Drives: '14 GT86 project, '13 GT86 DD
FA 20 block power limit
Hi everyone, Nige here from the UK..
I have been looking around on the net for an answer to my query, but haven't got a definitive answer yet.. thought maybe someone here could help?? As some of you will know I'm building a track car and am going to turbocharge it. I have a GTX3071R but am being led down the path of getting something bigger, like a 3576 or 3582. So, my question is this.. what is the highest power levels tested on a stock Block. Not Pistons rods or crank, but the block. I believe the weak point is the open deck design, am I right.. is this where they fail? I reckon a 3576 will give 600hp.
#2 | |
Drives: 2013 Scion FRS
Sent from my HTC6535LVW using Tapatalk |
#3 |
Drives: 2014 Scion FR-S Monogram
While I have no first hand experience with this I know that typically on EJ motors when going for very high power they would go to a closed deck and sleeved setup. Not sure if this applys to the FA20 as much or at what point it would be needed.
Raven OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap |
#4 |
Drives: 2016 Halo FRS
#5 | |
Drives: '13 10 Series FRS #1203
They tried to built the FA20 but had trouble keeping it reliable and scrapped it after the first year IIRC. As far as your question goes. I think theres a few guys pushing 600+ on the stock block reliably.
#6 |
#7 |
Thanks for the replies guys. Didn't Gushi run an EJ initially?
Beau Yates in Aus used the FA20 for a year then changed to 2J. The Vsport Aus car runs a built FA, but is nowhere near 500hp. So, do we think 600hp is safe on the stock open deck? I have read that the EJ is made of monkey metal, whereas the FA is better quality?
#8 |
Wasian Ninja
Drives: 2013 Crystal Black Silica BRZ-L
Local guy here has 500HP reliably on completely stock block
check out my build thread here
![]() Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold) |
#9 |
#11 |
The '17 manual only blocks have been strengthened compared to previous years.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#12 |
Drives: 2016 Scion FRS
I have read and seen guys on stock internals supercharged e85 running around 380hp to wheel. So 450 ish to the crank. Can our driveshafts handle 600+? I thought they would blow from the force.
#13 | |
I'm not talking stock internals here, I am asking about the strength of the block. TBH I wouldn't put any more power through the stock internals, but then, I build my own engines.
#14 |
Strengthened in what area and how?
| Help! Crawford power block install catastrophe (fixed!!) | wootwoot | Engine, Exhaust, Transmission | 54 | 02-26-2025 05:12 AM |
| Wtb Crawford power block builders | Dori_86 | Want-To-Buy Requests | 4 | 01-05-2017 03:01 AM |
| WTB crawford billet power block. | jupillam | Want-To-Buy Requests | 1 | 07-06-2015 06:09 PM |
| FS Crawford Billet Power Block used | jordanrw260 | Engine, Exhaust, Bolt-Ons | 2 | 01-16-2015 05:45 PM |
| Power limit for our transmission? TESTED YET? | hmong337 | Engine, Exhaust, Transmission | 26 | 12-12-2013 04:22 AM |
