Old 11-02-2014, 09:40 PM   #57
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
@Drift&Drag I think *any* trans with the engine pushed back against the firewall will need that u-brace removed. the damn thing is only 6" wide, good luck finding anything that fits through that.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 11-02-2014, 10:12 PM   #58
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
Yes it is pretty damn slim. Besides removing those braces, I am ecstatic that I did not have to modify the firewall or hammer the shit out of the tunnel. Just minor mods here and there and the engine and transmission slipped right in.
As far as your downpipe clearance concern, it depends which exhaust manifold you go with. Are you going with the twin scroll PHR manifold as well? Some of the traditional manifolds may work.
Drift&Drag is offline   Reply With Quote
Old 11-02-2014, 10:59 PM   #59
SomeoneWhoIsntMe
@Drift&Drag stock vvti 1jz single for now with an ace up motorsports downpipe which is for mx83 cressida and s13/14 swaps looks like it fits perfect, if I go big single I guess I'll have to get either the ebay manifolds designed for the JZX100 chaser, the ones for s13/14 swaps, or have a custom twinscroll piece made.
Old 11-03-2014, 02:10 AM   #60
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
isn't it amazing how well the JZ tucks in there on the XM mounts? have you had to drill out the trans u-brace inside the tunnel yet, or did you not have a trans installed when you test-fitted the motor?
also, mind snapping a pic of how much room there is for a downpipe? I'm curious for when I go big single.
I'll take a pic when I get home today. I haven't test fit the wastegates on yet, but I'm fairly sure there's enough for those plus anything up to 5'' or so. But stay tuned!
slicktop is offline   Reply With Quote
Old 11-03-2014, 07:09 AM   #61
SomeoneWhoIsntMe
@Drift&Drag @slicktop what spot weld cutter did you guys wind up using? I need to order one as well as an automatic centerpunch and I have no idea what I should get
Old 11-03-2014, 09:57 AM   #62
slicktop
Old 11-03-2014, 03:51 PM   #63
TWMPerformance
Drives: Manual Transmission, All the Way!
Amazing, I'm loving the amount of 2JZ swaps that are beginning to pop up in the 86 chassis!
TWMPerformance is offline   Reply With Quote
Old 11-03-2014, 05:29 PM   #64
slicktop
Some awareness on how much room there is in this bay.
Wastegate/exhaust, plenty
Turbo/manifold, move my fusebox and I can fit virtually any size turbo on this PHR S45 manifold.
Intake, only small issues are aft side of fuel rail. Engine will probably be moved up another half inch or so and that should account for heater hoses as well.
Forward. Sits 1.5in above current radiator mount. Might mod it for more clearance but it's good currently. The vertical brace that runs between both the radiator support on the bottom and the hood latch area needs to be cut off, braced otherwise.
Old 11-04-2014, 06:08 PM   #65
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Yep, it's the best part of it having previously been a Boxer...... Gobs of room. I really need to sit down and put together my build thread too for the LSx swap. Keep it going! you are making awesome progress.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 11-04-2014, 07:33 PM   #66
vividracing
vividracing's Avatar
So excited to see this build finally come together! Keep up the great work!
vividracing is offline   Reply With Quote
Old 11-09-2014, 12:02 AM   #67
Maverick22
Maverick22's Avatar
Drives: 2013 Rocketbunny GT86
Let us see you powder coated engine parts! I hear they are super smexy!
Maverick22 is offline   Reply With Quote
Old 11-09-2014, 04:50 AM   #68
slicktop
Some more parts ordered, but mainly for removing broken oil sensors. I used the incorrect torque wrench (20ft/lbs at lowest setting) to install the oil pressure sensor. Thought I'd be able to feel when it was good to go. That little bastard broke off. Ordered some screw extractors and another appropriate torque wrench for these lower torque setting items. Lesson learned, hopefully I can extract it with no issues cause I *really* don't want to pull the motor apart again. Oh well, I guess it could be worse?
Black Friday can't come soon enough, though. Need to buy my ProEFI and RPS Triple.
Old 11-12-2014, 10:39 AM   #69
slicktop
Got that bitch, that could have been bad.
And my Chase Bays harness came in.
I ordered a FullBlown return-style 485 E85 pump kit. If anyone has an M85 IS300 differential for sale, let me know, I would like to buy one! Also ordered N/A water pipe and some other odds and ends. Should be here relatively soon.
Old 11-15-2014, 09:01 PM   #70
slicktop
ProEFI setup came in today.
Also waiting for my ProEFI color CAN logger display, Clutchmasters FX850 twin disc clutch setup, and I also found an M85 IS300 diff for a good price in great condition. They'll all be going in the car by next week. Aiming to have first start-up before Christmas. Will be mainly waiting on driveshaft and some fab work.
Props to Induction Performance and Powerhouse Racing for all their help!
2jz, 2jz brz gt86 frs swap, 2jz frs, 2jz frs swap, 2jz swap
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
Mr and Mrs FR-S Build jaydee_do_work Member's Car Journals 2 12-04-2013 10:51 AM
86 BUILD, AUS JS86JS Member's Car Journals 9 05-31-2013 09:59 AM
My build... well some of it cruzinbill Electronics | Audio | NAV | Infotainment 41 04-01-2013 05:02 PM
STX build Evil86 Tracking / Autocross / HPDE / Drifting 2 01-08-2013 04:40 PM
