Old 02-03-2016, 03:12 PM   #211
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Originally Posted by slicktop View Post
Emtron EMS just came in last night. Looking forward to the new EMS setup. If it all works out, it'll open up a lot of swaps as a direct competitor to MoTeC in regards to CAN functionality at a much less expensive option.
which one did you use KV16?
Old 02-03-2016, 03:27 PM   #212
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
My tuner @Ross recommended me go with the KV8 for cost + build requirements. No reason to go with anything much higher (maybe the KV12 if I were trying to run dual injectors or something). Considering I have ID2000's, that'll support plenty of power by themselves.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 02-03-2016, 03:40 PM   #213
NyC Zn6
NyC Zn6's Avatar
Please keep us updated
Old 02-03-2016, 06:27 PM   #214
slicktop
DSS Pro-level axles just shipped as well~
-slicktop
2013 Scion FRS
Old 02-19-2016, 03:17 PM   #215
slicktop
Just registered for WannaGoFast on 1 May in VA. If anyone will be out there, stop by and say hi - I'm curious to see what the FRS will do in the 1/2 mile. I'm thinking of upgrading to a surge tank, but I don't know if I have the time to. We'll see.
The car should be ready next week.
-slicktop
2013 Scion FRS
Old 02-19-2016, 03:57 PM   #216
slicktop
Forgot I had this pic..
-slicktop
2013 Scion FRS
Old 02-19-2016, 04:15 PM   #217
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
what axles are they?
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 02-19-2016, 04:42 PM   #218
slicktop
Driveshaft Shop - Pro Level axles
-slicktop
2013 Scion FRS
Old 02-19-2016, 04:42 PM   #219
NyC Zn6
NyC Zn6's Avatar
Drive Shaft Shop http://www.driveshaftshop.com/
Old 03-20-2016, 03:58 PM   #220
slicktop
The harness is about wrapped up and ready to roll.
-slicktop
2013 Scion FRS
Old 03-22-2016, 12:46 PM   #221
iddrew
Drives: Toyota GT86 Pearl White
That harness is lovely! fantastic work. Following this build like mad, it's very close to what i'm doing at the moment. goodluck
iddrew is offline   Reply With Quote
Old 03-23-2016, 09:15 AM   #222
slicktop
Thanks a ton man! The harness was done by Brandon @ Trust Automotive in Chesapeake, VA.
-slicktop
2013 Scion FRS
Old 03-23-2016, 01:05 PM   #223
slicktop
Yep. This happened.
-slicktop
2013 Scion FRS
Old 04-07-2016, 09:41 PM   #224
slicktop
It's confirmed that Emtron works. I just got back from driving the car. EPS, tach, fuel level, coolant temp, speedometer are all working. @Ross will be using the Emtron to control traction control.
[ame="https://www.youtube.com/watch?v=B8Bne1XCBLg"]2JZ FRS Idle - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=T3lDx5ptZYw&nohtml5=False"]2JZ FRS low speed drive-ability - YouTube[/ame]
-slicktop
2013 Scion FRS
2jz, 2jz brz gt86 frs swap, 2jz frs, 2jz frs swap, 2jz swap
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
Mr and Mrs FR-S Build jaydee_do_work Member's Car Journals 2 12-04-2013 10:51 AM
86 BUILD, AUS JS86JS Member's Car Journals 9 05-31-2013 09:59 AM
My build... well some of it cruzinbill Electronics | Audio | NAV | Infotainment 41 04-01-2013 05:02 PM
STX build Evil86 Tracking / Autocross / HPDE / Drifting 2 01-08-2013 04:40 PM
