Old 07-18-2016, 10:55 AM   #15
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
This thread is relevant to my interests. Carry on!
@GSpeed I really appreciate your dedication to options for this chassis, and I like that it seems the interior could be modified minimally to retain most of it with this bar in place.
JazzleSAURUS is offline   Reply With Quote
Old 07-18-2016, 12:53 PM   #16
Sleepless
Drives: 2016 FR-S
Originally Posted by GSpeed View Post
MaximeT is right. You're looking at the total kinetic energy in the system, and applying that to one single point in the car all at once. Your numbers aren't wrong, that's just not the right equation for this situation.
Jake
In the example of the Mustang flipping over, the force is even worse since the car has gravity helping it as it comes down on its roof. The point is that if you are going well over 50mph, and flip like the Mustang, then you will see a force much greater than the above. Even spread over the roof, and the four points of the roll bar, the force will be enough to punch at least one of the points through the sheet metal.
Anyway, its all a matter of balancing compromises between full on race cage and nothing. For the most part, you are right that the roll bar is very unlikely to see such forces as the one on the Mustang scenario which is a worst case scenario where the car flips and lands perfectly upside down with the full force remaining from having hit the tire wall.
So far, you bar looks better than the Cusco and worse than the Autopower. However, the latter does require welding in the front footing plates which a lot of people are not willing to do. I went with a custom bar to meet my balance of compromises
It would be nice to see how the front bars are attached. It looks it is sandwiching more than the just the floor, which I think is a key selling point and might put it closer in strength to having used the rear seat shelf.
Sleepless is offline   Reply With Quote
Old 07-18-2016, 01:39 PM   #17
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Right, you see where we're coming from. No one will argue this is as strong as a fully welded cage. That's common sense. This is for the people that want a little more safety to augment aftermarket seats and harnesses. If you think you'll be in an environment where flipping is a very real possibility (wheel-to-wheel, rally, etc.) you need a fully welded cage. Which is why that's what our shop development car has.
GSpeed is offline   Reply With Quote
Old 08-16-2016, 12:25 AM   #18
byun
byun's Avatar
Drives: 2015 BRZ CWP
Any updates on this?
byun is offline   Reply With Quote
Old 08-16-2016, 10:37 AM   #19
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Yes. We have a member on this sites' car in the shop to use for interior measurements. Should be getting started this week. Our guys are finishing up some other projects before they get started on this car, and we'll have some pictures put up once work begins.
Old 08-20-2016, 06:36 AM   #20
batlwagn
Drives: 2016 Outback 3.6R, 2016 BRZ(ordered
Subbed for updates.
Sent from my SAMSUNG-SM-G890A using Tapatalk
ALL THE MODS!!
batlwagn is offline   Reply With Quote
Old 08-20-2016, 07:01 AM   #21
FRS Justin
Drives: 2013 Asphalt FRS
In the top picture the bar leans forward in the bottom picture it leans backwards which is it.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 08-20-2016, 07:32 AM   #22
FRS Justin
OK, so I just sat in my car and basically your design is close to what I have.
Looking at your drawings and comparing it to mine I see a few issues you might want to address....
1: you say not to use them with a factory seat but your bar does not include a harness bar.
2: I would consider moving it back for 2 reasons. 1st reason is someone will buy this bar and use a factory seat and kill themselves hitting their head on the bar.....2nd reason is its a bolt in bar that has maybe 2/3 the strength as a weld in bar. So knowing this I would move it back to be safer to the driver and still add protection. Yes it could punch thru but its a extra layer of protection. Mine with a harness bar weighed 47 lbs.
In February this year my nephew was driving a jeep and got t-boned by some asshole who wasn't paying attention and ran a stop sign.... He was hit so hard he shattered his skull on the roll bar and it killed him instantly... This isn't a mod for coolness points at a stance car show. A roll bar will kill you or save your life and you only get one chance to do it right.
710whp
Old 08-20-2016, 03:30 PM   #23
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Could you explain how to kill ourselves with the oem seat vs race seat ? Is that related to tilting seat back ?
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 08-20-2016, 03:56 PM   #24
FRS Justin
The oem seat offers no head protection at all if you are in a crash or roll especially if you lean it back. A race seat with shoulder harnesses will hold you down into the seat.
With the placement of the bar you would have to wear a helmet on the street or roll the dice in a oem seat.
Maybe MRK1 can explain it better...
710whp
Old 08-20-2016, 04:05 PM   #25
MaximeT
MaximeT's Avatar
I understand that, but it looks like the seat back is in front of the rol bare. You think it's still too close ?
The point of a half cage is to drive on the road to the track. That would make it useless if it's as unsafe as a full cage on the road.
(Not that I plan to use oem seat, but I plan to drive the car on the road without helmet)
Old 08-20-2016, 04:44 PM   #26
FRS Justin
I guess we will have to wait until we see a picture with someone sitting in the car.
In all fairness its hard to speculate from 2 different drawings...
710whp
Old 08-20-2016, 04:59 PM   #27
MaximeT
MaximeT's Avatar
Yes probably.
At the moment I think I may use a reclining seat like a Bride Gias 2 and full OEM safety.
Properly using the 3 point belt with a fixed back bucket on the road is looking more and more painful to setup.
Dunno if Gspeed got a solution to properly mount the seat belt receiver to pass inside the bucket seat opening ?
Old 08-21-2016, 06:35 AM   #28
MaximeT
MaximeT's Avatar
I guess with this design, the harness pass should follow the second graph ?
What's your position guys related to using a 6 point harness, no helmet and oem airbag on the road ?
I don't care at all about it being legal. Just the safety side.
It's pretty hard to find an answer so far.
GSpeed Roll Cage Kit Development GSpeed Tracking / Autocross / HPDE / Drifting 66 07-14-2016 01:59 PM
Finally looks like there is a proper bolt-in roll bar solution! OkieSnuffBox Tracking / Autocross / HPDE / Drifting 47 08-23-2015 08:13 PM
FS: Battle Version BOLT IN roll bar/cage Fortunate Few Brakes, Suspension, Chassis 22 07-22-2014 03:35 PM
Bolt in Roll cages. Ludacrits Cosmetic Modification (Interior/Exterior/Lighting) 8 01-26-2014 07:19 PM
86/BRZ/FR-S Bolt In Roll Bar by Alex Pfeiffer-Battleversion 03Z33 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 61 01-28-2013 05:57 PM
