 11:22 PM   #77
It's tough to describe in words but I think @hmong337 described it the best; at least we shared the same experience when he said
Originally Posted by hmong337 View Post
The slip window is wide and it takes precise modulation to slip smoothly. My problem is smoothly trying to get into 2nd gear without jerk or giving a tad bit too much gas when relewsing the clutch.
That wide window of slip is dramatically shortened so it's much easier to predict or feel when you have enough engagement to goose the throttle.
It just feels normal. It took no practice or getting used to because I no longer have to think about it and compensate.
1/16" difference in the diameter doesn't seem like much until you consider the mechanical advantage of the hydraulic system is a ratio of the cross sectional area of the cylinders. Since area changes with respect to the square of the radius, a little goes a long way.
Old 10-31-2014, 11:44 PM   #78
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I'm available this Sunday-Tuesday.
Let me know what works for you.
Old 10-31-2014, 11:50 PM   #79
You need this. Everyone needs this. I think the choice to go to a bigger slave was a last-minute decision after all the part placement was set in stone.
I'm guessing some suit drove it and whined about it being too stiff.
Old 10-31-2014, 11:56 PM   #80
PMed
Old 11-01-2014, 07:21 PM   #81
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
Man this is exciting. I've hated this clutch since day one and after 23k miles I still hate it/can't drive it. Feels like a broken toilet handle, there is no feedback.
Mad_Mike is offline   Reply With Quote
Old 11-01-2014, 11:47 PM   #82
37
degrees
37's Avatar
Drives: 6MT BRZ
Did it only make the pedal heavier or did it create a distinct point of engagement out of an otherwise vague process? I'm skeptical but also fully prepared to buy a slave cylinder and machine off the banjo retainer just to try this.
37 is offline   Reply With Quote
Old 11-01-2014, 11:54 PM   #83
The latter - 100%. @Andrew025 and I are meeting up tomorrow morning so he can drive it.
@Phantobe found this one. The picture on his shows a groove at the same angle as the OEM. http://www.autozone.com/drivetrain/c...er/383444_0_0/
Last edited by Ultramaroon; 11-05-2014 at 11:27 PM. Reason: Delete reference to the wrong part
Old 11-02-2014, 12:31 AM   #84
37
degrees
37's Avatar
Drives: 6MT BRZ
The latter - 100%.
Killer. That's exactly what I'm after.
I think @Phantobe found an even better fit. The picture on his shows a groove at the same angle as the OEM.
edit: http://www.autozone.com/drivetrain/c...er/383444_0_0/
Looks like the AutoZone part might be the same as the 30620-AA111. The compound angles on the banjo area look the same to me.
edit: If the line doesn't fit with your slave then I don't see why you couldn't just route it like this -3 AN line from @Chase Bays. If he's still on the forum, maybe he can comment on the effect of reducing the line size (which should in effect be the same as shrinking the slave size, barring any potential existence of a delay valve).
edit again:
That explains the alignment issue you're seeing. The OEM Forester part looks like it's in the same casting as the BRZ.
Now I wonder what might be different in the part you bought versus the original part from Subaru. Yours might be lacking a delay valve (if it exists) where the OEM parts have them. Just a thought.
Are these fake? shu5892001 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 04-11-2013 01:57 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 01:06 PM
fake Bugatti anyone? bofa Other Vehicles & General Automotive Discussions 16 07-18-2011 03:20 PM
