Old 04-27-2017, 04:40 PM   #1
Nigelr32
Drives: '14 GT86 project, '13 GT86 DD
FA 20 block power limit
Hi everyone, Nige here from the UK..
I have been looking around on the net for an answer to my query, but haven't got a definitive answer yet.. thought maybe someone here could help??
As some of you will know I'm building a track car and am going to turbocharge it. I have a GTX3071R but am being led down the path of getting something bigger, like a 3576 or 3582.
So, my question is this.. what is the highest power levels tested on a stock Block. Not Pistons rods or crank, but the block. I believe the weak point is the open deck design, am I right.. is this where they fail?
I reckon a 3576 will give 600hp.
Nigelr32 is offline   Reply With Quote
Old 04-27-2017, 04:42 PM   #2
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
I think Gushi from FD still uses the stock block and has like 650hp or so. Upgraded internals of course.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 04-27-2017, 04:43 PM   #3
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
While I have no first hand experience with this I know that typically on EJ motors when going for very high power they would go to a closed deck and sleeved setup. Not sure if this applys to the FA20 as much or at what point it would be needed.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 04-27-2017, 04:56 PM   #4
Trust86
Drives: 2016 Halo FRS
Gushi's car has a 2JZ
Trust86 is offline   Reply With Quote
Old 04-27-2017, 05:11 PM   #5
Shady195
Drives: '13 10 Series FRS #1203
Gush uses a 2J
They tried to built the FA20 but had trouble keeping it reliable and scrapped it after the first year IIRC.
As far as your question goes. I think theres a few guys pushing 600+ on the stock block reliably.
Shady195 is offline   Reply With Quote
Old 04-27-2017, 05:26 PM   #6
MurderousPandas
I though he uses the FA20... or did for a year...
Old 04-27-2017, 06:23 PM   #7
Nigelr32
Thanks for the replies guys. Didn't Gushi run an EJ initially?
Beau Yates in Aus used the FA20 for a year then changed to 2J.
The Vsport Aus car runs a built FA, but is nowhere near 500hp.
So, do we think 600hp is safe on the stock open deck? I have read that the EJ is made of monkey metal, whereas the FA is better quality?
Old 04-27-2017, 06:28 PM   #8
thehapaone
Wasian Ninja
thehapaone's Avatar
Drives: 2013 Crystal Black Silica BRZ-L
Local guy here has 500HP reliably on completely stock block
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold)
thehapaone is offline   Reply With Quote
Old 04-27-2017, 06:36 PM   #9
Trust86
At first yea he used a flat 4. I don't remember if it was a fa20 or not. I thought it was an EJ they dropped in.
Old 04-28-2017, 01:50 AM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Paging @Knshro13
Probably too busy with FD Orlando.
Old 04-28-2017, 09:42 AM   #11
stevesnj
stevesnj's Avatar
The '17 manual only blocks have been strengthened compared to previous years.
My 2016 Build thread
Old 04-28-2017, 12:55 PM   #12
C11GEN
C11GEN's Avatar
Drives: 2016 Scion FRS
I have read and seen guys on stock internals supercharged e85 running around 380hp to wheel. So 450 ish to the crank. Can our driveshafts handle 600+? I thought they would blow from the force.
C11GEN is offline   Reply With Quote
Old 04-28-2017, 01:18 PM   #13
Nigelr32
I have uprated shafts, hubs and a Samsonas Sequential 'box, so drivetrain strength isn't an issue.
I'm not talking stock internals here, I am asking about the strength of the block. TBH I wouldn't put any more power through the stock internals, but then, I build my own engines.
Old 04-28-2017, 01:18 PM   #14
Nigelr32
Strengthened in what area and how?
Help! Crawford power block install catastrophe (fixed!!) wootwoot Engine, Exhaust, Transmission 54 02-26-2025 05:12 AM
Wtb Crawford power block builders Dori_86 Want-To-Buy Requests 4 01-05-2017 03:01 AM
WTB crawford billet power block. jupillam Want-To-Buy Requests 1 07-06-2015 06:09 PM
FS Crawford Billet Power Block used jordanrw260 Engine, Exhaust, Bolt-Ons 2 01-16-2015 05:45 PM
Power limit for our transmission? TESTED YET? hmong337 Engine, Exhaust, Transmission 26 12-12-2013 04:22 AM
