#29 | |
#30 |
Drives: Nissan Murano
Ok assuming both are driven balls out, I'm putting my money on N/A all day being more reliable. There's so much more to take into account going FI.
#31 |
Hotlink Terrorist
Drives: 2015 WRB BRZ Spec S
Like air/fuel mixture, timing, cylinder pressure, oil delivery and control, cooling ,,stuff like that. Yeah, only FI engines have to worry about that.
If you want power level X, both motors are going to see stresses. While an FI engine has higher cylinder pressures, the NA engine is going to have to elevate its cylinder pressures as well AND wind up higher to achieve the same power as an FI does at lower RPMs Nothing is free. |
#32 | |
Drives: Lightening Red BRZ Ltd.
#33 | |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
I hope one day some priviteer builds a 12000rpm lightweight internal na fa20 monster. But still, the biggest drawback to this motor is the lack of variable lift.
#34 | |
Toyota did this decades ago. |
#35 | |||
Drives: 2015 Series.Blue
Hmmm... wasn't aware of that. Now if only they could fix the derpy look of the headlights on the new Mustang (and maybe cut some weight and bump the quality up a bit) Quote:
If they were both the same WHP, hell no. Know what's the coolest thing about boost? The fact you can change it on the fly. I've known 1000+HP Supras that started and drove just like it was stock (well, with loudish exhaust as it's hard to shut up 4" exhaust). Drive it all day out of boost and it's essentially boring. Now try that with an NA engine. You need large displacement, high compression (requiring race gas 100% of the time), and a cam profile that won't like to idle and is gutless until you get into the high RPM's it needs to hit to get those numbers. Speaking of the high RPM's, you'll need to be spinning that high and piston speeds are going to be an issue (as well as valve float, balancing, flywheel, etc) Quote:
Yarp, it's why I always find the comparison a bit funny. Yes, I could also go buy a used vette for the price of the twins or a used S2000 and stomp either one... Compare apples to apples and original MSRP's and the twins are a serious bargain. |
#36 |
Drives: '23 BRZ Limited
It's not really "variable lift" in the same sense that modern engines have "variable cam timing."
It's just two separate cam profiles, so it's either the low or the high-rpm cam lobe. Not so much "variable" as "either/or." |
#37 |
It is considering emissions and efficiency regs. Yes it's true that Toyota, Nissan, and Honda all made 100hp/l NA motors a while back, but it's very difficult for manufacturers to accomplish this today where they must meet stringent emissions and efficiency across their entire product line. Turbocharging is the easiest way for manufacturers to reach certain performance goals while meeting regs.
#38 |
Drives: point A to point C. Screw point B!
I think there's a few 100hp/l NA engines that would meet CAFE regs, but not CARB - California screws it all up for us!
Pretty sure there's a version of the K24 in production that's running right around 240hp. Just not available in USDM. Go figure. |
#39 |
Drives: Scion FR-S in Whiteout
So I'm hearing the F20C is just one of a kind (which I kind of already thought). Is there any decent info/thread out there on swapping the F20C in an FRS/BRZ? I'd like to preserve the handling/balance of the car if possible.
#40 | |
@86Tony seems to think the K20 is superior...
#41 | |
I thought it was K24 + K20 head + cams + E85 = 300whp At least that's what Andy Hollis has done for his OLOA Miata. |
#42 | |
At 300WHP, it's not gonna last very long at all. |
| Forged Performance - Cosworth Stage 2 FA20 Supercharger! Call for install specials! | Bobby@Forged | Forced Induction | 62 | 12-08-2015 12:01 PM |
| Cosworth teases their FA20 performance packages for the Subaru BRZ [video] | vh_supra26 | BRZ First-Gen (2012+) — General Topics | 23 | 05-31-2014 09:31 PM |
| DSPORT Dyno Tested Performance Products - FA20 | Team STILLEN | Engine, Exhaust, Transmission | 7 | 11-13-2013 07:21 PM |
| F20c engine | Whitigir | Engine, Exhaust, Transmission | 4 | 11-03-2013 08:03 PM |
| Kelford Cams FA20 High Performance Valve Springs | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 26 | 09-26-2013 09:58 AM |
